Old 02-07-2006, 03:10 AM   #1
pjensen641
Member#: 36777
2004 WRX Wagon
Default Seemingly high stock IDC and MAF..is this normal?
In preparation of going to Cobb Stg2 as soon as the parts arrive, I have logged some data using ecuExplorer. want to make before and after comparisons to see where my $600 went. I was suprised to see IDC of 93% and MAF rates of 204 g/s. Is this normal? Seems like I don't have a bunch more room (maybe 10-15% more IDC) to up the power before maxing out the injectors.
This data point was at 5700 rpms. Ambient air temp in the upper 30's. IAM of 16, KC of +9.
And if I didn't suck at teh internet...I would post a log...but I can't find out how
Anyone else get numbers like this off of a stock WRX? Is the IDC that high because I am running way rich, or is it just because of the cold air? I am hoping someone can tell by the MAF rates.
PS...cold air rules
pjensen641 is offline   Reply With Quote
Old 02-07-2006, 12:55 PM   #2
Tea cups
Member#: 103136
204 seems a bit high for a stock WRX - that value is typical more of a stage 2 car. You also shouldn't be in the 90's IDC with a stock car, typically. Are you flashed to Cobb stage 1? Even so, I don't think you should see those high values. If anything, Cobb's maps are leaner than stock. My guess is that your MAF sensor is screwed up and is reading more air than there is. Usually they read less air, which would be a much worse situation. Or, maybe you just have a factory freak.
Tea cups is offline   Reply With Quote
Old 02-07-2006, 02:12 PM   #3
pjensen641
Member#: 36777
2004 WRX Wagon
Nope...completely..100% stock.
All I know it that in the winter...my car seems to have about 50 more ponies than in the summer. I was recording 13 psi boost at 2700 rpms, peaking at around 14 psi near the max IDC rpm. I even get noticable boost starting at 2000rpms.
To tell you the truth, if stage 2 would make may car feel like this in the summer, I will be happy. It is so gutless in the summer that I have trouble taking off from a stop without slipping the bejesus out of the clutch.
Old 02-08-2006, 12:15 AM   #4
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
I'm also at stage 1 93 oct., recently during a logged run I saw 101.96% IDC (which is threoritically impossible, has something to do with how IDC is calculated) and 205.8 g/s MAF. Intake air temp was 68 F.
This was in first gear at 24 mph, 6127 RPM.
So your not the only one seeing high IDC and MAF at stage 1, not really sure if it is "bad" for our cars at this point to be acheiving such high values.
P.S. To post your logs, try putting them in "Wrap[code] tags" icon under the advance post section. Usually takes a little fiddiling around to get them looking right .
boundy3 is offline   Reply With Quote
Old 02-08-2006, 12:33 AM   #5
Raze0r
Member#: 106727
I have a feeling your just experiencing the effects of cold weather. I don't know exactly how much cold can affect peformance but I do know that the colder the better... colder air means more dense, therefore you can run higher boost pressures without having to worry about your turbo getting angry (to some extent).
Raze0r is offline   Reply With Quote
Old 02-08-2006, 12:47 AM   #6
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
+1
Its really easy to get stock injectors to max.
cdvma is offline   Reply With Quote
Old 02-08-2006, 04:27 PM   #7
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
shave them = 850cc
Reflash stock ecu and enjoy!
You will probably see higher maf votages in the winter. I see slightly higher readings on cold days as well. What are your Maf voltages? High 3's? Maybe even 4.0, im not sure how high a stock wrx can get up to.
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 02-08-2006, 07:12 PM   #8
hondaeater69
Member#: 60324
Keep in mind stock your car is running PIG rich. Re flashes usually lean out the AFR and may actually lower IDC's all else equal. The denso injectors in our cars are known to be of very high reliability, even past the normal 80% threshold some say you shouldn't be past.
Just installed boost gauge, peaks at 12psi. Is this normal on a stock '02 WRX? AjntOrnj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 10-17-2009 01:04 PM
IDC and Maf values after porting tgv's LiquidForce Engine Management & Tuning 13 11-19-2005 09:40 PM
Having an friction sound with my new Bobcat pads and rotors, is this normal? breathinez Brakes, Steering & Suspension 2 04-25-2005 05:10 PM
Is $2,500 for taxes, plates and doc fee sound crazy or is this normal? twiztid General Community 10 11-07-2002 10:36 PM
I get .85mpa in first and second. is this normal? dijay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-05-2002 05:49 PM
