#1 |
Member#: 7006
NESIC
Vehicle:2007 SpecB |
Anyone have any experience with aftermarket struts. I was looking at KYB AGX struts, but will my stock tire and rim size rub on those? 205/60/15?
Also won't it lower my car?
#2 |
Member#: 5030
Vehicle:1999 Legacy 2.5GT 05 Legacy GT 06 Armada |
They shouldn't. AGXs are made and marketed as stock replacement struts.
I have a set of the RS AGXs on my car currently. I haven't had any rubbing or fitment issues. Brad |
#3 |
Member#: 8386
Vehicle:1998 Legacy GT 2.5 Red |
KYB AGX's should work.. I have them on my car and no rubbing
#4 |
Member#: 4615
BAIC
Vehicle:05 STi, 97 Leg OB |
IGNORE THE GT GUYS
![]() seriously, though, AGX's won't work, they'll rub. BTW, your stock size is 205/70/15, not 60 it might work with 60's, but I'm not sure. The tires are too tall, and they'll hit the spring perches, unless you run smaller (shorter) tires. |
#5 | |
Member#: 5211
Vehicle:1997 Legacy Outback Spruce Pearl green |
Here is the deal on Outbacks. There are no aftermarket struts that will clear the stock 205/70-15 tires. Any currently available strut (other than stock replacements) will also lower the car about an inch. You can keep your wheels and switch to something like 205/60-15 tires (about the same size as Legacy Gt 16" tires). In theory these will make your speedo read fast, but I am currently running Impreza RS 16" wheels and tires and I have not noticed anything. I suspect that Subaru didn't do anything to correct the speedo on Outbacks. Doug |
#6 |
Member#: 7006
NESIC
What would be the struts that would allow me to keep closest to original height? What about springs?
Anything out there that'll let me put on 225/45/17's and not have rubbing. ![]() |
#7 | |
Member#: 5211
Anything WILL let you run 225/45-17 tires without rubbing (at least with correct Subaru offset wheels). The diameter of these is the same as that of stock Legacy GT wheels/tires and is much smaller than Outback stockers so there is plenty of room. Doug |
#8 |
Member#: 2362
Vehicle:1999 Legacy Outback Blue w/ Paint Chips & Mud |
So the basic gist of this is if you want to mod an outback, you will need new wheels and tires.
My plan: -rear strut brace -rear swaybar mounts & endlinks Then, depending on $$$... -Gold P1s w/ 225/45-17 tires -KYB/AGX with some good non-lowering springs -used rally or mud tires for my five 15" stock alloy rims that will fit with the AGX's. (for offroad excursions and rallyx, don't want to scratch the P1s!) If no $$$ available by the time my current tires are shot to hell (shortly...) Then: -Dunlop SP5000 in 215/65/15 (plus zero size, I believe, but should help performance.) on my current 15" rims. Should only be under $500. There is certainly a WRX in my future, but certainly not the very near future. I'm thinking a 2004 or 2005 model. In the meantime, this luxo-bargewagon is all I've got. Might as well make the most of it, and while gold P1's might look rather silly on the Outback, when I *finally* get my WR Blue WRX, they will fit in perfectly. |
| Thread Tools | |
| Display Modes | |
| Looking for performance parts for 98 GT wagon | jakmobile | Legacy Forum | 5 | 03-08-2006 06:46 AM |
| Looking for performance parts for my Subaru | General7 | Newbies & FAQs | 10 | 05-24-2005 09:55 PM |
| The 96 L is gone ( tears ) and now the 97 OUTBACK is coming... | RaceComp Engineering | Mid Atlantic Impreza Club -- MAIC | 0 | 05-16-2005 08:17 AM |
| Crossbars for roof rack off a 97 outback | Sobelizard109 | Private 'For Sale' Classifieds | 1 | 11-11-2003 08:38 PM |
| ? about the 97 outback sport wagen brake ! | trustz | Brakes, Steering & Suspension | 3 | 09-25-2002 02:51 PM |
