Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 02-09-2006, 07:40 PM   #1
03mbpREX
Member#: 33953
2011 WRX
Default Getting Protuned, help me prepare
im going to get my 06 wrx protuned next month. I have stage 2 right now. I have full turboback, and headers. Is there any parts that I should get now before I get protuned to make the most out of it. like intake , pulley, hoses, etc.... I want to make the most out of my stage 2, so what parts will I make some power with besides my headers and turboback
03mbpREX is offline   Reply With Quote
Old 02-09-2006, 07:43 PM   #2
hondaeater69
Member#: 60324
Tmic Ftw.
Old 02-09-2006, 08:09 PM   #3
03mbpREX
Member#: 33953
2011 WRX
what kind? I dont wanna spend alot of money on one. are the ebay ones worth it? if so which one? or is an sti one just fine.?
Old 02-09-2006, 08:49 PM   #4
hondaeater69
Member#: 60324
skip the STi, Ebay, or used name brand ftw.
Old 02-09-2006, 09:13 PM   #5
mpower22
Member#: 58352
04 20G STI(SOLD)
08 z51C6 (growing mullet)
http://www.projectwrx.com/modules.p...showpage&pid=35
once you have your parts....MAKE SURE TO GO THROUGH THIS CHECKLIST....
really things you should do anytime you tune a car......
mpower22 is offline   Reply With Quote
Old 02-09-2006, 09:34 PM   #6
Geeoff
Member#: 106439
06 WRX TR
'05 Matrix XRS
^Link not working
Geeoff is offline   Reply With Quote
Old 02-09-2006, 10:34 PM   #7
mpower22
Member#: 58352
04 20G STI(SOLD)
Old 02-09-2006, 10:45 PM   #8
titsataki
Member#: 4402
2009 Outback XT
this sounds like a golden rule list.
titsataki is offline   Reply With Quote
Old 02-10-2006, 10:05 AM   #9
BigJ04STi
Member#: 77239
2004 Impreza WRX
None
If you're gonna spend the money on tuning... why not add a few more power adders. The tunng charge will be the same either way, but in the end you might be happier with your tune and never want another...
Otherwise... you get tuned on the header and turboback, and decide later on to add a TMIC, Intake, turbo inlet, etc etc... and need to get retuned again.
BigJ04STi is offline   Reply With Quote
Old 02-10-2006, 11:10 AM   #10
markuswelby
Member#: 82379
2005 KWIK WRX
WR BLUE
Could not agree more!!! I got my 05 WRX Protuned about 5 months ago and am now putting on a VF39 and dare not drive my car for more than a few days without getting another Harman tune. This time i did even more homework tho.
i would also be careful of headers, they do give more power but u will lose more bottom end.
markuswelby is offline   Reply With Quote
Old 02-10-2006, 12:35 PM   #11
Tanj!
Member#: 9339
2005 Forester XT
80, 86, 87, and 88 RX-7
Big +1 for the top mount. It's the only thing I didn't do before my protune that I know regret with the 2.5L and the TD04. Without it you will max out at around 13psi on the TD04. With it Jarrad from PDX said 15psi is achievable. If you have any thought that you might want an intake get it done too. Intakes can/do change the maf readings and your tuner can fine tune this when he is doing your car. If you want a CAI i'd suggest tracking down one the older non 65 APS black CAI's since they flow more air. You however shouldn't put it on the car right before you're ready to tune since it's not the correct size for factory. I'm going to assume that your headers replaced/removed that cat in your uppipe. If not I'd suggest that too. Also talk to your tuner about spark plugs and if they recommend going one step colder. Jarrad said I could go one step colder and get some advantage but not full advantage b/c my setup wasn't going to push it that hard. Some tuners like the one step colder plugs others don't. Best to pick your tuner's brain on that. Pulley’s hoses and other misc things like that aren’t going to make such a radical difference that the ECU can’t learn for them. The three biggies though are the top mount, intake, uppipe, and plugs if recommended. You also might want to think long and hard about spending the money on a VF39 for the “STI” upgrade. I decided to skip that part since I knew I would ultimately jump to a bigger turbo than that and the TD04 tuned for the moment was worth the money.
