Welcome to the North American Subaru Impreza Owners Club Thursday August 27, 2015
Old 02-07-2006, 01:48 PM   #1
mpower22
Member#: 58352
04 20G STI(SOLD)
08 z51C6 (growing mullet)
Default high speed run in sti..then check engine light and engine sputters then runs fine?
I'm protuned with a 20g turbo alchy injection....the works......I'm set for 22psi with alchy....did a right rpm run in 5th while exiting an offramp.....then noticed a cel when I pulled to the light, the engine sputtered a bit then died
But it started right back up with no smoke/weird noises. I pulled over and used my accessport to pull to the cel but it said I had no fault code? I reset the ecu...reloaded the realtime alchy map and the car seems to run fine?
Are there fault codes that the ap can't read?
Does a protune erase the factory overboost code? I'm 99% it never went over 22psi?
Any ideas?..like I said idle seems okay...vacuum seems okay and nothing in the catchcan?
mpower22 is offline   Reply With Quote
Old 02-07-2006, 02:50 PM   #2
Zumble
Member#: 34860
2005 Forester CGM
The Protune should NOT supress the P0244 code but they can if they wanted to I think. I've hit boost cut before and never had my car turn off after.
Zumble is offline   Reply With Quote
Old 02-07-2006, 02:53 PM   #3
supermarkus
Member#: 6971
2008 WRX STi
SSM
Accessport CANNOT read historical codes. Once you shut the car off, the thrown code becomes a historical code.
supermarkus is offline   Reply With Quote
Old 02-07-2006, 02:59 PM   #4
mpower22
Member#: 58352
04 20G STI(SOLD)
Ahhh it was still on when I tried to read it for the first time....I'm assuming a good scantool can real historical codes.........is the list of codes in cobbs manual all the possible codes for an sti?
Old 02-07-2006, 05:17 PM   #5
hondaeater69
Member#: 60324
Did you finally get the 20G all sealed up and properly tuned?? No more firest? (i was there when she up in flames in MD )
no there are more codes than in the manual. i believe the manual just has the most common.
The overboost code will be throw if you go over the predetermined boost number set by jorge in your protune, do you know what he set that too? I"m assuming stock BCS?
chad.
Old 02-07-2006, 06:43 PM   #6
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
there is a limit to what the factor MAP sensor can read.
from what i recall, highest Absolute Pressure value is 36.98 (36.98 Absolute - 14.7 Barometric = 22.28psi boost) so that may be the value that he used for the boost limits.
Quack is offline   Reply With Quote
Old 02-07-2006, 06:53 PM   #7
mpower22
Member#: 58352
04 20G STI(SOLD)
i'm set at 22psi..using a gm boost selenoid......she runs great.....the gm bcs is rock solid.....22psi...never higher.....we'll see if she pops up again...
Old 02-07-2006, 06:57 PM   #8
Quack
Member#: 57264
stange thing is tat on a Mustang dyno i did a few pulls @ 24psi, and didn't hit boost cut, but on the way home i did. then i looked at my map & noticed it was set for ~22psi, but it still had me wondering why it didn't do it on the dyno
Check engine light, and running cycle test ?? GuitarkidM3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-19-2008 01:15 PM
Check engine light and cruise blinking at high rpm.. ORACLESTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 22 09-25-2006 10:19 PM
check engine light and speed sensor problem bwstarks Legacy Forum 6 08-10-2006 02:30 PM
Check engine light and cruise light, but no codes found in the Cobb Accessport riggs Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 12-12-2005 04:25 PM
Fuses blow...then blow... then about 10 more.... and SO ON!! ( running lights/tails? mmmprza Electrical & Lighting 23 03-11-2004 06:56 PM
