Old 02-07-2006, 11:12 AM   #1
markman
Member#: 93623
Have a Nice Day? n00b with ECU flashing questions
Someone on this forum recommended that I check out OpenECU & Tactrix for reprogramming a stock ECU. This looks interesting and scary and I probably won't mess it for a while if ever... but I am intrigued and have a few ???'s:
1. How difficult is it to do once you have the $80 cable? Is the software intuitive or do I need an engineering degree to do it?
2. Are there 'presets' you can download to get you started on the right path? (sorta like the Cobb AP has? 'I have this mod & this mod so I download this ROM...')
3. Has anyone here flashed their own ECU and with what results? What changes did you make and how hard was it?
4. Is there a limit as to how many times you can flash your stock ECU? I thought there was a limit; if I recall that was one of the selling points of the Cobb AP- it didn't have a limit as to how many times you can flash it.
5. Advantages/Dissadvantages of this vs. EM system?
Sorry for being such a noob
markman is offline   Reply With Quote
Old 02-07-2006, 11:35 AM   #2
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Reading and flashing the ECU is straightforward. Editing your map is not, but the tools are steadily improving. Right now, a major obstacle is that different ECUs have the maps in different places, so the tools need to have a sort of "table of contents" written for each ECU revision. If such a table already exists for your ECU, or if you're prepared to create such a table (which requires some substantial computer knowledge), actually editing the map is pretty easy.
Not yet. Since there are relatively few people right now actually editing and reflashing ROMs, there's nobody prepared to share "off the shelf" style maps.
I have done some substantial editing to my maps. I've taken my MY02 USDM WRX (AF411 ECU, A4SG900C calID) and have modified the boost maps, low and high detonation fuel maps (including rescaling the low det map for higher load sites), ignition maps, turbo dynamics and wastegate duty maps, and the CEL table. I'm running around 16.3 psig peak boost with a target AFR around 11.5:1.
There's a theoretical limit to the number of times you can flash an EEPROM, but the realistic limits are pretty high. I've flashed my ECU at least thirty times with no trouble. You need to get up into the hundreds of reflashes before you're going to have any issues.
Same advantages/disadvantages as any other reflash-based engine management. It's not as mature or have as many features as the ECUtek or AccessPort systems, but it's free and is constantly advancing.
The major pieces of the OpenECU "process" are:
* logging
* reading/flashing the ECU
* editing an ECU image
Currently, the logging phase is easy and straightforward for anyone with the TARI ecuExplorer software, with the exception of finding your Load and IAM memory locations. With the cable and ecuExplorer, you can read all the same things as DeltaDash.
The reading/flashing of the ECU is also straightforward using Colby's GUI version of the ECUflash tool.
Editing your ECU image, using either Enginuity or epifan's ecuEdit, is currently complex and requires some mental gymnastics.
Expect the editing tools to improve substantially over the next few months (these tools have already reached a substantial level of functionality in the space of two months). This will bring it up to a level where anyone comfortable with tuning a car (including professional tuners) will be able to safely and efficiently edit the maps in the ECU.
Advanced features like map switching and realtime maps are going to take a while to develop (as it requires not only changing the map data in the ECU, but reverse engineering and reprogramming the actual execution logic).
Hope that helps,
/Andrew
Kha0S is offline   Reply With Quote
Old 02-07-2006, 11:47 AM   #3
markman
Member#: 93623
wow, thanks for the quick reply... answered everything
I guess I'll keep an eye on the development until it becomes straightfoward to the point where I'm comfortable trying it out.
Old 02-07-2006, 11:54 AM   #4
Kha0S
Member#: 8808
2011 WRX
DGM 5D
At the very least, the cable is worthwhile for doing serious datalogging with ecuExplorer. Also, finding out which calID you have for your ECU, and, if it's not already copied up on openecu.org, copying it, means that support will show up for your particular ECU sooner in the editing tools.
Old 02-07-2006, 02:49 PM   #5
Gethin
Member#: 2998
Also there is a documentation project that has been started over at http://www.scoobypedia.co.uk using the OpenECU tools. Just click on the ECU button.
Gethin.
Gethin is offline   Reply With Quote
Old 02-07-2006, 03:17 PM   #6
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
Can you use the AccessECU cable?
It is cheaper, I figured why stop the money saving now ya know?
parker/slc/gc8fan is offline   Reply With Quote
Old 02-07-2006, 04:05 PM   #7
Freon
Member#: 88322
2009 BMW 135i
For now things are a bit difficult and cryptic. If you're really interested I would recommend starting to read through the openecu forums.
Technically you should be able to download, retune, and reflash any 2002-2005 USDM WRX. If nothing else you can probably tweak the target boost up a tad, maybe remove a bit of fuel from the low det fuel map and go with that for some extra power.
One of the more useful things may be the MAF scaling for those running intakes. Shouldn't be too difficult to retune this map by looking at your fuel trims and logs. This is probably the first thing I will do once I can find the damn MAF scaling values in this DBW rom...
