Old 02-08-2006, 02:10 PM   #1
cordizzle
Member#: 55109
2006 sti
Default Installation
Hi, This summer im going to be looking at doing a ver. 7 sti spec c swap including the engine, tranny, wiring harness, suspension, brakes, drivetrain, rear diff, etc. i live in eastern PA and there are not a lot of shops around here that would do a swap of this type. I have 3 friends of mine who do all of their own engine work that said they would help me. Is this possible? They have everything needed to do the swap. Im wondering how hard and how long it would take to do the swap in 1 weekend or so.
Thanks
cordizzle is offline   Reply With Quote
Old 02-08-2006, 09:07 PM   #2
cordizzle
Member#: 55109
2006 sti
bump for info
Old 02-09-2006, 12:37 AM   #3
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
im not sure on the wiring, but if its anything like the older GC swaps your going to be hating life after about 2 weeks of wiring(thats if your good).
I just got done w/ my swap, and it took me 2weeks to do it. of witch 10 days where spent stricktly on wiring.
do your homework and look around. this swap has been done hundreds of times, and there is plunty of info on it.
good luck
snowman4us is offline   Reply With Quote
Old 02-09-2006, 02:14 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
good luck
took me 3 days to build my harness(from scratch) and 1 week working outside to splice it in...it's not as bad as people make it sound....then again i do this for a living
Old 02-09-2006, 06:57 AM   #5
cordizzle
Member#: 55109
2006 sti
but if i get a ver7 engine and but it in my bugeyes, shouldnt everything line up, including the wiring harness?
Old 02-09-2006, 12:01 PM   #6
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
you can run the ver.7 engine off of your wrx wiring already in the car.. You may need to add some wires for avcs if equipped.
subbyspeed is offline   Reply With Quote
Old 02-09-2006, 05:39 PM   #7
cordizzle
Member#: 55109
2006 sti
So now that I understand the wire needs, is it possible to get a few friends and myself to DIY this since we know what we are doing?
Old 02-09-2006, 11:55 PM   #8
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
I don't see why not. As long as you have the information you would really need to do it. ecu pinouts, and wiring diagrams if need be.
Old 02-10-2006, 08:42 AM   #9
cordizzle
Member#: 55109
2006 sti
does anyone know where I can get in information above if needed?
Old 02-11-2006, 12:31 PM   #10
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
im fairly good with cars, but this was the 1st time i did something on this level. im sure if i where to do it again, i could cut down the wiring time by 1/2. i just had to find out things as i went, and took notes on it. there is allways little things that you dont find out till you try and start the motor.
Old 02-11-2006, 09:17 PM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
yeah like me swapping the crankshaft and camshaft signal pins in the gray connetor near the turbo....it took me about 2 hours to figure out why i had fuel and spark and it was popping back thru the intake. i then found out that you can't run a factory WRX BOV to atmosphere(car would start run for 5 seconds then start to lope and die)....ah yes, the joys of putting a powertrain in a car that it was not originally intended for.
Jeremy
Anyone need help with an install? RubbleDTD Mid Atlantic Impreza Club -- MAIC 0 06-03-2010 05:23 AM
Hydra install on oldschool? tenchu Other Engine Management 0 06-03-2010 04:37 AM
Just installed the Injen CAI, Ultimate racing up-pipe install w/ dyno time to follow All8up Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-07-2002 08:45 AM
Springs installed, Steve awesome installer LDragon South East Region Forum 3 10-03-2001 09:44 PM
Do installers take off door side panles to install tint? TriniTuner Interior & Exterior Modification 10 07-27-2001 02:35 PM
