Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 02-09-2006, 11:52 PM   #1
yakkosmurf
Member#: 81931
2008 STI (Stage 1)
WR Blue Mica w/ Gold BBS
Default Which AP map to use on my trip tomorrow
I'm driving around 350 miles tomorrow (all highway), and I'm debating about using the economy real time map over the Stage 1 93 octane. Any suggestions or experience? I might try one map on the way there and another on the way back on Sunday. It's also going to be raining tomorrow, so I don't think I need the highest performance for the trip.
yakkosmurf is offline   Reply With Quote
Old 02-10-2006, 12:39 AM   #2
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Once you are on the highway cruising, doesn't make a difference.
mcowger is offline   Reply With Quote
Old 02-10-2006, 12:41 AM   #3
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
both. let us know how it turns out.
Bishop is offline   Reply With Quote
Old 02-10-2006, 01:17 AM   #4
MBasile
Member#: 86997
2002 Impreza WRX
yeah...let us know. I'm getting Protuned on the 20th and have to drive 175 miles for it! I want to know if driving back in econo will make a difference. also (kind of a thread hijacking..sorry) does your MPG go up after getting a tune since you dont run as rich?
MBasile is offline   Reply With Quote
Old 02-10-2006, 01:29 AM   #5
Striker13
Member#: 84776
MY03 Impreza WRX
MBP
the STX one
Striker13 is offline   Reply With Quote
Old 02-10-2006, 12:35 PM   #6
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
It can....depends heavily on the tune.
Old 02-10-2006, 01:16 PM   #7
OtisCole
Member#: 80959
2004 WRX - Cobb stg2
If I stayed out of the boost, my stg 1 93 got just about the same mpg as the economy (85 mile hwy round trip commute). It's just a matter of discaplining the foot (not easy!). But a longer trip might show the benifits of the map better.
OtisCole is offline   Reply With Quote
Old 02-10-2006, 01:50 PM   #8
MBasile
Member#: 86997
2002 Impreza WRX
I think since on highways you do generally get MPG's, theres not much of a difference between a staged map or the econo. Its in the city and on the twisties (I live on a twisty road) where you use a heavy foot to get going (after the light or after the turn)
Old 02-10-2006, 01:53 PM   #9
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
I'd reccomend waiting till yor actually on the freeway to load the realtime economy map.
placing the car under load (driving the car hard in any way)wouldnt be a good idea. Thats somthing to keep in mind.
You could read the map notes on the download page to know it's specific limitations.
Ya, Lets us know the diffirence.
parker/slc/gc8fan is online now   Reply With Quote
Old 02-10-2006, 03:57 PM   #10
hondaeater69
Member#: 60324
i would personally skip the econo map. LIke parker said, if you have to get on it be careful (it runs more timing than normal). Just stay out of boost.
hondaeater69 is online now   Reply With Quote
Old 02-10-2006, 11:10 PM   #11
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
also remember to stay in your torque band. Look at your boost gauge and find the rpm that gives it the lowest reading on the gauge while cruising. I have noticed above 3k or around 85mph has provided the best fuel economy. and that was on my heavy 18" prodrives and stock ecu with no EM. I ended up getting about 26mpg on my way from TX to florida. These numbers have changed since EM due to the powerband moving left.
Good luck though and have a safe trip.
scoobdude is offline   Reply With Quote
Old 02-10-2006, 11:11 PM   #12
eyehate
Member#: 10223
I noticed 4 to 5mpg cruising on the hiway in econ vs stg II.
eyehate is offline   Reply With Quote
Old 02-11-2006, 12:17 AM   #13
pudnana
Member#: 89071
2000 Blue 2.5 RS
2004 Java WRX
I used the ECONO map on mine driving down from Flagstaff to Phoenix and back up. On the trip down I got 30.75 mpg or something like that, and up the hill i got 22 mpg on ECONO, seemed better than normal stage 2 driving, but that could be due to I didn't drive like a mad man like I normally do on stage 2.
pudnana is offline   Reply With Quote
Old 02-11-2006, 03:16 AM   #14
multiplexer
Member#: 39518
Stick to the performance map. I feel much safer knowing that I could get out of the way in the rush if I need to; you never know when some a**hole might cut you off.
multiplexer is offline   Reply With Quote
Old 02-12-2006, 02:21 AM   #15
carrman
Member#: 69137
2007 2.5i Outback
1966 Chrysler 300
Ran 160 miles, over 5 mountain passes that were 6 percent, and managed 26.8 mpg on stage 2. 75 mph during the whole trip.
carrman is offline   Reply With Quote
Old 02-13-2006, 03:01 PM   #16
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I have used both the stage 2 and econo map and found almost no difference. i went through 4 tanks of gas on the econo map, mixed highway/city driving, staying off of it as much as possible and only gain .5mpg average per tank. I determined it wasn't worth the lost horespower.
