Old 02-07-2006, 02:07 AM   #1
Swansea_lad
Member#: 106300
2002 Yamaha YZ250
blue black rims
Default sti or mod WRX for my 99RS
ok So i am about to buy a 99RS 2.5L 2door.(rated at 165hp)
i was orgianlly goin to swap in a newer WRX EJ20 stock engine (227hp).
Im now thinking to go the whole way and want to know my options of putting in the STI engine in.
What are teh STI engine codes? the sticky thread says 2004 STI engine is EJ205T. is this the only sti engine?
also what about just getting teh EJ20 WRX engine...then is it possible/easy to swap in the STI injectors/intercoolers/turbo etc or is this not worth it.
how much are the STI components to buy individually compared to jsut getting teh STI engine?
Thanks
p.s. i would liek to avoid JDM just because i dont want to mess around with that. plus im not crazy crazy at getting it all fast. 300bhp is good to me. (even tho this will move!)
also...are there any sites(havnt found any really, yet) of places online where I can order suby engines.
Swansea_lad is offline   Reply With Quote
Old 02-07-2006, 06:37 AM   #2
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
yes. messing around with all of that.
swapstar is offline   Reply With Quote
Old 02-07-2006, 08:14 AM   #3
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
2.5l STi- ej257
I did the usdm wrx swap in mine, and i love it. With some bolt ons/engine management, it'll be plenty quick for my liking. I also stuck with the stock RS gearbox and rear diff (4.11). It makes a big difference over the uber long wrx gear ratios.
subbyspeed is offline   Reply With Quote
Old 02-07-2006, 08:53 AM   #4
the_short_bus
Member#: 106593
2008 impreza 2.5i
Dark Grey
so you like your USDM wrx swap? i'm about to do that within 2 weeks. did you ever own/drive a wrx prior for a long period of time. just curious the difference between the two with the same engine but different gearboxes?
tsb
the_short_bus is offline   Reply With Quote
Old 02-07-2006, 11:20 AM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
If 300bhp will content you, do the USDM Ej205 swap. Then, get a catless up-pipe, a TBE, and a VF30 or VF34 and some STi pinks. The turbo and injector change is making the set up very close to a JDM EJ207 2.0l set up. You won't have the advantage of the stronger block or better heads, but with a Cobb stage 2.5 reflash, you will be at 310-315chp.
And do stick with the stock tranny. The gearing is far superior to a USDM WRX's gearing. I have driven a lot of these cars. If the $$$ aren't their for a full blown RA tranny, the RS tranny is the next best option gearing-wise...
Old 02-07-2006, 12:06 PM   #6
the_short_bus
Member#: 106593
2008 impreza 2.5i
Dark Grey
ok thanks... I almost forgot about the catted uppipe. i'll have to gut the extra one i have here before the swap..
Old 02-07-2006, 12:32 PM   #7
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
tsb
Yeah, i love it.. And my goal wasn't max horsepower.. i wanted something i could build mildly, and still be reliable. I've got a stage 2 setup ready to go on the car, once i get it back from the body shop, and after that, i'll just upgrade injectors and turbo to a vf39, get a protune, and be done power-wise.
As far as gearing, i've driven a few wrx's.. Stock, and some well modded. Stock, the gears feel like they take forever. Well modded, still take forever, but now your going way too fast too quickly by the time you wrap it out. Unless you like top speed. I particularly don't.
Old 02-07-2006, 12:51 PM   #8
the_short_bus
Member#: 106593
2008 impreza 2.5i
Dark Grey
yea my goal is to get back to a stage 2 engine, like i had in my 03 wagon. with the weight difference and better gears it will be alot faster. I don't plan on going anymore than stage 2. its quick enough and a good middle ground for autox and drag.
Old 05-10-2006, 10:37 PM   #9
PinkRabbit
Member#: 110865
1999 Subaru GM6
I am also trying to decide between EJ257 or EJ20T modified in a GM6.
As of right now it will probably see very few events but I am very passionate about my daily driving.
My immediate goal is 300hp but would also like the availability of even more ponies. An extra $3k now would be worth it if upgradeability goes way up. How much more time/money/headache is it to do the full STi swap. Is it really worth it? DCCD, 6 speed? Of course the more you increase HP beyond factory the OP, the more unreliable. But, I've also heard and read that Subaruís 25, even the 257 isn't their most durable block (particularly '04).
What if this is the scenario; $10K, daily driver (no drag racing), possibly modified later but no more than 400-450hp max. Thank you all for your $.02 so far.
