Old 02-08-2006, 03:36 PM   #1
YinUCSD
Member#: 44945
06 LGT wag
Question 4EAT Issue: At stop sign/traffic light, car stays in neutral when I step on the gas.
Hey guys,
I think I have a transmission issue but I'm not really sure. So I'm sitting at a light or stop sign, and then when I step on the gas (about 50% of the way down: somewhere between just barely pressing it and WOT), the car stays in neutral for a few seconds, then goes into gear. It's kind of annoying and dangerous when trying to go through a busy intersection where cross traffic does not stop . Sometimes, it happens when I simply slow down to make a slow turn. When I make the turn to step on the gas, the same thing happens and stays in neutral for a few seconds. It's very noticable.
I dont think it is an ECU learning issue or anything like that. Unless it is and I'm just missing something here. What do you guys think?
:tia:
YinUCSD is offline   Reply With Quote
Old 02-08-2006, 03:45 PM   #2
c'dalerider
Member#: 92388
04 WRX, 06 STI
wrb x 2,900awhp combo
it sounds like youre trany is in trouble. Take it to youre mechanic to be checked out. trany fluid ok?
c'dalerider is offline   Reply With Quote
Old 02-08-2006, 05:01 PM   #3
MNAutomatic
Member#: 50038
2003 WRX Sedan
tranny fluid is low....check the stick and fill it up. If that isn't the case I would then guess clutchpacks maybe.
MNAutomatic is offline   Reply With Quote
Old 02-08-2006, 10:37 PM   #4
YinUCSD
Member#: 44945
06 LGT wag
how is that lucas transmission goo or wahtever
i'm gonna go to kragen tonight and pick up some atf to top off my fluids. update tomorrow....
Old 02-09-2006, 01:06 PM   #5
Hayes
Member#: 11808
Check fluid not only for proper level but is it red or burnt color. Think about replacing the fluid if it's burnt or dark color and or if it has more that 30,000 miles on it. JMO
Hayes is offline   Reply With Quote
Old 02-09-2006, 03:46 PM   #6
YinUCSD
Member#: 44945
06 LGT wag
^but even new dextron3 fluid is red. i should just replace it anyway since my car has 45k miles...
so ive been doing some searching and its not very clear as to how do a 4eat transmission flush. even drain n fill threads, i see conflicting numbers for how much fluid to add back in. scoobymods has nothing on 4eat tranny fluid either. hmm. i suppose i'll just measure out how much came out and put that back in plus another quart, and then check levels.
Old 02-09-2006, 06:31 PM   #7
WRX02WRB
Member#: 36240
2015 STi
Your owners manual should have that information.
WRX02WRB is offline   Reply With Quote
Old 02-09-2006, 08:22 PM   #8
YinUCSD
Member#: 44945
06 LGT wag
^ oh yeah... i am a true believer of the owner's manual, but the problem is that i dont have one!!! seriously . when i bought this car used, the previous owner lost it i guess. can anyone help me out with this info from your 4eat owner's manual?
:tia:
Old 02-09-2006, 09:32 PM   #9
BoneStockTS
Member#: 80670
:tia:
You can register (for free) at my.subaru.com , from where you can download the manual for free.
BoneStockTS is offline   Reply With Quote
Old 02-10-2006, 10:43 AM   #10
YinUCSD
Member#: 44945
06 LGT wag
^ cool thanks for the info. dang i didnt know that isht.
When I step on the brakes my cluster light up? Doomsayer Electrical & Lighting 1 03-16-2010 02:15 PM
If your 09 wrx has a wierd noise when you step on the clutch cold start, subscribe ! WRrexu General Community 20 10-03-2009 01:23 PM
Found this at work, you bet i'm going to use it when i leave on the suby... anthonywrx Off-Topic 3 04-27-2007 04:00 PM
"...Get in, step on the gas, and the power hidden under the hood delivers... Hazdaz Off-Topic 15 06-26-2006 11:10 PM
Escort 8500 goes off Laser when I step on gas in my WRX cky211 Electrical & Lighting 45 04-05-2004 02:18 AM
