Old 02-07-2006, 02:47 PM   #1
3fordasho
Member#: 73529
Default cracked cylinder heads- how common?
patient is 02 with a burnt exhaust valve. Machine shop now found minor cracks from the spark plug holes to intake valve seats. They claimed they probably are not leaking but could cause a problem in the future. Just wondering how common this is and if others have run into this and under what conditions.. motor overheated.. etc.
3fordasho is offline   Reply With Quote
Old 02-07-2006, 03:29 PM   #2
fastlane
Member#: 17470
2002 WRX Wagon 5 Spd
^^Nomo - 04 GT Stang now
I had the same issue when I had my head rebuilt. The machinist tested and there was no leakage but he also siad that I would probably have to replace my heads the next time they need a valve job. It can be caused by numerous things such as overheating, the wrong plug heat range, overtightening of plugs, etc.
fastlane is offline   Reply With Quote
WRX '02 Cylinder Heads cracked - any suggestions? CompuPsych Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 10-31-2009 04:53 PM
How would you ship an I6 cylinder head limequat Off-Topic 15 11-25-2008 03:47 PM
Cracked Cylinder Head Minorityairsoft Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-09-2008 10:07 AM
Cylinder head cracks kingsubi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-09-2007 12:55 PM
how common/uncommon are small cracks in basement floor cement? enozto Off-Topic 8 06-02-2004 02:00 AM