--- Cory
PinkRabbit is offline   Reply With Quote
Old 05-11-2006, 10:42 AM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
you won't get a wrecked sti for 10k
Old 05-14-2006, 10:21 AM   #11
fourstrokephysics
Member#: 92132
1997 OBS GFA
Yeah but the wrecked 03 WRX for my 97 OBS was only 5000...I used the dash, engine, transmission, rearend, brakes, hubs, axles, front control arms(+20mm wheelbase with no need the roll the fenders), seats, entire wiring harness (no harness splicing necessary if you do a dash swap too). The WRX already had a catless uppipe and downpipe and with the longer WRX gears in the lighter chassis, its a highway screamer. You have to use the WRX crossmember and the WRX front swaybar (or if you get an aftermarket sway bar, you'll need a 02+ sedan front swaybar, or an 02+wagon FSB if you don't do the transmission swap too. You'll gain a rear LSD by doing the tranny and rear end swap. Use the WRX front control arms if you use WRX sedan front axles (i guess this is if you're going to do a drivetrain swap too) but then you also get a set of 4 wheel disc brakes that are pretty damn good when you put them on a lighter car. Also you have to swap in the pedal box if you're going to go with the WRX tranny. Sure the 4.11 gear might be kinda quicker but that 3.90 gear isn't too bad either..I like it on long trips. An STi swap would be wicked fast but also wicked expensive and there are other issues to deal with such as the electronic throttle control. It requires fabricating a bracket to hold your gas pedal. Other than that the swaps are very similar other than the price issue. 10K is not unreasonable for an STi swap. I did my WRX swap for 5K and I outrun 350Zs all day long. Also that was in a 4 door OBS wagon, I can only imagine what the two door coupe is like. It's all up to your budget i guess.
fourstrokephysics is offline   Reply With Quote
Old 05-22-2006, 08:58 PM   #12
PinkRabbit
Member#: 110865
1999 Subaru GM6
Ok, what if we assume that it is possible to acquire an STi for 10k or just take the monetary amount out of the equation. What will serve you better; EJ257 or modified 20T?? Input is ggreatly appreciated.
Old 05-22-2006, 10:02 PM   #13
johnkaldar
Member#: 51047
1999 gc8 RS/sti-ra
If you can handle the swap, why not go jdm? If emissions doesn't come into play than it costs the same or less than the wrx swap without have to upgrade much for the 300 hp range.
johnkaldar is offline   Reply With Quote
Old 05-22-2006, 10:02 PM   #14
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
If i could have the 2.5 liter, i would. The torque is significant. But the ej205 is a good way to go for reliable power and plenty of readily available parts for it. And is cheaper than the 2.5 swap. The 2.5 will handle more stock though.
Old 05-23-2006, 07:54 PM   #15
RR02wrx
Member#: 99614
12 STi Limited
I would agree with this statment. I just purchased my entire STI swap and I swearched around for a month or two for salvaged/wrecked sti's and I couldnt really find anything lower than 12-13k. I had people telling me you can get them at auctions for 9k..etc. Ive never seen it for that low though. I got the engine, ecu, engine harness, bulkhead harness /w sti cluster, sti 6 speed, and entire driveline for 10.5.
RR02wrx is offline   Reply With Quote
Old 05-23-2006, 07:56 PM   #16
RR02wrx
Member#: 99614
12 STi Limited
I have a ej205t in my GC8 right now. I had a choice to put 11k into it, or buy a full sti conversion. It wasnt a hard decision for me at all, I opted for the STi conversion without much convincing because I know the potential of the engine. (ej205 mated to the rs tranny and driveline..etc)
WTT swapped rs for sti or modded wrx subiedude03 Private Vehicle 'For Sale' Classifieds 43 08-24-2007 02:01 AM
Need Sti Or Modded Wrx Heads For 02 Wrx (n.florida) blazinthug3577 Private 'Wanted' Classifieds 0 05-14-2007 10:11 PM
Looking for a good 05 or 06 WRX for my buddy... BlackSun Private 'Wanted' Classifieds 3 04-12-2007 04:13 PM
WTB: short ram or cai for my 99rs slidell Mid Atlantic Impreza Club -- MAIC 1 12-22-2005 08:38 AM
goodridge or equavilant <sp?> brake lines for my 99rs White 2.5rs Private 'Wanted' Classifieds 0 11-05-2004 12:13 PM
