Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 02-07-2006, 08:51 AM   #1
SixSigma
Member#: 104557
2006 STi
Black w/Silver
Default 06 Stock STi - Sudden Engine Whistling Noise After High Speed
I was driving on the highway last week and wanted to open the car up, so on the next straigtaway, I punched the gas and got the car up to 140mph in 6th gear. As I got to the 140 mark, all of a sudden I hear the this really high pitch noise. I let my foot off the accelerator and the noise remained and slowly diminished as the car slowed down.
Now, whenever I drive I hear this high pitch noise as I accelerate. Any idea what this might be? Think I blew a hose or something? I looked under the hood while the car was on and didn't notice any weird noises or sounds.
It also seems now that it takes longer for the turbo to kick in and I only hear the turbo spooling once I get to 4th gear. Think this should be a dealer issue?
Any help would be appreciated.
Thanks,
Six
SixSigma is offline   Reply With Quote
Old 02-07-2006, 08:52 AM   #2
SixSigma
Member#: 104557
2006 STi
Black w/Silver
oops. wrong forum. can a mod please put this in the 2.5L forum. Thanks.
Old 02-07-2006, 09:03 AM   #3
SixSigma
Member#: 104557
2006 STi
Black w/Silver
double post.
Old 02-07-2006, 09:07 AM   #4
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Usually the whistling sound at high speeds is caused by the mirrors. I guess if you're hearing it now at low speeds then it is engine related. Weird though.
garface is offline   Reply With Quote
Old 02-07-2006, 09:10 AM   #5
Vampyr
Member#: 31761
2005 sold! STi
Aspen White w/ Gold rims
first off... how many miles were on your car when you did the 140mph run?
Vampyr is offline   Reply With Quote
Old 02-07-2006, 09:18 AM   #6
SixSigma
Member#: 104557
2006 STi
Black w/Silver
I had about 2000 miles on it. So it was broken in enough.
Old 02-07-2006, 09:18 AM   #7
subieworx
Member#: 47769
Probably an IC hose. Check the TMIC to make sure everything is connected. Is the high pitched squeal when boost is coming on? Does it sound exhaust related? Do you hear it while idleing?
subieworx is offline   Reply With Quote
Old 02-07-2006, 09:19 AM   #8
SixSigma
Member#: 104557
2006 STi
Black w/Silver
I only hear it when accelerating, even at low rpm's. It sounds like it's coming from the driver side engine compartment. But I can't be sure. It's definately not the exhaust.
Old 02-07-2006, 09:21 AM   #9
06WRXTR
Member#: 96668
2006 WRX TR
its wind noise bro, i had the same problem
06WRXTR is offline   Reply With Quote
Old 02-07-2006, 09:26 AM   #10
SixSigma
Member#: 104557
2006 STi
Black w/Silver
but it was quite loud. do you get that much wind noise?
Old 02-07-2006, 09:29 AM   #11
tomt5078
Member#: 84619
2013 BRZ
So how did you fix it then?
tomt5078 is offline   Reply With Quote
Old 02-07-2006, 09:30 AM   #12
SixSigma
Member#: 104557
2006 STi
Black w/Silver
I don't think it's wind noise because I can hear it at low speeds, like 20mph. I didn't hear this noise prior to this stunt.
Old 02-07-2006, 09:51 AM   #13
subieworx
Member#: 47769
Check all intercooler hoses then. One was likely not tightened down enough.
Old 02-07-2006, 10:17 AM   #14
aREX4X
Member#: 18781
I'm gonna say the mirror noise too, my 2002 used to do it and it scared the crap out of me the first few times, when I really got going it almost sounded like the horn a bit.
x...
aREX4X is offline   Reply With Quote
Old 02-07-2006, 10:26 AM   #15
SixSigma
Member#: 104557
2006 STi
Black w/Silver
hmm... the thing is the noise dissappears on the highway when i'm going the normal 55-80mph.
I haven't tried to get it over 100mph since. It's probably all in my head. Just weird though. The engine idles just fine. I checked the hoses and everything looks in order.
