Old 09-20-2001, 07:57 PM   #1
Ripper
Member#: 7774
Question My check engine light is on but car is running fine.
Hi people. I just was wondering, my check engine light turned on 3 days ago in my 98 RS. My car is running fine and I have no clue what it could be. I've heard before that our model RS's have problems with the check engine light, but I was hoping someone would reassure me or tell me that info is wrong. Anyone have any ideas as to what the problem is? Someone I know though it may be my O2 sensor, which i know nothing about. Any help would be great. Thanks.
Ripper
Ripper is offline   Reply With Quote
Old 09-20-2001, 08:01 PM   #2
yuzo
Member#: 9197
ahhhhh is it still on warranty? if it is then take it in. try checking your oil and see if your gas cap is screwed in good. i've heard lights going on because of this.
yuzo is offline   Reply With Quote
Old 09-20-2001, 09:41 PM   #3
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
do u have any mods?
KillerTHC is offline   Reply With Quote
Old 09-21-2001, 06:34 AM   #4
Sweder21
Member#: 9099
2000 Impreza 2.5RS
BRP
I have a MY00 2.5 and the check engine light has come on again. I have no mods and the last time this happened the diagnostic computer said it was with the fuel. Mine started when I switched from 87 to 91 octane. I wouldn't be too concerned with it as long as you aren't hearing any irregular noises coming from the engine. But make sure you get it checked out just to be safe.
Sweder21 is offline   Reply With Quote
Old 09-21-2001, 09:48 AM   #5
RacerinLSL
Member#: 1174
2011 Subaru WRX
Sweder21 -
My '99 did the same thing. The dealership instructed me to switch back to 87 and I no longer have a problem. Supposedly our engines do not create enough heat energy or BTU's to burn off 91 or higher octane causing carbon buildup and throwing a P170 CE light(fuel trim malfunction). I had never heard this before, but so far, they were right.
Chad
RacerinLSL is offline   Reply With Quote
Old 09-21-2001, 03:01 PM   #6
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
Mine used to come on in stop-n-go traffic... One day when it threw I turned the car off, went out and took off the gas cap, replaced it, got back in and turned the car on. The light has never come on since. I don't know if I just got into a bad gas cap replacing habit after a while or what. Or maybe the bulb burned out!
iodine23 is offline   Reply With Quote
Old 09-21-2001, 03:56 PM   #7
SubaFastR
Member#: 5786
Mine came on when I installed an Apex ITC. With the ITC I am able to advance the timing 4 degrees with the use of 91 octaine. What a kick in the ass! My car pulls so hard now. Also, when I use the nitrous, I'm able to retard the timing a degree or two.
Kevin
SubaFastR is offline   Reply With Quote
Old 09-21-2001, 04:12 PM   #8
soob2k
Member#: 567
i have a 2000 rs and had a check engine light... it was the fuel sender that had gone bad. had it replaced yesterday. 36000 in 2 years!!! is that a lot?!?!?
soob2k is offline   Reply With Quote
Old 09-21-2001, 04:14 PM   #9
SubaFastR
Member#: 5786
That's pretty normal mileage, mine has 25,000 in 11 months.
Kevin
Old 09-21-2001, 04:17 PM   #10
Ripper
Member#: 7774
Thanks for all the help guys. I think I'll give those things a try. I have no mods as of yet, but I run 93 octane gas just because thats what I feed all my cars. That may be the problem, but I would've never guessed paying for better gas would cause more problems.
Old 09-21-2001, 04:23 PM   #11
SubaFastR
Member#: 5786
Unless your car is detinating or pinging, you are just throwing money away. The gas isn't cleaner or anything, it is just harder to set it on fire, so to speak.
K
Old 09-21-2001, 04:41 PM   #12
Julian
Member#: 1182
MY00 RS
BRP
Concur with what SubaFastR said.
