Old 02-07-2006, 02:43 PM   #1
NYCshopper
Member#: 5126
Default Full Test: 2006 BMW M5 (edmunds.com)
Video available @ Link:
http://www.edmunds.com/insideline/do...ticleId=109147
Speed and flexibility make BMW's M5 the world's most potent performance sedan
Push the start button on the 2006 BMW M5 and there's a slight delay before the engine fires as if to hint at the complexity you're about to set in motion with your finger. And when all 10 cylinders burble to life they give new meaning to the words "performance sedan."
The engine, 5.0 liters of smooth-idling perfection, is capable of more than 8,000 rpm. It typifies the harmony at work in the M5: At idle its creamy smoothness belies its full capability. Like the rest of the car, it is what you want when you want it: relaxed and composed one minute, intense and aggressive the next. It is…balanced.
So throw out your preconceptions. Ignore logic. Forget what you think you know. Then engage the MDrive button and mash the throttle and the M5 will readjust your automotive sensibilities.
Drive it
MDrive, as BMW calls it, changes the M5's character however its driver chooses. It can, at the push of a button, transform the car instantly from a comfortable and quick luxury sedan to a brilliantly balanced, insanely fast road weapon. Technically, you could set everything to change very little, if at all, but when used properly, it increases the M's power output from 400 to 500 horsepower, swaps its throttle response, shift speed and suspension damping to more aggressive settings and disables stability control. Think of MDrive as the M5's Jekyll and Hyde button.
Bump the M button, nudge the paddle, breathe the throttle and we're under way. All at once this is a different sedan from the one we parked last night. Last night it was comfortable, not soft but comfortable, shifted slowly (too slowly), and made some pretty good yank when we stepped on it. It was a banker's car. Or a doctor's car. Dr. Jekyll, perhaps.
Now it's different. Now it's sharp-edged and angry. Delay and hesitation are gone. Every action is met with a deliberate reaction. Throttle jabs in the first two gears will send you to the chiropractor. Expansion joints become speed bumps. Full throttle upshifts — even in a straight line — require countersteer correction. It is immediate. It demands respect. It is Mr. Hyde after a swirly and sugar buzz.
This personality engages serious drivers in ways others in its class never could. This is a car that takes braking, turning, accelerating and hauling passengers seriously.
An engine for the history books
From outside the car, the 5.0-liter V10's sound at idle is tinny and not at all pleasant. The harshness is the reverberation of high-energy exhaust pulses inside the long, stainless-steel manifolds. It's an ugly, abrasive sound uncommon in the world of production engines, where exhaust energy is almost always muffled by cast iron. It's also the sound of BMW's undiluted focus on performance.
Rated at 500 hp at 7,750 rpm and 383 pound-feet of torque at 6,100 rpm, the aluminum engine has a unique power delivery and its combination of sound and thrust are entirely out of place in a sedan. There's no surge of torque when the throttles are opened like in any of the current sports car engines making similar power. Rather, there's a linear wave of thrust that crescendos with an intake shriek which sounds genuinely pissed at its 8,250-rpm redline.
Much of the sound comes from the 10 individual throttle bodies swallowing air through the large plastic intake plenums that cover both banks of cylinders. But the throttles are only the beginning of the technology at work here. There's also VANOS variable valve timing infinitely adjusting the opening and closing of the four lightweight valves at each cylinder.
Other exotica? How about the 12.0:1 compression ratio, hollow camshafts and those ugly-sounding 22-inch exhaust headers. This is an expensive engine. But it makes power and stirs the soul in direct proportion to its cost.
SMG: Round three
A new seven-speed Sequential Manual Gearbox is assigned the duty of transmitting the V10's power to the tarmac and BMW tells us a six-speed manual transmission will be available in the fall of this year. The new SMG, unlike it predecessors, is the first BMW gearbox designed exclusively to operate as such. Designing it from the ground up as an SMG made it stronger and quicker-shifting than previous versions.
Drivers select from two operating modes: sequential or automatic. In sequential mode, gears are selected manually using the steering-wheel-mounted paddles or the shift lever. There are six programs to modify shift speed and clutch engagement in sequential mode. During downshifts in this mode, revs are matched to the selected gear. Requests for a downshift which would overrev the engine are ignored.
