Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 02-09-2006, 02:27 PM   #1
Member#: 35176
1998 2.5 RS Impreza
2000 gray OBX
Default Which mounts,bushing to get for swap-04sti ingc8
Hey guys, Im getting ready to do my swap on my gc8( 04 sti motor, trans, diff, hubs, etc.) Since my whole car will be apart I was wondering what upgrades you would recommend. I currently have the Sti tranny, motor, and pitch stop mount for my gc8.
I was looking at the following:
Whiteline Steering rack bushing
Whiteline KSB751 Diff Lock Kit
New camber bolts
Control Arm Bushings
Kartboy Transmission Crossmember Bushings
Kartboy Rear Differential Bushings
Kartboy Rear shifter Bushing
Kartboy Shift Lever
Any recommendations on what would you get/not get. OR any other advice and new ideas are welcomed.
Last edited by mjd85la; 02-09-2006 at 05:54 PM. Reason: pictures from turninconcepts.com
mjd85la is offline   Reply With Quote
Old 02-09-2006, 05:16 PM   #2
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
Definetely do the steering rack bushings while doing the swap. No added labor when taking everything apart.
The diff. bushings i'd do too.. But i'm not sure which ones you'd have to buy, since your upgrading all of that stuff. i'd assume for the sti.. but i'm not positive.
subbyspeed is offline   Reply With Quote
Old 02-09-2006, 05:40 PM   #3
Member#: 17300
1993 Widebody Wagon
748whp e98
The STi engine mounts will work with the new motor (engine + pitch stops)
Pretty sure you'll have to buy a 6MT STi transmission mount that's different than the 5MT one
If your going with the 6spd use all the 6spd Shift Linkage and therefore all the 6spd bushing for anything shifter related.
Rear end if you swapping the whole R180 subframe obviously the bushings for the STi aswell
Steering rack bushing depends on if you want to use the STi crossmember with the STi steering rack, but even then I think you have to do some more swapping of the steering column aswell. You'll have to ask someone who's accually done it. If you stick with the RS steering rack then use the ones designed for the GC.
Kotir is offline   Reply With Quote
Old 02-09-2006, 05:57 PM   #4
Member#: 35176
1998 2.5 RS Impreza
2000 gray OBX
Yes, i am swapping all crossmembers, r180 and Sti steering rack. Are you saying the Sti shift bushings instead of upgrading?
Old 02-09-2006, 08:41 PM   #5
Member#: 71201
Shop Sport Service
Hey, I see the swap is coming along....good for you.
I agree that now is the time to do bushings. I'd consider doing an Anti-Lift kit as now is the time to do it if you think it's a mod for you. The Kartboy shifter bushings are cheap, but i would not say they are necessary. They make more of a difference on the 5mt than the 6mt...so if you are tight on cash i'd say this is one you can hold off on. The short shifter though will make a big difference.
PM me if you have any questions or would like some prices on Kartboy stuff.
When's this thing coming together? Good luck with everything
dentsport is offline   Reply With Quote
which spring type to get for KYB/Dspec setup igoeasy Brakes, Steering & Suspension 2 07-27-2009 03:20 PM
Which Brake Booster To Use for Swap? beaviscih Subaru Conversions 21 05-24-2009 08:48 AM
Which trans cooler to get for 04 4EAT WRX? Tube/fin or bar/plate? fuzzymemory Transmission (AT/MT) & Driveline 5 03-28-2007 10:06 PM
Which tire size to get for a wagon? Unabomber Tire & Wheel 11 07-30-2004 11:11 PM
Which pulley to get for most performance gain and reliability? WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-06-2002 03:55 AM
