Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 02-10-2006, 10:02 PM   #1
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Default WBo2 with UTEC
Hello, I am looking for the opinions of fellow UTEC users on the best wide band o2 sensor/gauge/logger to go with the UTEC. Things I am looking for would be compatability with the UTEC's datalogger, ease of use, clean installation/easy visibility, PRICE, etc. Any input would be greatly appreciated. Thanks.
Dave
OppositeLock is offline   Reply With Quote
Old 02-11-2006, 12:29 AM   #2
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
Well, the most economical would be to get a Innovate LC-1 or LM-1 WB and use MPS_UTECLogger software to log it with the UTEC. Here is the thread for the Logging software which is free:
http://forums.nasioc.com/forums/show...1#post12635981
However, I may be partial to the software...
-jason
jmussetter is offline   Reply With Quote
Old 02-11-2006, 02:57 AM   #3
Gethin
Member#: 2998
To get the AFR into the UTEC's logs your choices are TurboXS Tuner (the Tuner "piggybacks" onto the serial connection inserting it's AFR data into the standard UTEC logs) or something like the LM1/LC1 from Innovate Motorsports then use a third party app like the excellent MPS_UTECLogger which has some cool extra features too! The Tuner is probably a sexier install as the LM1 is bulky, but then the LC1 is nice too. Advantage of the LM1 is you can use it on other vehicles easily by removing it, not as "permanent" as the LC1 or Tuner.
You can use other units too like the Zeitronix but then you have to manually grapple with the data to insert the AFR into the UTEC logs, not much fun.
Personally I use the LM1 with the MPS_UTECLogger
Gethin is offline   Reply With Quote
Old 02-11-2006, 10:13 AM   #4
OppositeLock
Member#: 54060
Thanks for the replies, this is just the kind of info I was looking for.
Old 02-12-2006, 10:53 AM   #5
OppositeLock
Member#: 54060
Does the LC-1 have 2 outputs? I want to be able to run the gauge (XD-1 I think) as well.
Old 02-28-2006, 03:49 PM   #6
mavrick
Member#: 78477
04 Element block
Hydra pwrd t67
Bump, I to would like to know any info on this??
MAv
mavrick is offline   Reply With Quote
Old 02-28-2006, 04:06 PM   #7
x99percent
Member#: 27108
2004 STi
2004 A4
The two analog (gauge) outputs are separate from the serial cable output that your computer uses.
http://www.innovatemotorsports.com/s...C-1_Manual.pdf
x99percent is offline   Reply With Quote
Old 02-28-2006, 07:22 PM   #8
mavrick
Member#: 78477
04 Element block
Hydra pwrd t67
Thank you.
MAv
help: how do you Log AEM Uego WBo2 with ecuexplorer? marcus.raw Engine Management & Tuning 4 11-12-2007 08:24 PM
FS TXS tuner wbo2 with LSU4 sensor UURRXX_Ash Bay Area Impreza Club Forum -- BAIC 0 04-23-2005 11:36 AM
PLEASE help!! trying to get palm to work with utec smskier Engine Management & Tuning 14 02-03-2003 03:48 PM
Macintosh OS X with UTEC? paulw Engine Management & Tuning 3 11-01-2002 09:38 PM
abc with utec HonduhEater Engine Management & Tuning 6 09-29-2002 01:49 PM