Automatic mode, from a user standpoint, is very similar to an automatic transmission in which shifts are made for you. Five shift programs are available in automatic mode and they're all quite slow.
In action it's a blessing and a curse. On its most aggressive setting it lacks subtlety to the point of feeling abusive. Full-throttle upshifts begin with a microscopic pause followed by a violent thud as torque reloads the drivetrain. They're loud, ugly and fast as hell, so be sure you mean it if you're going to do it.
Downshifts, when they're executed as requested, are heavenly. Rev matching is as computer precise as expected. But more often than not when driving hard, they're ignored. Timing downshifts to the predicted rate of deceleration is still not a task suited for street-car technology. We often had to work the downshift paddle two or three times before we got the desired gear.
A chassis dressed to thrill
Visually the M5 stands out from other 5 Series models with double-spoke 19-inch wheels, quad exhaust tips, quarter-panel vents and several minor body changes including a small trunk lid spoiler. It's a subtle freshening that will only be noticed by those keen enough to know it's an M car.
Underneath the M5's skin is a capable all-aluminum suspension design that's up to the task of harnessing this kind of power and weight (4,012 pounds). Conventional MacPherson struts up front and single lower control arms with two upper lateral links at each side make up the rear suspension.
Damping is electronically adjustable in one of three modes: "Comfort," "Normal" or "Sport" via BMW's Electronic Damping Control, which continues to adjust damping to suit road conditions within each mode. The ride, even in Comfort mode, is exceptionally well controlled. The Normal setting provides an aggressive ride and Sport is stiff enough to only be useful on a glass-smooth racetrack.
The M5's steering ratio is variable and quickens as the wheel is turned off center. Steering assist is also variable between two levels which are linked to the car's electronic damping modes. In Comfort mode more steering assist is available than in Normal or Sport modes. Steering feel is typical BMW, with sharp off-center response and a just-right soft spot on center so as not to feel nervous when cruising. It's an appropriate balance for a car like this.
Naturally, BMW's most advanced braking system graces the M5. Behind the 19-inch wheels are huge 14.7-inch front and 14.6-inch rear two-piece rotors bringing the big sedan to a stop. Surprisingly, there are no four-piston calipers hiding in the front wheels. Instead, BMW chose a far less sexy dual-piston sliding-caliper design.
Power is sent to the Continental SportContact2 tires through BMW's M Variable Differential Lock limited-slip rear differential. Torque is distributed evenly between the rear wheels when viscous fluid in the clutch-type differential is sheared by a difference in wheel speed. In action, it's a quick-reacting, natural-feeling torque distribution that spreads rubber on pavement like butter on toast.
Control room
Overall, with its combination of leather, satin aluminum or wood trim and iDrive, the M5's interior is a distinctly Bavarian balance of form and function. Because iDrive controls navigation, climate, stereo and communication settings, the dashboard is relatively uncluttered. Switches on the center console control engine output, suspension modes and all 11 SMG calibrations.
The optional 18-way adjustable heated seats in our test car were equipped with active backrest bolsters which move inward to brace the driver or passenger against cornering loads. They are a gimmicky feature that can distract at critical moments. Luckily they can be switched off. We'd make due with the standard heated seats which are only 16-way adjustable.
The thick-rimmed leather steering wheel is stitched with red and blue and serves as the perfect frame for the easy-to-read 200-mph speedometer and 9,000-rpm tachometer. There's also a head-up display which projects engine speed and gear selection into the lower portion of the windshield, but we could never find it at a glance.
How's it stack up?
This is a very different car from the Cadillac STS-V or Mercedes-Benz E55 AMG, its only obvious competitors. Both of those cars are powered by grunty, supercharged V8 engines that, when compared to the M5's high-revving V10, feel like they belong in a tractor. This unique power delivery endows the M5 with more edge and involves its driver more than a lower-revving engine.
The M5 is also faster than the Cadillac and on par with the E55 in virtually any contest of speed. Our test car plowed through the quarter-mile in 12.8 seconds at 115 mph — a full half-second quicker than the comparably priced Cadillac. It hit 60 in 4.8 seconds, slightly slower than BMW's claimed time of 4.5 seconds. Our test surface isn't known for its grip, and without the aid of launch control, which isn't available on U.S.-spec M5s, launching the car is a trial-and-error procedure.