Old 02-14-2006, 02:19 AM   #17
wombat1
Member#: 62649
02 Popcan
Humus Brown
I once used the economy map on the way to a track (200 miles or so), and spaced it. After running a couple warm ups I gave her the berries for a lap or two, then oops! Remembered the map and switched it to stg 2. There was no audible knock or ill effects. I don't think you need to be too worried about taking it easy, and you can certainly drive on boost with econo mode. Just use it when driving "normal."
wombat1 is offline   Reply With Quote
Old 02-14-2006, 09:58 AM   #18
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Yes you could do that on the older econo maps and not notice much of a difference in performance loss. But on the new econo map ...it sucks max boost of 7 PSi even when flored doesn't work for me. I just keep it in stage 2 all the time with no loss (very little) of fuel economy as compared to the economy map.
wrxdrvr is offline   Reply With Quote
Old 02-14-2006, 10:02 AM   #19
gusto
Member#: 58323
i did this on a trip from boston - stlouis & back and i lost mileage going to eco from stage II
had all the receipts at the time, i thought i posted up the info, but this was a year and a half ago now so i dont know where i put all that stuff. ill see if i can find a post regarding this.
just leave the car as-is since the computers happy and changing to eco map is 100% pointless when driving long distance.
gusto is offline   Reply With Quote
Old 02-14-2006, 12:45 PM   #20
wombat1
Member#: 62649
02 Popcan
Humus Brown
Measuring fuel econmy to and fro is not at all a legitamite comparison. I went on a road trip of 500 miles round trip, economy map there, stg 2 back. Results? 26 mpg on economy, 22 mpg on stg 2. The catch: Decrease in elevation going there, climb coming back. Even though I used the maps as a fuel consumption test, the resulting figures were useless. If anything, the low boost of the economy map is less strain on the motor, and it is still as powerfull as a typical commuter car. The extra off boost responsiveness is nice too.
Old 02-14-2006, 10:36 PM   #21
deejai35
Member#: 60131
2002 WRX Sport Wagon
WR Blue
I too have watched economy vs. stage 2 or in my case VF34 map. On highway trips I have not noticed much of a difference. It definitely matters in city driving.
deejai35 is offline   Reply With Quote
Old 02-22-2006, 10:17 AM   #22
yakkosmurf
Member#: 81931
2008 STI (Stage 1)
Sorry for the delay in update, but here are the results. On tha way to New Orleans, it was really warm, and I ran the A/C the whole way. I got almost 28 mpg while cruising on the highway around 70-75 mph. On way back, I was going to use the Stage 1 map, but the weather had changed dramatically. I decided it wouldn't be an accurate test given the different conditions, and the fact I wasn't going to be running the A/C compressor. So, I ran w/o the A/C on the way back and got not quite 30 mpg (29.7xx). I'm impressed. I normally get around 24-26 mpg on Stage 1 with my mix of highway and city driving.
I was also surprised that the car didn't drive different on the econo setting when driving normally. It wasn't as bad I was expecting.
Old 02-22-2006, 10:38 AM   #23
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
driving niceley on cobb's vf34 map gained more milage/tank than on the econo map.
i usually keep it in fourth though and use less throttle to maintain its speed than in 5th gear.
psyber_0ptix is offline   Reply With Quote
Old 02-22-2006, 04:57 PM   #24
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
yakko, Maybe you should say what map you were using.
Old 02-22-2006, 09:52 PM   #25
mistermike3
Member#: 102640
02 RA+ewg18G+C16
= pure pleasure
just a question, I am running the vf34 , sti inj. mode and first, getting horrible gas mileage, but I amd getting a protune in a week, see if it makes a difference. Also, wont driving at 85 mph for 5 hours (highway) just pointelessly wear out your turbo? THanks
mistermike3 is offline   Reply With Quote
which UTEC map to use? Re-Volt Engine Management & Tuning 10 12-28-2005 02:49 PM
Which utec map to use fosgate769 Engine Management & Tuning 3 02-25-2005 01:44 PM
Which factory Subaru oil filter to use on my 2002 WRX gsodonis Service & Maintenance 2 10-02-2003 02:20 PM
what jets sizes to use on my nitrous oxide wet kit STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-22-2002 09:29 AM
