Old 02-09-2006, 10:15 PM   #1
kn0bby8
Member#: 97644
2006 WRX
Default Cel
Flashed a p0244 once yesterday and again today. After some reearch I have come to the conclusion that I need to get the LWG map. (I am using AP)
Where can I find the LWG map for my 2006 5MT WRX?
I am not sure becasue I haven't found the map but I am led to believe that it is a real time map. Fom what i understand base maps are better. Are they?
Will this map casue me to lose some performance over the regular stage 2 93 octane base map?
kn0bby8 is offline   Reply With Quote
Old 02-09-2006, 10:42 PM   #2
hondaeater69
Member#: 60324
I would call cobb, you should NOT be getting that code. I don't believe there is a LWG map available for the 06's yet. How much boost are you getting?
Old 02-10-2006, 04:32 PM   #3
kn0bby8
Member#: 97644
2006 WRX
I just got off the phone with cobb. Basically they told me to clear the code and see if it happens again. They told me the way i was driving the car when it hapened (wot 5th gear low rpm) was putting to much load on the car. Said that turbo motors aren't meant to be driven like that. Hope it don't happen again.
Can anyone explain what they mean by putting to much load on the car means? I have an idea but not sure if its correct.
Old 02-10-2006, 05:10 PM   #4
kn0bby8
Member#: 97644
2006 WRX
I was driving with the AP and monitering boost in 5th gear wot i got 17.6 it might have even climbed higher but i let off the gas. I should not be boosting that high right?
Old 02-10-2006, 05:14 PM   #5
WRC51
Member#: 16373
The more throttle you put down, the more boost you will see (to a certian point) If your straining the motor too much (legging) the motor that's not good for any motor.
For example - -Instead of WOT in 5th @ 80 KPH, downshift to 4th or 3rd...easier on the motor.
WRC51 is offline   Reply With Quote
Old 02-10-2006, 05:17 PM   #6
hondaeater69
Member#: 60324
yea that's too high for that motor/turbo combo.
You need to learn around driving with a turbo. Instead of just romping on the gas at low RPM, ease into it to let the boost control actually control the boost.
0136 CEL w/ Pony Express CEL "fix" lstepnio Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-17-2003 04:26 PM
Anyone with Borla header and CEL, did the ECU recall fix the CEL? Suba_Roo Normally Aspirated Powertrain 14 01-25-2003 12:53 AM
gutted uppipe, cel or no cel? recursian Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-17-2002 03:57 PM
Wierd Cel after ECU Reset, installed TurboXS TMI, No Cel in Log DiMensionX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-13-2002 08:19 PM
CEL or no CEL? chuglobal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-25-2002 03:23 PM
