Old 02-08-2006, 09:18 AM   #26
latesleeper
Member#: 84898
2005 Forester XT
If you are getting that noise at cruising speeds... Check your transmission fluid? Mine was low from the factory.
latesleeper is offline   Reply With Quote
Old 02-09-2006, 12:07 AM   #27
KillerSTI04
Member#: 98912
Default Ic Hose
Its definatly and I/c Hose twice once when i was racing a 350z at about 100 i just lost aloot of power... and every time i would take it over 3000 rpms the noise would start Especially at 4000 rpm when the turbo is already spooled up. IF its making that loud of a noise its definatly the I/c Hose check it out... im sure youll be just as surprised as i was... it could be off just a little and make a hell of alot of noise
KillerSTI04 is offline   Reply With Quote
Old 02-09-2006, 12:32 AM   #28
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Does it happen if the car's not moving and stationary? Does it only happen if the cars moving? If you were to further isolate the noise would it be toward the front or rear of the engine compartment?
EtoS is offline   Reply With Quote
Old 02-09-2006, 12:58 AM   #29
Sleight55
Member#: 104960
2005 Impreza STI
Steel Grey Metallic
Default Noise
I would definitely say check all your Intercooler Hose clamps between the intake and the Intercooler, and then check the ones between the intercooler and the turbo. It really sounds like a boost leak to me. At high speeds like that you could have been boosting alot of pressure and had a clamp slip off. If that's not it something may be wrong with your By Pass Valve (BPV) If you take the hose off on the side of it, you can see the cylinder, if it looks open, it may be stuck.
Any way you look at it I bet your still under warranty, so I'd just take it in and make the dealership do all the work. Afterall you bought it from them for a reason.
Sleight55 is offline   Reply With Quote
Old 02-09-2006, 02:27 AM   #30
aznmc16
Member#: 25253
2004 WRX STi
is it a harmonic kinda sound?? and is it happening only at certain speeds??
cuz my 04 makes harmonic sounds at 65MPH. and i think its coming from the rear diff.
aznmc16 is offline   Reply With Quote
Old 02-09-2006, 08:04 AM   #31
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
It's making the noise because you did it on Rt. 8.
j/k, I grew up in Oxford, and I don't miss Rt.8.
96Lconversion is offline   Reply With Quote
Old 02-09-2006, 08:18 AM   #32
Davemeister
Member#: 86577
2016 Supercoolmobile
Awesome Pearl Metallic
That actually sounds like the noise from the mirrors. On a day with the right crosswind, my WRX sounded like it was honking the horn, or like a guy with asthma was playing a harmonica.
Davemeister is offline   Reply With Quote
Old 02-09-2006, 02:53 PM   #33
SixSigma
Member#: 104557
2006 STi
Black w/Silver
guys, the noise went away. doesn't do it anymore. what the hell?
SixSigma is offline   Reply With Quote
Old 02-09-2006, 03:31 PM   #34
wrex03
Member#: 29963
04 sti
Maybe the cat you ran over finally died.
wrex03 is offline   Reply With Quote
Old 02-09-2006, 03:35 PM   #35
SixSigma
Member#: 104557
2006 STi
Black w/Silver
ummm....lol
Old 02-09-2006, 03:59 PM   #36
korn0452
Member#: 97198
2006 impreza sti
wr blue pearl
i have an 06 sti and it all deepends on how i drive my car. for example if i drive it hard for awhile then open it when i get to about 120 it makes an extremly load humming noise on the driverside if i drive though the noise it become loader and the starts to come from the driver side. is this the same nosie posibly. my nosie sounds like the brakes are coming on slighly. but if i dive the car normal and then npen it there is no sound i can go as fast as i want without an annoying sound. any body know what this is?
korn0452 is offline   Reply With Quote
Old 02-09-2006, 04:10 PM   #37
SixSigma
Member#: 104557
2006 STi
Black w/Silver
i don't think it was the brakes. i'm pretty sure it was in engine compartment on the driver side. but the sound could have been throwing itself that high of a speed.
when i was hearing the sound afterwards, it wasn't nearly as loud. but i could make it out coming from the drivers side compartment. i really do think it was the boost getting stuck and eventually freed itself from daily driving.
Old 02-09-2006, 09:43 PM   #38
TurboDXsti
Member#: 106671
2006 Sti
grey
my 06 STI does the same thing , what the hell is that noise ?
TurboDXsti is offline   Reply With Quote
Loud whistling noise after downpipe install....leak? AutoSpeedWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 11-01-2008 09:27 PM
whistling sound at high speeds Nikko Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 05-17-2007 07:51 AM
Whistling Noise After Installing DP i-max Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-02-2007 07:57 PM
whistling noise at high mph vnmvx-0 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 02-19-2005 10:05 AM