Perhaps most impressive was the M5's 69.2-mph slalom speed, which trumps the Cadillac by exactly 4 mph — no small margin in this test. Surprisingly, it generated only 0.86g around the skid pad, a number that doesn't reflect its capability.
Braking distance from 60 mph was outstanding at only 112 feet — 10 feet shorter than the Cadillac. Pedal feel was initially solid and confidence inspiring, but we did notice very slight fade after five back-to-back stops.
Is it for you?
Learning the M5's nuances, the ins and outs of its various systems and its ridiculous number of adjustments, is a serious task. And it comes with a serious price. Our test car totaled $89,090 with options and the mandatory gas-guzzler tax.
The M5 is one hell of an advanced car and it will challenge anyone who approaches driving like a conventional enthusiast. Most of the time it's brilliant and more than capable of meeting its driver's requests for power, grip or comfort. But get lazy — leave the tranny in 7th gear then mash the throttle for a quick pass on a back road — and the SMG's brilliance fades as fast as the oncoming headlights loom. No amount of technology will save you from idiocy in manual mode.
The 2006 BMW M5 isn't just a sedan. And it isn't just a performance car. It's a new breed of machine that defies definition. It's a 500-hp four-door that's equal parts passion, performance and highfalutin utility. Like we said…balanced.
NYCshopper is offline   Reply With Quote
Old 02-07-2006, 04:09 PM   #2
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
I want to love this car. But it's two tons of weight and about five tons of ugly. Chris Bangle BURN IN HELL!
fogdor is offline   Reply With Quote
Old 02-07-2006, 04:13 PM   #3
Achilles38WRX
Member#: 4419
2002 S2K - 2013 ISP
i don't have a wrx
i have a hard time seeing why people think the 5 series/M5 is so ugly. its cleanly done, better than the z4 or 7 series.
i guess its popular to hate anything chris bangle does without forming your own opinions.
Achilles38WRX is offline   Reply With Quote
Old 02-07-2006, 04:18 PM   #4
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
Nice ad hominem attack, jackass, but I think most people agree with me
Old 02-07-2006, 04:23 PM   #5
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
I, for one, like the new M5. Like may not be a strong enough w3rd.
Hank3 is offline   Reply With Quote
Old 02-07-2006, 04:26 PM   #6
rexxer
Member#: 27624
2014 WRX
I'm in the other camp... I really like the looks of the newly designed BMWs. I'm not in the market for one, so that won't help there sales any.
Are there no Ferarris that are in the same direct class at the M5?
rexxer is offline   Reply With Quote
Old 02-07-2006, 04:29 PM   #7
BW-REX
Member#: 81504
^^^ I guess ill take it a step further, I love the new M5!
BW-REX is offline   Reply With Quote
Old 02-07-2006, 04:34 PM   #8
Foxy
Member#: 33069
2008 STI
It's interesting to see the difference in tone of review between this one and the decidedly negative one on Truth About Cars (but then again, are those guys every happy with anything other than a Porsche?). I think the M5 looks nice, and I'm sure it's a heckuva fun ride. I'll probably never find out first hand, though
Foxy is offline   Reply With Quote
Old 02-07-2006, 04:50 PM   #9
Len
Member#: 39937
2011 328i 6MT
LMB
It's REALLY not too hard to be better looking than the Z4. Yes, I hate most everything Bangle did at BMW. To me his works fall under "being different just for the sake of being different" category. I think that's a common symptom that occurs right after something reaches its creative peak and starts coming down the slope. That's just MY opinion though.
The other thing about M5 is this. If you have enough money to own an M5, wouldn't you also be able to separate your performance car and your family car? I mean, I would rather get a lighter, more nimble sports car like a Cayman S or a Carrera S, and just get a regular 5-series (or equivalent) for the family. Why combine the two?
Len is offline   Reply With Quote
Old 02-07-2006, 05:00 PM   #10
Achilles38WRX
Member#: 4419
2002 S2K - 2013 ISP
i don't have a wrx
Old 02-07-2006, 06:34 PM   #11
nogger
Member#: 17797
I think it is a beautiful car.
