Welcome to the North American Subaru Impreza Owners Club Tuesday July 29, 2014
Old 02-10-2006, 03:28 PM   #1
99WRXEJ20
Member#: 34545
1999 GC8
74f
Default My dyno numbers. Ej20g/H
This is at about 20psi.
99WRXEJ20 is offline   Reply With Quote
Old 02-10-2006, 04:22 PM   #2
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
nice. where'd you get the motor from? hahah
swapstar is offline   Reply With Quote
Old 02-10-2006, 04:59 PM   #3
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
kick ass steve! I wanna see the new setup soon But before auto-x!
subbyspeed is offline   Reply With Quote
Old 02-10-2006, 05:00 PM   #4
99WRXEJ20
Member#: 34545
1999 GC8
74f
I dont know let me think, well super.....!
Old 02-10-2006, 05:19 PM   #5
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
what intercooler?
Old 02-10-2006, 06:56 PM   #6
DoctorNick
Member#: 7022
heh, chulooz
is on my ignore list
Wow, turns into a bat out of hell around 4300 eh?
DoctorNick is offline   Reply With Quote
Old 02-10-2006, 07:07 PM   #7
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
Nice work. Prtty standard. Those early engines were nice and still nice.
It would be interested to see higher rpm and a GT30R turbo.
Any vids?
west_minist is offline   Reply With Quote
Old 02-10-2006, 07:21 PM   #8
BensonRST
Member#: 106895
1999 RS-T
Custom Charcoal
kinda comes on late, don't ya think. nice numbers never the less. i'd say go bigger with the fuel and crank up the boost. that turbo can spit more power. the power cuver is awesomely flat though.
BensonRST is offline   Reply With Quote
Old 02-11-2006, 01:09 AM   #9
99WRXEJ20
Member#: 34545
1999 GC8
74f
car is built for auto-x so I didnt want anything that much bigger but who knows what the future will bring. I know kinda laggy for auto-x but most of the racing is done between 4-7k. This setup is using a greddy front mount for a 99 wrx. I am happy and not that happy at the same time. I like the curve but I had hoped for the same power at lower boost levels. i think the spool might have to due with the conservative tune off boost. Who knows. And yea I would love to turn up the boost but with a stock motor IDK it scares me. We took the car higher into the rpm but didnt get any higher numbers than those scene so why take it higher than needed.
Old 02-11-2006, 01:30 AM   #10
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
Yup a VF22 would be a better turbo choice for the power you are making. Dynapack ha?? whats a stock WRX put down on that dyno?
Scoobie Steve is offline   Reply With Quote
Old 02-11-2006, 01:19 PM   #11
99WRXEJ20
Member#: 34545
1999 GC8
74f
I wanted a rotated mount setup for future considerations.
Old 02-11-2006, 02:42 PM   #12
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
do you have the chart with the boost and A/F ratio?
honestly that spool seems really late for a 28 ~1000rpm later than a td05
Old 02-11-2006, 03:18 PM   #13
99WRXEJ20
Member#: 34545
1999 GC8
74f
my old setup with tdo5, was about 300rpms earlier. This tune was done by a tuner that had never tuned a power-fc and was extremely conservative.. Ill see if I cant get the boost vs. A/F graph.
Old 02-12-2006, 10:57 AM   #14
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Did he have the software or did you purchase it?
scoobyimprza is offline   Reply With Quote
Old 02-12-2006, 09:25 PM   #15
99WRXEJ20
Member#: 34545
1999 GC8
74f
I purchased it but he has it. I live like five minutes away from him.
Old 02-12-2006, 10:22 PM   #16
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Hey those numbers are not that bad. I'd expect higher though, but if the car is fun to drive then great
Couple questions if you don't mind?
-Is that the .86AR?
-What size UP/DP you have (ID or OD?)
-Internal or external gate?
I'm curious as to why your car seems so laggy...I'd think that 2871 would spool faster and even a TD05 only spooling 300rpm earlier seems really laggy. Have you checked for leaks etc.?
Did you guys try pushing it more...did additional boost give you more power? I'd be curious to see any info. you can provide on the tune (AFR, Timing, MAF v's etc.) Feel free to PM me if you'd like.
Anyway, sorry to ramble on a bit. Good luck with the car and keep us posted on how it goes.
Louis
Soon2Bgreat is offline   Reply With Quote
Old 02-12-2006, 11:41 PM   #17
99WRXEJ20
Member#: 34545
1999 GC8
74f
-Is that the .86AR?
Louis
Car does seem a tad laggy but when getting into it the revs dont drop that much and your back in boost in no time. The turbo is a gt2871 with a .64ar. So basically its a gt30 intake side with a small ass exhaust side. So that could be some of the lag. I also think that the timing could be adjusted a bit in the lower revs to make up some of the lag. The up-pipe was custom made to about 2 1/4 inch and the down pipe is a 3inch. We did try some higher boost runs but I was running out of fuel and I didnt want to see my car blow the first day I had her running. We also had to go to a blow through maf setup cause we couldnt get the car to idle worth a lick with it in stock location. The setup uses and external 38mm .Illl try and stop by the shop tomorrow and get other graphs.
Old 02-13-2006, 12:01 PM   #18
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Cool...the more i think about it, it's actually pretty good. It looks very similiar to a 20g graph on a 2.0l. It's a tad down on power and a tad up on torque but you're only at 20psi, many of the 20g's are at 22psi or so. Spoolup seems to be the same as a 20g and the trq/hp curves look almost identical.
You are also using the small .64...i'm sure you'd gain some by using the .86.
As far as the compressor side goes, is this the 56 trim 2871? Lastly are you using the comp. cover with the 3'' inlet?
Good luck with the car I can't wait to see what you pull with 2-3psi more and a more complete tune. Should be fun to see, keep us posted
Louis
Guess my dyno numbers - WIN A SHIRT Spec V to Wagon General Community 125 09-29-2008 03:01 PM
Evaluate my dyno numbers.... bmw50021 Proven Power Bragging 12 03-13-2008 11:29 PM
EJ20G Dyno numbers. snowman4us Subaru Conversions 36 11-02-2006 09:55 AM
Disappointed with my dyno numbers, have a look 02R6 Proven Power Bragging 54 02-11-2004 08:39 AM
My dyno numbers from the shiv dyno day quickscooby Proven Power Bragging 13 10-19-2003 12:35 AM
