Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 02-09-2006, 04:15 PM   #1
Shabib67
Member#: 61749
Default utec problem
Hey guys, I just got my utec installed and have it set on map 1. I have a turboback exhaust and intake. My problem is when i connect to the utec, i can access any feature like dashboard, data logger, etc. However whenever i access the map editor, it just shows a hundred symbols and then it freezes the hyperterminal. Any idea whats going on and how to fix it? Im trying to upload the stage 2 base map and stage 1-2 parameters.
Shabib67 is offline   Reply With Quote
Old 02-09-2006, 04:17 PM   #2
x99percent
Member#: 27108
2004 STi
2004 A4
Sounds like your connection settings aren't quite right in HyperTerminal... what do you have them set to?
x99percent is offline   Reply With Quote
Old 02-09-2006, 04:24 PM   #3
Shabib67
Member#: 61749
what is on the instructions. Its just weird, i mean how can all the other functions work but not the map editor?
Old 02-09-2006, 04:59 PM   #4
Freon
Member#: 88322
2009 BMW 135i
That is odd. If your hyperterminal settings are wrong it shouldn't work at all.
You could try reflashing the firmware, or else I'd try to talk to TXS and see what they have to say.
Freon is offline   Reply With Quote
Old 02-09-2006, 05:13 PM   #5
x99percent
Member#: 27108
2004 STi
2004 A4
What does it say at the bottom of the HyperTerminal window... next to where it says "Connected" or "Disconnected" at the bottom left?
Definitely a possibility.
Old 02-09-2006, 05:48 PM   #6
Lost_Pete
Member#: 100570
Sounds like the maps have been corrupt. Reflash the UTEC with the latest firmware and start again.
regards
Pete
Lost_Pete is offline   Reply With Quote
Old 02-09-2006, 06:17 PM   #7
Shabib67
Member#: 61749
^^^ill try that thanks for the advice.
Hypterterm/utec problem Shamr0ck Engine Management & Tuning 1 01-02-2004 12:18 PM
Major Utec Problems, Please Help! rexmobbin' Engine Management & Tuning 9 12-16-2003 11:39 PM
Utec problem- car won't start V REX Engine Management & Tuning 0 09-06-2003 10:44 PM
Attn: Phil @ TXS major Utec problems/knocking someone please help Jay04WRX Engine Management & Tuning 66 08-02-2003 03:22 PM
UTEC Problem Veck Engine Management & Tuning 14 10-14-2002 10:50 PM