Just drop by a dealer and have them pull the code. Easy way to find out if it is anything to worry about. It "should" be a quick pop in...any monkey can run the scan tool they use. Takes but a minute.
Julian is offline   Reply With Quote
Old 09-22-2001, 01:03 AM   #13
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
Is there a scan tool that we can buy cheap, like they have for fords and chevys?
janikphoto is offline   Reply With Quote
Old 09-22-2001, 11:25 AM   #14
Rick G
Member#: 3122
Default For scan tool search OBD-II
Rick G is offline   Reply With Quote
Old 09-22-2001, 12:16 PM   #15
5doorman
Member#: 8401
1996 Impreza (base)
hunter green
Default nice thing about my school!!
They have an OBD-II scan tool!! Plus the latest tire mounting and balancing equipment from Hunter Engineering!! I love it!!
Andrew
5doorman is offline   Reply With Quote
Old 09-22-2001, 09:33 PM   #16
Siper2
Member#: 1134
2007 BMW 328xi wagon
I had the light go on at 3,000 miles, and again at something like 20k. Both times, a faulty MAF sensor.
-S2-
Siper2 is offline   Reply With Quote
Old 09-22-2001, 10:41 PM   #17
Ripper
Member#: 7774
I thought the faulty MAF was only a problem on the 99 RS's..... but not the 98's.... is this true?
Old 09-22-2001, 10:45 PM   #18
Andrew
Member#: 1170
2005 STi
did you ever take your car in when there was a recall for O2 sensors?
Andrew is offline   Reply With Quote
Old 09-22-2001, 11:20 PM   #19
Ripper
Member#: 7774
i just got my 98 used like 4 months ago.... I wasn't aware there was a recall
Old 09-23-2001, 01:56 AM   #20
Jademonkey
Member#: 9213
2000 RS
Red
Yea, I took my 01 in too. I wasn't aware of the 02 sensor recall either. Since I just got my RS 6 months ago...I would have thought the dealership would have known about it, since it was the last one on their lot.
Jademonkey is offline   Reply With Quote
Old 09-23-2001, 02:57 AM   #21
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Mine came on tonight. I shifted at about 4k into 4th gear and the check engine light came on, blinked 4 or 5 times and turned back off. Any ideas? It hasn't come back on since.
Drac9 is offline   Reply With Quote
Old 09-23-2001, 04:48 PM   #22
subyguy2sfriend
Member#: 10497
2004 WRX Wagon
The other guys ideas for checking the light were great. Also if that dosent work try resetting the computer by disconnecting the battery for 15 mins. Then reconnect it and let your car sit at idle for 5 mins. It will relearn everything. That might fix it.
subyguy2sfriend is offline   Reply With Quote
Old 09-23-2001, 08:44 PM   #23
Ripper
Member#: 7774
Thats a good idea about the battery. I'll try that.
Old 09-23-2001, 11:30 PM   #24
RacerinLSL
Member#: 1174
2011 Subaru WRX
Ripper,
DOn't do that!! Then you'll never know what was actually wrong. Get the code pulled. Stop using 93 octane and save yourself the money. It does not help your car. It just causes extra carbon buildup.
Siper2 - YOu don't have a MAF sensor, you have a MAP.
Chad
Old 09-24-2001, 04:30 AM   #25
Siper2
Member#: 1134
Yeah I do, it's behind my seat. AAA Road Atlas issue.
j/k
Yeah MAP, that's what I meant.
-S2-
My check engine light is on............ L Bo Off-Topic 9 04-13-2006 11:49 AM
...i'm in pasadena and my check engine light is on... tre.c Southern California Impreza Club Forum -- SCIC 4 07-27-2004 10:34 PM
help my check engine light is on! Dr. J Normally Aspirated Powertrain 2 06-09-2003 09:14 PM
Uh Oh my check engine light is on Tainted South West Impreza Club Forum -- SWIC 21 07-27-2001 12:18 PM
