Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 02-07-2006, 07:12 PM   #1
amievil
Member#: 56803
1991 & 1994 Miata
1998 Legacy Outback Wgn
Default accesport has no power
i just received my accessport from cobb eager to hook it up and to my surprise it won't turn on. i have the car in test mode with fans cycling and fuel pump clicking but plug accessport into dash and no power. i was thinking maybe it is the cable so i tried to hook it to my pc just to see if it works but it doesn't give an option to sync with pc, i guess maybe because it's unmarried? does any one else have problems with the cables or similar problems to mine. seems like the would test this stuff before they send it out.
amievil is offline   Reply With Quote
Old 02-07-2006, 07:27 PM   #2
dvang
Member#: 84188
05 legacy
caravan full of kids now
call cobb
dvang is offline   Reply With Quote
Old 02-07-2006, 07:30 PM   #3
phantomsr
Member#: 69071
2002 Stg2-WRX Wagon
WRB & Dust
If it powers up when you connect to the PC then it's got to be the cable. If you want to sync to the PC, hold the up and down arrows when you power it up.
phantomsr is offline   Reply With Quote
Old 02-07-2006, 07:56 PM   #4
amievil
Member#: 56803
1991 & 1994 Miata
i did call cobb and they said they are emailing me a label to ship cable back. cobb tech told me i could sync with pc until it is married. also i took a voltage meter and tested every pin on the cable that goes from the car to ap and got conductivity on one pin as i held one wire to each pin and tested each pin on the oppsite end, does not seem right.
No dash and shifter lights and radio has no power Jutboy Electrical & Lighting 9 06-24-2008 11:47 AM
computer has no power subi444 Newbies & FAQs 0 08-14-2007 05:13 PM
Installed 04 Sti Cluster into my car and now my Alpine has no power. JeffrWRX Interior & Exterior Modification 15 02-10-2007 11:45 AM
WRX has no power!! engine stalls and bogs!! Loomin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 08-22-2006 09:56 PM
Car has no electrical power at all... jojo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-16-2006 01:22 PM
