Old 02-09-2006, 11:03 PM   #1
MixeD_MenacE
Member#: 1274
MY00 BRP 2.5RSTi
www.zucru.ca
Default EJ257+Exedy Organic+Stock RS trans = Boom?
I need some help with my conversion. I've sourced out an EJ257 and will be going with it. Will an exedy stage 1 organic and stock RS transmission/drive train hold up to the new motor? I understand there's probably a safety factor of 3-4 built into the stock box (w/ stock n/a engine)..unfortunatly the safety factor goes down once more power is added.
The ultimate goal is a 6spd but my budget is limited for this year (possibly next year the new trans will go in)
I've had a clutchmasters stage 3 suggested to me as a replacement for the exedy.
The car is my auto-x car/daily driver. No drag racing for me.
Thoughts?
SC
#31 DSP
Winnipeg Sports Car Club
MixeD_MenacE is offline   Reply With Quote
Old 02-09-2006, 11:06 PM   #2
amukaoen
Member#: 62595
04 WRX Cobb S2
World Rally Blue
BOOM~!
the STi has a really strong transmission for a very good reason!
amukaoen is offline   Reply With Quote
Old 02-09-2006, 11:10 PM   #3
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
powerlabs still uses his stock rs tranny with his RA swap...
svek is offline   Reply With Quote
Old 02-09-2006, 11:32 PM   #4
MixeD_MenacE
Member#: 1274
MY00 BRP 2.5RSTi
www.zucru.ca
i've been getting the hit or miss with this issue. I believe Kotir is also running a stock trans with his V8 twinscroll set up
Old 02-10-2006, 12:17 AM   #5
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
svek bet me to it. Powerlabs and others have put alot of power through a stock RS trans. Shift easy and no launching.
Scoobie Steve is offline   Reply With Quote
Old 02-10-2006, 12:57 AM   #6
moss
Member#: 10197
Alot of people are using RS trannies... just be gentle like everyon said... you slam gears, that tranny is toast.
keith
moss is offline   Reply With Quote
Old 02-10-2006, 12:58 AM   #7
MixeD_MenacE
Member#: 1274
MY00 BRP 2.5RSTi
www.zucru.ca
hmmmm i wonder if powerlabs can chime in...kotir too??
*wave*
Old 02-10-2006, 01:00 AM   #8
moss
Member#: 10197
I'll add this though... Soon2bgreat was running a stock RS tranny on a V7 motor, and that clutch (upgraded) slipped like a MOFO. the car was pretty worthless above 5k in most gears (esp 5th)
Old 02-10-2006, 01:26 AM   #9
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
the stocker will be fine...how much power are you looking to put down?...that is the true question...how much torque?...
if you get a lot of power, your clutch will slip...or so goes the plan....it adds a factor of safety...
Old 02-10-2006, 05:53 AM   #10
Kotir
Member#: 17300
1993 Widebody Wagon
748whp e98
I toasted the organic Exedy Street RS clutch with like probably 10 good launches with the Ver8 Swap Although I did run it on the RS-T (12psi T3 on stock RS motor for like 20k before that)
Added 6 puck sprung friction disk to the Exedy street pressure plate
Worked for awhile before I decided to beat the crap out of it
I didn't break a gear, but it'll pop out of 1st if I rev and try to launch it...
Not sure if it was the 10 or so AWD burnout launches I did on the drag strip before that or the flatfoot shifting... who knows
I think with an organic non puck clutch + some common sense it should last for awhile atleast
I'm only made like 240tq on a Mustang dyno - EJ257 should be good for quite a bit more
I'm still driving on the RS tranny that grinds going into any gear but reverse, likes to pop out of 1st and 2nd gear, and sounds like a jet landing according to my friend. 120k miles (about 40k with nitrous, turbokit or STi swap but all abused) I think it'll probably give up soon
-Tim
Kotir is offline   Reply With Quote
Old 02-10-2006, 08:30 AM   #11
XENONSVX
Member#: 41719
XT, SVX, JUSTY &
GF8 STI V4 RA
I've got a 6 puck ceramic clutch disk w/ my stock L pressure plate & flywheel, running my stock L trans...no problems yet
My buddy has a wrx w/ a lil over 80k on it, still the stock trans w/a 2.2 hybrid...
Just leave your stock trans, dont drive it like a jackass and it'll stay around for a while
XENONSVX is offline   Reply With Quote
Old 02-10-2006, 12:33 PM   #12
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
Like others said... the stock RS/TS tranny is fine. I am at 330whp with my version 7 swap and have been running it for over 2 years and 22,000 miles.
BTW, I started out with the Exedy clutch but it slipped so bad... even with the motor stock (280-ish fly-whp) so I went with a SPEC cerametallic clutch and it holds up great.
Kreeger is offline   Reply With Quote
Old 02-10-2006, 12:55 PM   #13
MixeD_MenacE
Member#: 1274
MY00 BRP 2.5RSTi
www.zucru.ca
sounds like the stocker should work out fine for atleast this season of auto-x. This year the motor will remain relatively stock (except for exhaust and possibly up pipe). No plans for power upgrades until the driveline gets redone.
more thoughts people? I really appreciate the help! I'm anxious to show you guys what I've been up to this past while.
