#1 |
Member#: 77939
Vehicle:00 GF Rustbucket |
My HGs on my 98 Legacy GT are going and I figure I might as well do a swap instead on changing the gaskets.
Im debating whether to do the ez30. I have read the anders8 and phatsuby threads but im still left lacking some info. Does anyone have any other threads that would be helpful?(I did try to search) Can anyone give me a general overview of what I would need to complete the swap? Approx cost? From what I understand, the motor will bolt right up to chassis and tranny. Issues would be wiring and any problems with the auto tranny ecu in a manual. Do you have to contact gruppe-s for motors? cause they dont have them listed on their website. Thanks for any help -Ben
#2 |
Member#: 2272
BAIC
Vehicle:95 L AWD LIFTED!!! 1970 Subaru FF-1 Coupe |
There arent any other threads. PM anders or phatsuby or slack for more info.
#3 |
Member#: 13617
Vehicle:2001 Legacy GT back to stock is a project too |
so when you say EZ30 do you mean EZ30 or EZ30R? Because anders has an EZ30 and I have a R. Gruppe-s only has the R's that I have seen. If you are doing the regular 30 use the stock ecu, it wont be a problem however you may have to get a little creative with your starter, or at least cruise control because you wont have a neutral switch input on the ecu. Other than that you will pretty much be fine. If you are planning on the R then stand alone is the only way to go which the Hydra is the only solution.
hope that helps some, if you need more specifics let me know and I can try to help. Ben |
#4 |
Member#: 77939
PM'd you phatsuby
I do realize that the motors are different. Last edited by mtnbikeman123; 02-11-2006 at 04:05 AM. |
| Thread Tools | |
| Display Modes | |
| 08 impreza swap EZ30?? | EVOWHO | Subaru Conversions | 8 | 05-22-2008 12:29 PM |
| Where are all these EZ30 and 6cyl swaps? | wgknestrick | Proven Power Bragging | 27 | 03-12-2006 05:56 PM |
| So whats so hard about the EZ30 swap? | jamesfacts | Normally Aspirated Powertrain | 7 | 09-11-2004 09:12 PM |
| Any News of the New EZ30 Premiered at IAA? | Jon [in CT] | News & Rumors | 1 | 09-08-2003 11:28 PM |
| EG33/EZ30 Oil pump compatable with EJ20? | kidatari | Subaru Conversions | 0 | 07-31-2003 02:47 AM |