Don't worry about the headers. On the 2.5L motor with that tiny td04 you have insta spool anyways and should have nice torque. Here is my dyno sheet. I think you will be happy with your protune once you get it done.
Tanj! is offline   Reply With Quote
Old 02-10-2006, 01:22 PM   #12
markuswelby
Member#: 82379
2005 KWIK WRX
WR BLUE
HA HA, yea, i am one of those unlucky fools that has an 05 WRX and has to live with under 300whp... that is ok, there are worse things.
Old 02-10-2006, 01:40 PM   #13
blinguskahn
Member#: 39301
STi 05 8cm FPRed
WRX 06 Blue FP20G
Get a VF-34/39.
blinguskahn is offline   Reply With Quote
Old 02-10-2006, 04:26 PM   #14
03mbpREX
Member#: 33953
2011 WRX
theres many ebay tmic's how do I know which one is the better one?? I was thinking of adding cobb sf intake, pulley, and ic hoses before I get tuned, are these parts worth it??
Old 02-10-2006, 04:29 PM   #15
markuswelby
Member#: 82379
2005 KWIK WRX
WR BLUE
Originally Posted by blinguskahn
Get a VF-34/39.
Exactly what is sitting in my office. Have the Walbro and pinks at home...
just need to buck up for the install and the tune...
on CA pump i will probably still be under 300whp tho. I figure if i can break into the 12s on my car i will be all kinds of happy.
Old 02-10-2006, 04:45 PM   #16
03mbpREX
Member#: 33953
2011 WRX
is the tmic on ebay, one by ssautochrome the one everyone says is good, or the one by x02 racing the one thats better?. If so can both these intercoolers fit the stock Y pipe?
http://cgi.ebay.com/ebaymotors/Turbo...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/02-04...QQcmdZViewItem
Old 02-10-2006, 05:22 PM   #17
dankster
Member#: 54592
You might want to get an upgraded boost control solenoid. I've read you can get faster spool that way. Perhaps someone more knowledgeable can explain.
dankster is offline   Reply With Quote
Old 02-10-2006, 05:55 PM   #18
Tanj!
Member#: 9339
2005 Forester XT
Originally Posted by 03mbpREX
Good that you brought that up I'd forgotten about that. We basically get the shaft and none of the WRX or STI y-pipes work for us (2.5L w/ TD04). Either you will need to get a specific y pipe OR be prepared to cuss a bit with silicon hoses to get things to fit correctly. I don't know the specifics off the top of my head not having done it yet but I do know neither of those (or any other top mount) is a direct drop in for us unless they specifically say they will fit the FXT/06 WRX. Also the recirc valve is different on our cars from the WRX and STI so you need to either get another recirc/bov or switch to the STI/WRX fitment along with the appropriate hoses.
*edit* A quick look around indicates that Gruppe-S might have an FXT fitment kit available for top mounts. Might be worth calling them to source the correct parts for fitment. *edit*
Old 02-10-2006, 07:59 PM   #19
GTSJOE
Member#: 77490
05's STI WRB
STI White
pm,d you about a perrin tmic w/ bov
GTSJOE is offline   Reply With Quote
Old 02-10-2006, 08:00 PM   #20
GTSJOE
Member#: 77490
05's STI WRB
STI White
you should also get a light weight crank pulley not a underdrive
Old 02-10-2006, 08:58 PM   #21
03mbpREX
Member#: 33953
2011 WRX
whats a good lightweight pulley to get, also im gonna order the x02 tmic, will the stock BOV fit?, ive been searching but coming up empty.
NE Area Protuners - Help me out guys :) krisco New England Impreza Club Forum -- NESIC 2 05-28-2007 10:01 PM
Help me prepare for a job interview OT! jacobsen1_ Off-Topic 27 04-25-2007 03:45 PM
OT programmers - help me prepare for a job interview on monday morning maaw Off-Topic 5 05-16-2005 09:39 AM
I gotta get this!!!!!! Help me locals!!!!!!!! MK19_ South East Region Forum 15 04-28-2004 05:19 PM
help me prepare a speech marioej18 Off-Topic 15 03-24-2004 07:11 PM
Message Board Statistics All times are GMT -4. The time now is 07:55 AM.
