Old 02-11-2006, 09:28 PM   #1
Eskram
Member#: 16697
2004 2.5 Hybrid 18g
Wagon + LGT 1-4 g00dness!
Default Worth putting header back on for protune?
I'm getting my car Protuned by Topspeed in a few weeks.
I have a 1st-gen GT Spec header that is currently off of the car. I had ongoing problems getting the uppipe joint to seal with the header on, so I took it off several months ago and put the stock manifold back on.
Is it worth the hassle to put it back on and hope I can get it to seal, or should I just stick with the factory manifold for now? What kind of gains with a header are people getting over a standard stg2 protune?
Eskram is offline   Reply With Quote
Old 02-11-2006, 09:34 PM   #2
hondaeater69
Member#: 60324
typical header results. . .gain HP in the top end, lose it on the bottom. If you are willing to sacrifice bottom end for top end, AND get the leak fixed, it's your choice go for it!
hondaeater69 is offline   Reply With Quote
Old 02-12-2006, 03:38 AM   #3
Bbasso
Member#: 66235
2005 WRX
I'd think that has to do with the design of the header, So a general statement like that is not really fair to say.
Most of the time when improving the flow of exhaust usually helps to gain power thru out the entire RPM range....
If you have any proof of your claim then I would glady retract my last statement.
Bbasso is offline   Reply With Quote
Old 02-12-2006, 04:10 AM   #4
hondaeater69
Member#: 60324
on a NA car headers will usually add power throughout the RPM range, on turbo applications a header usually creates a longer path to the turbo creating a small amount of lag in the front part of the RPM band. . .I'd find you proof, but i don't feel like it right now, maybe tomorrow k.
I don't know if you're nitpicking or not, but for clarification i'm talking about aftermarket tublar headers. . .
Old 02-12-2006, 12:13 PM   #5
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
based on my experience, I agree with hondaeater69.
txl146 is offline   Reply With Quote
Old 02-12-2006, 06:14 PM   #6
Eskram
Member#: 16697
2004 2.5 Hybrid 18g
Hmm.. Sounds like it's not worth the trouble. I'll probably just leave it off then and possibly sell it.
Thanks.
Old 02-13-2006, 01:38 AM   #7
JustA4
Member#: 58210
2004 35r STi
186mph - standing mile!
FWIW - I Talked with PDX Tuning about putting some Headers on my car with the install of the GT30r. They responded that the current exhaust manifold isn't a limiting factor and that it has better velocity to the turbo than current headers. He said the money could be better spent on other mods.
JustA4 is offline   Reply With Quote
Is it worth putting STI springs on my 07 2.5i? Buktheng Impreza Forum 14 06-06-2009 09:27 PM
Good thing I put my trusty RE92's back on for the summer roffle Off-Topic 27 04-01-2005 10:37 PM
Sunroof leaks , piece of rubber came off - help putting it back on Legacy Legacy Forum 1 03-22-2003 10:35 PM
how to put badges back on? elemental Interior & Exterior Modification 9 01-06-2003 03:46 AM
Putting badges back on? 98kPa Interior & Exterior Modification 8 04-25-2002 05:12 PM
Message Board Statistics All times are GMT -4. The time now is 12:30 AM.