Old 02-11-2006, 05:07 AM   #14
Skully
Member#: 48990
98 Impreza RS
RBP
Im running a 2000 Legacy GT tranny in my 98 RS. My old turbo kit i made 320awhp @ 16.5psi of boost. Since then i have refabbed a new up/down pipe and the car has ALOT more torque now. I will be taking it to the dyno soon i hope. Im running a Spec Stage 3+ clutch. The clutch is rated @ 525 ftlbs. and holds awsome. No tranny problems as of yet.
-Thomas
Skully is offline   Reply With Quote
Old 02-12-2006, 05:20 PM   #15
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
My tranny is still alive with over 160,000 miles. It's got to give up the ghost soon.
RS_to_WRX_swap is offline   Reply With Quote
Old 03-03-2006, 03:13 PM   #16
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
I broke my tranny twice. The first time the 5th gear hub nut backed off. There was a service bulletin out on it but I didn't make it to the dealership.
Second time I sheared off all the teeth in 2nd gear shifting hard. This was on the stock 2.5L engine.
I have about 18000 miles on the swap and have managed a 0-60 time of 4 seconds flat and a 1/4 mile of 12.6 @113 with a full tank and a passenger on the stock tranny and a Spec Stage 3 6 puck kevlar clutch. The turbo motor isn't as bad on the tranny because it doesn't make as much torque off boost or down low, but I am looking at upgrading soon; I know it won't last forever. Subaru transmissions are crap. But if you baby them, they'll hold. For me keeping the stock tranny was simply a money issue.
powerlabs is offline   Reply With Quote
Old 03-03-2006, 04:55 PM   #17
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
My 2 cents is to stay away from pucked clutches if sticking with your stock tranny. Those suckers put one hell of a load on the tranny. I personally would rather have the clutch slip at the limit more than my gears slipping.
I work for a Porsche tranny shop, and the one thing we see more often than anything else on high powered cars is downshifts damaging the trannies. With a high powered car and some wide rubber, downshifting into 2 or 3rd gear and hitting 7000rpms is one hell of a shock load on the system. So, in addition to the advice about not launching, feather your downshifts as well...
Old 03-03-2006, 10:54 PM   #18
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
dont slam the gears. and ease on the throttle. those will help alot. NO AWD burnouts. if you feel you got beaten by that honda real bad, ask him to follow you on the twistys....
Old 03-04-2006, 12:58 PM   #19
Slack
Member#: 17548
An exedy organic should be fine. The pressure plate only has 29% more clamping force, so with proper shifting and clutch work your stock transmission should last you long enough to get that 6mt you're slobbering over.
Mick
Slack is offline   Reply With Quote
Old 03-04-2006, 04:43 PM   #20
sheepdog
Member#: 93773
1995 Flat Khaki GC8
2011 STi Wagon
My buddy blew 2nd in his stock RS trans with an EJ20G pretty stock, autocrossing.
sheepdog is offline   Reply With Quote
Old 03-04-2006, 10:39 PM   #21
powerlabs
Member#: 45790
SUPERCHARGED
Mick
I will have to disagree with that. My Exedy organic didn't last a month post swap, and I never launched the car a SINGLE time with it.
I think it would be ok for a bone stock US WRX swap, and that's about it.
Old 03-05-2006, 08:22 AM   #22
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
+1... My Exedy clutch would slip anytime I got on it at all. I remember once (less than a month after my swap) I was at a light and wanted to get the jump on traffic because the lane merged ahead. When the light turned green, I revved to about 3k and slipped the clutch but DID NOT drop it. It slipped so bad, the car just sat there as I revved... the clutch fully out... I was barely moving.
YES, the clutch was adjusted properly (by a master Subaru mechanic of 20 years... the same guy who did the swap) and my version 7 motor was still at the stock, untuned power level. The main component of the clutch's failure to hold power is that the pressure plate pressure rating is frikkin wimpy as hell. You want something like 2300lb clamping force and up.
Go with an ACT clutch. They have the best PP for the RS tranny. Even my SPEC clutch slips now from time to time.
FS SoCal: BNIB Exedy Organic, slightly used Exedy Organic, slightly used OEM Flywheel Lazyxturb0 Drivetrain 36 09-12-2008 09:45 PM
ver 6 sti trans + stock 2.5 RS trans gear swapping questions. pearl Transmission (AT/MT) & Driveline 0 02-26-2008 07:09 PM
Exedy organic clutch scoobyimprza Private 'For Sale' Classifieds 1 12-14-2003 01:54 PM
FS: New Exedy Organic Clutch Kit teiva-boy Private 'For Sale' Classifieds 5 12-04-2003 02:11 PM
Exedy organic clutch slip Mikanical Transmission (AT/MT) & Driveline 8 10-23-2003 11:26 AM