Oh well. I'll have to keep an ear out for it I guess.
Old 02-07-2006, 10:46 AM   #16
Dr. Fob
Member#: 101329
'06 STi - white
'00 S2000 - silver
My friend's '05 WRX wagon makes a whistling sound AFTER the car is shut off. The noise stays constant for at least 5 minutes. If there were air leaks it ought to have released all the pressure after 5 minutes right? Any ideas?
Dr. Fob is offline   Reply With Quote
Old 02-07-2006, 11:15 AM   #17
garface
Member#: 1581
MY00 RS/STi7
Don't the new models run the fans sometimes after the car is shut off?
Old 02-07-2006, 12:17 PM   #18
SixSigma
Member#: 104557
2006 STi
Black w/Silver
It's definately not a fan noise.
Old 02-07-2006, 12:24 PM   #19
ignomini
Member#: 106955
'04 STi
Blue, of course
My '04 does the same thing any time you hit the limiter in 6th, or load the car hard at very high speed. At first I thought it was wind noise, but now I wonder if it's the ECU dumping boost through some double secret outlet. If so, your "valve" may have stuck and you're losing boost at low speeds.
But then *** do I know, this is only my first post.
ignomini is offline   Reply With Quote
Old 02-07-2006, 12:25 PM   #20
SixSigma
Member#: 104557
2006 STi
Black w/Silver
that's the best theory yet. how do i go about checking for this?
edit: And welcome to the boards
Old 02-07-2006, 12:36 PM   #21
Timmy Burns
Member#: 99348
If I could only
get you oceanside.
There is no double secret outlet for your turbo, that I can assure you.
Any mods? Do you have gauges? If so, what were you boosting at that time? As many minor details that you can remember will be helpful.
Timmy Burns is offline   Reply With Quote
Old 02-07-2006, 12:44 PM   #22
stidailydriver
Member#: 69650
06 sti
black w/gold
like ^^he said, are you stock? how much boost? maybe you poped off a vacuum hose. and are you sure its not just the tranny whine you are hearing?
IBnewpost"howdoIremovedoublesupersecretboostvalveo utlet?"
stidailydriver is offline   Reply With Quote
Old 02-07-2006, 12:58 PM   #23
supermarkus
Member#: 6971
2008 WRX STi
SSM
Your electronic throttle makes a lot of noise even at idle, normal. It's probably in your imagination if you cant find any leaks and the noise persists. What probably happened is the whistling at high speed made you very sensitive to those types of noises, now you're listening to your car more and finding more "problems". Then you come online and look up other whistling "problems" and this site has turned you into an automotive hypochondriac. This site is great for that.
supermarkus is offline   Reply With Quote
Old 02-07-2006, 06:38 PM   #24
thehollowrift
Member#: 86788
04 STi
At that high of a speed --- your differentials do crazy things ---
Had a good friend have that similar problem or maby it was a transfer case??
its one of the two
might want to get that checked out.... and make sure you take it to a dealer without any MODS.... his problem was that he took it to a dealer and they finished off his tranny problem.......
just my .02
thehollowrift is offline   Reply With Quote
Old 02-07-2006, 07:14 PM   #25
2thAche
Member#: 83131
2004 STi
WR Blue
Is this like a high pitched electronic kind of whistle or a whoosh kind of whistle? Sometimes under partial throttle accelleration you can hear the blow-off valve dumping pressure, sounds like a whooshing whistle. Under full throttle this should go away if your RPMs are up enough.
Another thing that can make a high pitched whistle that sounds electronic is a fuel pump.
2thAche is offline   Reply With Quote
Loud whistling noise after downpipe install....leak? AutoSpeedWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 11-01-2008 09:27 PM
whistling sound at high speeds Nikko Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 05-17-2007 07:51 AM
Whistling Noise After Installing DP i-max Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-02-2007 07:57 PM
whistling noise at high mph vnmvx-0 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 02-19-2005 10:05 AM
