Old 02-09-2006, 03:40 PM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default LGT turbo swap problems
I'm swaping an MY05 LGT engine and tranny into an MY97 impreza L.
The problem I have encountered is that the Legacy gets it's vehicle speed from the ABS and it looks like it transfers it to the ecu via the CAN. My vehicle has no abs.
The tranny has a bolt in the hole where the mechnical speedo goes but when removed there is nothing there. Before I knew there was nothing behind the bolt I was planning on either seeing if the Legacy ecu could be flashed to use the electrical signal for vehicle speed sent back from my gauge cluster or to use an STI or Forester ecu because the use vehicle speed signal and the pinouts are pretty much identical minus and plus a few things.
Any ideas for how to solve my problem?
How important is vehicle speed to the ecu?
If it's not important what other options are the for a speedometer.
I'm going to post in tranny about the posibility of cracking open both my L tranny and the Legacy and retrofiting the mechanical parts for the speed sensor.
Thanks Joshua
P.S. I don't want to use the L tranny because the second gear syncros is gone and it's paired with an open rear diff.
yebokmj is offline   Reply With Quote
Old 02-09-2006, 08:03 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i have pondered this for some time befor you started your swap
cracking the case might work i have no idea what you will find in there though that +using a 04 fxt/sti/baja xt and electric vss
even the old (ej20G) ecus look at the vss (its simmilar to hitting boost cut) i think its a saftey feature in realation to the top mount intercooler
Old 02-09-2006, 09:00 PM   #3
yebokmj
Member#: 2213
Brilliant Red
what do the ecus look at the vss for? Is it just as a govener for the speed or is it used for other readings as well.
Joshua
Old 02-09-2006, 11:39 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i suspect it is protection from intercooler heatsoak
1 factoid that cobb gave at his open house years ago is that the wrx turns off the radiator fans at 60 mph
wondering if the ecu dosn't limit boost in lower gears too
why don't you email trey and ask him?
Old 02-10-2006, 10:47 AM   #5
yebokmj
Member#: 2213
Brilliant Red
I sent them an email. I hope they get back to me.
Joshua
Old 02-11-2006, 11:32 AM   #6
yebokmj
Member#: 2213
Brilliant Red
Default solution?
I believe i found a solution. I looked at switching the mechanical from the tranny over and that's to much work I'm not feeling the whole cracking the tranny thing. So I found these two things: Speed Sensor
This Next Unit will allow me to send the proper signal to the gauge cluster that should be coming from the ABS computer. All I need to do is find out what that signal is. Any help here would be great.
Thanks,
Joshua
Old 02-11-2006, 01:00 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
that might work for the speedo the data format input should be in the fsm
still think the ecu is gonna be pissed off that there is no abs/speed/??
Old 02-11-2006, 01:07 PM   #8
yebokmj
Member#: 2213
Brilliant Red
I'm sure it's in the FSM but where it's really hard looking through all those computer files vs. a book. The ECU gets it's speed from the gauge cluster via the can as far as I can tell, so if I'm giving the speedo the proper signal the ecu will be happy as well.
Joshua
Old 02-11-2006, 02:44 PM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
your going to use the lgt cluster .. cool
Old 02-11-2006, 09:20 PM   #10
yebokmj
Member#: 2213
Brilliant Red
Yeah LGT gauge cluster, I don't see that I have a choice. Though it won't match my Greddy gauges
Joshua
Old 05-22-2006, 11:29 AM   #11
Kaymin
Member#: 96076
RIP 96 SBM GC8
05 Burnt Orange Evo
Take lots of pictures!!! I'm thinking of doing the same swap
If the car i start with has ABS will i have the same problems? Besides the axels
Kaymin is offline   Reply With Quote
Old 05-22-2006, 07:07 PM   #12
yebokmj
Member#: 2213
Brilliant Red
Do a search for more infor the swap is long done and running. I would asume you would have the same problems even if you have abs because your ABS system isn't setup to be used for a VSS and probably will never give out the right signal. I ended up using the LGT harness and switching a few things so I could use and STi ecu. I am going to be using a Hall Effect speed sensor for VSS.
Joshua
05' LGT trans swap - Speedo Gear Problem morrocco88 Transmission (AT/MT) & Driveline 45 02-13-2013 12:01 PM
LGT swap PROBLEMS? lsaltsman Transmission (AT/MT) & Driveline 0 06-14-2009 10:09 PM
Turbo swap problem, random extra gasket? The Satch Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-09-2008 07:23 PM
turbo swap problems 18aspenSTi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-22-2008 04:39 AM
2.5 Turbo Swap Problems Speedy7_7 Subaru Conversions 0 02-22-2007 10:41 PM
