Old 02-10-2006, 04:54 PM   #1
tcard
Member#: 80459
2000 impreza 6MT
DCCD silver
Default Back Up Light Question
alright heres the setup, i just put an 04 6spd Sti tranny into a 2000 2.5 RS that had an auto in it, the car is completely setup all factory systems are working fine, the only problem is the reverse lights, so i wired the reverse lights the way the diagram stated and they work but they go on in every gear instead of just revers ?? if you want me to describe how i wired it if it will help ill do that. thanks in advance.
tcard is offline   Reply With Quote
Old 02-10-2006, 09:34 PM   #2
tcard
Member#: 80459
2000 impreza 6MT
DCCD silver
bump for cluelessness
Old 02-11-2006, 01:27 PM   #3
tcard
Member#: 80459
2000 impreza 6MT
DCCD silver
no one has anything?
Old 02-11-2006, 02:35 PM   #4
Lachlan
Member#: 19470
1981 Brat GL
It sounds like a relay got wired wrong. If you know relays, they often have two output posts; one for normally open, one for normally closed. If you wire up the wrong one, you'll get exactly the opposite behaviour you would expect. I'm not familiar with the 6 speed or the reverse light relay, but I'd say that's your problem.
Lachlan is offline   Reply With Quote
Purplish back up light bulbs? SCP5000 Interior & Exterior Modification 7 10-15-2002 06:17 PM
Where is the Back-up Light Switch??? seowitz Service & Maintenance 13 10-16-2001 11:52 PM
Back Up Lights! CRAZY KEN Interior & Exterior Modification 3 10-15-2001 03:33 PM
Extra Back-up Lights BrysImpreza Interior & Exterior Modification 13 07-05-2001 02:24 PM
back up lights Ragstylz Technical Forum Archive 7 08-13-2000 08:22 AM
