Old 02-09-2006, 01:27 PM   #1
thered1
Member#: 105955
95 impreza l
green
Default which ecu/harness
I hate being new on forums...i have over 3000 posts on the mazda forum im a member of, im not new to these, im just looking for an answer. What ecu can/should i use with a 94-95 JDM ej20t engine? will the ecu and harness from a 2002+ usdm wrx? i just need to know the differenct between this jdm engine, and the 2002 wrx engine im going to buy. The jdm ones cheaper but if it doesnt work with all the 02 wrx wiring...obviously that wouldnt be a good buy.
thered1 is offline   Reply With Quote
Old 02-09-2006, 02:36 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
94-95 ecu +harness its also important to note that subaru only has 1 harness every thing under the dash is wrapped together be sure to get the WHOLE deal
some random facts about the ej20
has been in production since 1989
major revisions
ej20G (legacyGT(vf-10) legacy RS(vf-12) impreza mt(td05) impreza auto(upturned inlet td04)
ej20G (sti version, sti ver 2 late sti ver2[5 injectors])
ej20G (late version different ecu and wasted spark coil (td04 inline inlet))
ej20h twin turbo mechanically similar long block to ej20g same injectors known for valley of death in between turbos, turbo manifold/vacuum solenoid box fouls on steering colum in LHD car
ej20k sti 3 and 4 vf-22 vf-23
ej205 (jdm early, jdm late (avcs), usdm)
ej20R bp/bl chassis throttle by wire
ej207 early ver 5&ver 6 late ver 7+ (avcs)
if you have to pass smog inspection at all the usdm ej20 ecu is the way to go and has significant support in the usdm aftermarket
Old 02-09-2006, 05:02 PM   #3
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
if you are adventurous and want to pass obd2, you could fit a entire usdm wrx wiring harness on a ej20G motor. youd have to have EVERYTHING though, full engine/bulkhead/ecu/rear etc.
work also required.
you'll have a tough time finding a ej20g wiring harness. thats why i stash them away for spare
swapstar is offline   Reply With Quote
EJ18 ECU into EJ22 ECU harness FuJi K Normally Aspirated Powertrain 6 09-08-2004 10:55 PM
ECU harness one last time volley Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-06-2002 08:49 PM
location of some sensors on the MY02 factory ecu harness. . . wackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-04-2002 07:52 PM
ej-20g,turbo,ic,tranny,ecu,harness,cheap bttune2.5rs New England Impreza Club Forum -- NESIC 3 01-06-2001 05:50 PM
sti v.6 motor ecu + harness interested? doripreza Technical Forum Archive 13 07-28-2000 12:53 AM