I would love to just drive it.
nogger is online now   Reply With Quote
Old 02-07-2006, 06:38 PM   #12
Boostjunkie22
Member#: 107001
2006 Evolution IX
Apex Silver
I like it a lot, wish I had the money for one!
Boostjunkie22 is offline   Reply With Quote
Old 02-07-2006, 08:00 PM   #13
rice h8r
Member#: 94524
very ncie car but to me, it seems a bit funky. I think they should have more color options and Bangle styling is ehh. Is it just me or does the dashboard look like it's made from cheap, hard plastic...?
rice h8r is offline   Reply With Quote
Old 02-08-2006, 08:32 AM   #14
Stonebaru
Member#: 64033
Doucherlicious
ug my eyes!
the bangles just arent smooth designs at all (and it's sad when a semi-exotic car's interior is more pleasing to the eye than it's exterior)
Stonebaru is offline   Reply With Quote
Old 02-08-2006, 07:55 PM   #15
quentinberg007
Member#: 7887
Go sit in a 5 and you'll retract your statement. Like all BMWs, it is very nice inside. It is more about feel than look.
I love when we take the Mini to the dealer... because I get to poke around in all the BMWs.
~~Quentin
quentinberg007 is offline   Reply With Quote
Old 02-08-2006, 08:08 PM   #16
wrxsubaru
Member#: 65133
Maybe its for the guy who bought a 911 turbo and wants a every day driver.
wrxsubaru is offline   Reply With Quote
Old 02-08-2006, 10:17 PM   #17
Len
Member#: 39937
2011 328i 6MT
LMB
~~Quentin
Actually I sat in a 5 a few days ago at the Philly auto show, and I honestly felt the material quality was sub-standard for the class. By class I mean compared to the GS, A6, and E-class. I don't know how durable the plastic is compared to the competitors, but it sure felt hard and plasticky. Obviously a very subjective judgement though.
Old 02-09-2006, 09:36 AM   #18
Foxy
Member#: 33069
2008 STI
Top Gear's review of the new M5, if you haven't already seen it. Jeremy didn't really like it until he pressed the M button.
Old 02-09-2006, 10:59 PM   #19
quentinberg007
Member#: 7887
Quicker than a Lotus Exige.... I'm impressed!
~~Quentin
Old 02-21-2006, 11:01 PM   #20
Dueysan
Member#: 50292
2004 Impreza WRX
Red
Let's see 90gs for a pumped up ugly Bangleized 5 series sedan....what a joke....for the same money I could buy a loaded Corvette convertible that would eat this thing alive and have top down fun and still have enough money for a loaded Cadillac CTS when I wanted a luxury sport car with four doors. Sorry BMW, I'll pass.
Dueysan is offline   Reply With Quote
Old 02-22-2006, 09:26 PM   #21
Rallycarperson
Member#: 53971
#35 SP Rally Car
MAP-RALLY.com
Im not a big fan of the M5 to tell you the truth. Even before watching the Top Gear M5 episode, I was feeling the same way like Jeremy after reading some of the M5 features...
The 5 Series is not a pretty car to start out with. It is too expensive and way too complex to be a real "performance sedan". BMW should offer a sort of M5 CSL with just the basic features...no stupid iDrive and fancy electronics. All those options should be extras, making the M5's base price cheaper. But, I do agree that if overlooking all the electronics, it is one hell of a car.
~Mark
Rallycarperson is offline   Reply With Quote
Edmunds.com Inside Line Full Test: 2008 BMW 135i USCTrojan4JC Non-Subaru News & Rumors 37 03-19-2008 11:25 AM
Edmunds.com Inside Line Full Test: 2008 BMW M3 Coupe USCTrojan4JC Non-Subaru News & Rumors 26 02-29-2008 08:04 PM
Full Test: 2007 BMW X5 4.8i (Edmunds.com) NYCshopper Non-Subaru News & Rumors 1 03-15-2007 08:00 AM
Comparison Test: 2007 Audi RS 4 vs. 2007 BMW M5 (Edmunds.com) NYCshopper Non-Subaru News & Rumors 6 03-05-2007 07:25 PM
Full Test: 2006 Porsche Cayman S (edmunds.com) NYCshopper Non-Subaru News & Rumors 20 02-02-2006 10:46 AM