Freon is offline   Reply With Quote
Old 02-07-2006, 04:51 PM   #8
colby
Member#: 15918
08 STI/02 PGT WRX
DGM / Orange
The AP cable works for logging, but not for reflashing because it relies on the PC serial port UART which can't generate unusual baud rates. The reflashing voltage it generates is also of marginal quality.
colby is offline   Reply With Quote
Old 02-08-2006, 12:27 PM   #9
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
Cool, Just wonderin.
Old 02-08-2006, 12:30 PM   #10
colby
Member#: 15918
08 STI/02 PGT WRX
DGM / Orange
If you can find a serial<->USB adapter that uses a FTDI chipset, you may have some luck.
colby
Old 02-08-2006, 05:58 PM   #11
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i'm wonderin why someone who works for cobb wants anything to do with free reflashing tools.
Old 02-09-2006, 09:50 AM   #12
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
edit: whoops wrong thread...
Old 04-25-2006, 01:16 AM   #13
Natoe
Member#: 90353
Sold '95 22T Impreza
'99 EJ205 L, AE86 GVR4
anybody had success with older turbo ECU's? such as the legacy turbo's or JDM sti's? (those both are very similar)
a friend of mine is confident he can tune my EJ22T ECU.
Natoe is offline   Reply With Quote
Old 04-25-2006, 11:51 AM   #14
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
Haven't found a limit yet. We have 4 vehicles currently with over 300 (2 WRX, 2 STi). reflashes on them and one is about to hit 400. There has been no signs of any problems with the ECU's at all.
Cheers,
William T. Knose Jr.
Lead Programmer
I-Speed USA
Crawford/I-Speed is offline   Reply With Quote
Old 04-25-2006, 01:49 PM   #15
colby
Member#: 15918
08 STI/02 PGT WRX
DGM / Orange
Thanks for that datapoint. I was suspecting that up to 1K flashes should be no problem. Just looking at how many pulses it takes to erase and write bits with EcuFlash, I don't see any signs of the bits tiring out on ECUs I have flashed ~50 times.
Cheers,
Lead Programmer
I-Speed USA
Old 04-25-2006, 02:41 PM   #16
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
Do you know of a way to cause the ECU to "wear out" faster than just flashing the ECU? Currenrly I don't see a problem with flashing the ECU up to 1K times like you have stated, though maybe there is something could sped up the "wear out".
Cheers,
Lead Programmer
I-Speed USA
Old 04-25-2006, 03:49 PM   #17
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
a few that come to mind:
over voltage
temperature
esd
Old 04-25-2006, 06:00 PM   #18
colby
Member#: 15918
08 STI/02 PGT WRX
DGM / Orange
A lot depends on the programming algorithm. You definitely don't want to "over erase" the bits for example. You can trap charge and age the flash very quickly this way if your reflashing kernel doesn't adaptively program/erase the flash according to the manufacturers specs. Some chips like the SH7058 provide their own reflashing code just to be sure that people don't screw up when writing their own code from the docs. It also gives them the ability to change the code in different versions of the chip in case the flash process parameters change.
Colby
Cheers,
Lead Programmer
I-Speed USA
Old 02-19-2007, 09:01 PM   #19
sniece
Member#: 9935
To revive and old thread, after doing plenty of logs to get an idea of how my engine is running, I decided to download the factory map to start looking at what's available through modifying it, but can't seem to get ECUExplorer to read it. I've connected the green connector under the dash, but I'm assuming the reason I can't read at this point is I'm not shorting the 'white connector block'...and so comes my question. Where can I find it, and what pins am I supposed to short?
Any help would be appreciated.
Thanks,
Steve
sniece is offline   Reply With Quote
Old 02-19-2007, 10:22 PM   #20
REX8
Member#: 24038
Its under the dash, RIGHT next to the green connectors...hanging down.
Old 02-19-2007, 10:29 PM   #21
Nekronaut
Member#: 133187
2012 WRX 5dr
Just a clarification for KhaOS's post.
A typical EPROM usually has on the order of 100,000 burns (flashes) to it. This may vary on the actual chip manufacturer. A few hundred re-flashes should be doable. I would stick to the mantra of do it right the first time though. Great post though.
Just my 2 cents.
Nekronaut is offline   Reply With Quote
Old 02-20-2007, 03:30 PM   #22
lh0628
Member#: 138256
2004 FXT
Would a normal serial-USB cable from computer stores work if I just want to do datalogging?
lh0628 is offline   Reply With Quote
Can't connect with ECU Flash. Detailed info inside. turboL Open Source Reflashes 17 04-04-2009 10:24 AM
Major problem with ecu flash efmd3 Open Source Reflashes 16 03-29-2009 01:16 PM
Intrest in ecu with cobb flash swap for stock ecu (5speed) Tex-WReX Texas Impreza Club Forum -- TXIC 9 06-27-2005 02:54 PM
A n00b with a few questions, please forgive me UltimateLurker Newbies & FAQs 35 03-12-2005 03:48 PM
N00b ECU tuning question... stylin2.5rs Engine Management & Tuning 2 08-19-2004 05:40 AM
