Old 02-07-2006, 05:04 PM   #1
Lachlan
Member#: 19470
1981 Brat GL
Default Strange Harmonic
I've had this problem for a while now; it hasn't affected performance from what I can tell but it's really really annoying. Whilst driving down the freeway I get a strange moaning or low whistling from time to time. It seems to be directly related to throttle position because when I hear it if I open or close the throttle a tiny bit it goes away. I don't know if it has to do with manifold pressure; I notice it happens a lot at -200mmHg, but it also happens at low levels of boost (aka negative vacuum). It's kind of like the sound you get from rubbing your finger on a crystal goblet. Any clues what it might be/how to fix it?
Lachlan is offline   Reply With Quote
Old 02-08-2006, 12:20 AM   #2
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
whats your intake setup, have you altered anything vacuum related on the car, ie. catch cans, etc.
subbyspeed is offline   Reply With Quote
Old 02-08-2006, 12:26 AM   #3
Lachlan
Member#: 19470
1981 Brat GL
I removed the resonator, that's it.
Old 02-08-2006, 01:04 AM   #4
Sean
Member#: 518
762 PGT Impreza L,
Silverado EXT, Yaris
This is a shot in the dark here but does it sound mechanical or pneumatic? I have an intermittent whine in my drivetrain. North Ursalia told me at one point it may be prop shaft related if I remember correctly.
NESIC Web Site | Trunkmonkey FAQ | Trunkmonkey Racing | Trunkmonkeys in Action
Sean is offline   Reply With Quote
Old 02-10-2006, 12:27 PM   #5
USMARINE24M
Member#: 42077
98RS 98 JDM EJ20
i am having the same problem i think.. performance is still the same, but i hear that noise right before boost and sometimes during boost.. It mostly happens when i'm in 5th gear around -10 to 0 vaccum, doing about 50.. just a light touch on the gas and it will go away, but then if i let my foot back to where it was the noise comes back.. it happens in other gears too.. as far as i know i dont have any leaks.. to me it sounds like a someone blowing in an empty beer bottle.. its annoying cuz i'm not sure how loud it is outside the car. the sound comes from in front of me somewhere in the engine compartment, i think my side or towards the middle.. cant duplicate sound with the car parked..
USMARINE24M is offline   Reply With Quote
Old 02-10-2006, 12:41 PM   #6
Lachlan
Member#: 19470
1981 Brat GL
That sounds like what I have. If it were something propshaft related I would assume it would be coordinated with vehicle speed--but it's not. It all has to do with throttle position and perhaps to a lesser extent manifold pressure.
Underdrive pulleys and harmonic vibs.. StupidFast Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 65 03-24-2002 03:37 AM
tech question about harmonics PeterJ Normally Aspirated Powertrain 2 03-14-2002 10:50 AM
2 RS in Harmon. CosmoTheCat North West Impreza Club Forum -- NWIC 0 04-28-2001 08:33 PM
Underdrive pulleys - harmonics Greborb Normally Aspirated Powertrain 39 03-21-2001 07:53 AM
UR pulley / harmonic dampers / risk v. benefit psst. SHIV cvalle-sd Technical Forum Archive 4 08-21-2000 08:46 AM
