Old 02-11-2006, 12:23 PM   #1
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
Default MBC. how safe?
So yesturday i found out im only running .7 bar of boost, droping off to .5 . so im thinking of throwing on a MBC and setting it at 14psi. how safe would that be? i know that the MAP sensor will pick up on the higher boost, but how will the ECU react?
this is also on a EJ20G w/ a tdo4 (out of a wagon)
thanks
kirill
snowman4us is offline   Reply With Quote
Old 02-11-2006, 12:55 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
that might not be that far off factory boost levels ..
iirc this engine is only rated at 220ps
do you have an egt gage
a mbc w/o a egt gage is just asking for failure
Old 02-11-2006, 01:03 PM   #3
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
no, i dont have one.
but thats a good idea on the EGT guage, never thought of that.
And i know for a fact that the boost levels im running are factory, becoue if it was anything lower it would be spring pressure. and sense the engine is only rated at 220, .7bar of boost seems like a good boost level to make those numbers.
thanks
how safe is cobb stage 2? anthonyrb98 Mid Atlantic Impreza Club -- MAIC 3 05-11-2004 11:03 AM
how safe is Oakland Chinatown? mr_disco Bay Area Impreza Club Forum -- BAIC 22 11-14-2003 04:05 PM
How Safe Are Carbon Fiber Hoods? fukamoto Interior & Exterior Modification 19 01-18-2003 06:55 PM
How safe is it to run 1st and 2nd gear @ 16psi? WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-17-2002 11:22 AM
Is a MBC really safe? Avey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-12-2002 06:38 PM
