Old 02-11-2006, 08:24 PM   #1
curbsurfer253
Member#: 93190
Default RWD Conversion Possibilities?
I have a friend who converted an S13 240SX to AWD along with his Skyline engine swap. He set the car up so it was convertible from RWD to AWD on the fly, through engaging a hydraulic pump. Is anything similarly possibly for an AWD to RWD conversion on a GC8?
curbsurfer253 is offline   Reply With Quote
Old 02-12-2006, 09:55 PM   #2
WickedRydaX
Member#: 31900
Don't quote me on this, but I believe the way subaru trans are made its based off a FWD, so it can be FWD on the fly. You can make a RWD trans, but then it loses AWD. Like anything with the money and time anything can be done.
MCL
WickedRydaX is offline   Reply With Quote
Old 02-12-2006, 10:15 PM   #3
OneArmedScissor
Member#: 18958
08 STi
Black as my heart
MCL
nope. they are built AWD. it can easily be RWD though by messing with the diff.
clark (azscoobie) did it.
OneArmedScissor is offline   Reply With Quote
Old 02-12-2006, 10:36 PM   #4
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
I think what Wicked was trying to say was that the general design of the transmission is a FWD transmission, which it is.
An on the fly setup would be fairly complicated considering the design of the center diff.
THAWA is offline   Reply With Quote
Old 02-12-2006, 10:54 PM   #5
BlackoutWRX
Member#: 74589
2000 94 Infiniti G20
90 S13 Coupe
MCL
i believe subaru is based off rwd and evolutions are based off fwd. just looks at how the engines sit. the evolution's sits just like a fwd car.
BlackoutWRX is offline   Reply With Quote
Old 02-12-2006, 10:54 PM   #6
WickedRydaX
Member#: 31900
That is what I am trying to say, also I know of auto trans that have that were setup to take off in AWD then can put into FWD, but they didn't have that good of luck with it.
MCL
Old 02-12-2006, 11:21 PM   #7
Rockstar25
Member#: 91833
98 black RS-Sold
Indy Forum's Kid
there was some one on here that welded his center diff, and made it RWD. also IIRD there is a place that sells diffs to convert to RWD
http://forums.nasioc.com/forums/show...&highlight=RWD
http://forums.nasioc.com/forums/show...conversion+kit
Rockstar25 is offline   Reply With Quote
Old 02-12-2006, 11:27 PM   #8
THAWA
Member#: 44581
3 Boxers 2 AWD
That's totally not true. You're basing this on how the engine is mounted, transversly or longitudially. Have you ever seen a boxer engine not mounted transversly (or whichever way all boxers are mounted, I always forget which)? Also, if they are RWD based, why hasn't the layout of the engine tranny changed since the FF1 was made when they were only FWD?
Old 02-12-2006, 11:36 PM   #9
Rockstar25
Member#: 91833
98 black RS-Sold
Indy Forum's Kid
the boxer trannys are not mounted transversely, iirc this is transverse mounting tranny
Old 02-12-2006, 11:44 PM   #10
THAWA
Member#: 44581
3 Boxers 2 AWD
Longitudially then
Old 02-12-2006, 11:45 PM   #11
tony_subaru
Member#: 22742
Weld up the center diff, and put in stubby front axels. Has been done before and the suby's are fun rwd
tony_subaru is offline   Reply With Quote
Old 02-13-2006, 12:05 AM   #12
THAWA
Member#: 44581
3 Boxers 2 AWD
You don't need to do anything to the front axles if you just remove the splines that transfer power to the front.
Old 02-13-2006, 12:12 PM   #13
old_duwel
Top Scoob 015
Member#: 18175
99 STI RA Ltd #450
WRB blue
there is a center Diff in japan that you can buy for $400 and it will make it 100% RWD. I have impreza magazines that shows it.
old_duwel is offline   Reply With Quote
Old 02-13-2006, 01:22 PM   #14
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
yes there are dealers in the us to
but not in a purly switchable
a dccd tranny will allow from 100 to 65% lock but not any more
yes 5eat trannys are primarly FWD with a wet clutch that engages the rear wheels upon slip
Old 02-13-2006, 01:29 PM   #15
THAWA
Member#: 44581
3 Boxers 2 AWD
4eat's aswell.
Old 02-13-2006, 01:43 PM   #16
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
im hungry. eats.
swapstar is offline   Reply With Quote
rwd conversion AntonioS Transmission (AT/MT) & Driveline 16 09-27-2005 06:04 PM
RWD conversion - will it help? dyswtric27 Transmission (AT/MT) & Driveline 0 06-30-2003 01:56 PM
Auto RWD Conversion ImprezedRS Transmission (AT/MT) & Driveline 4 03-26-2003 07:31 PM
Billet RWD Conversion centre diff chiraoka Transmission (AT/MT) & Driveline 14 01-08-2002 08:04 PM
Anyone done RWD Conversion? cdigerlando Factory 2.0L Turbo Powertrain 0 05-25-2001 08:55 PM
Message Board Statistics All times are GMT -4. The time now is 10:26 PM.
