Old 02-11-2006, 11:32 PM   #1
BlackMagic*Club5
Member#: 101638
420 It aint my MOMs
atramentous
Default Using ECUTEK should I switch to AEM?
Ok so heres my situation. I have a ecutek on my 04 WRX. But having limitations on the ecutek. My tuner told me theres not alot to work with compared to an STI ecu since they have bigger,more things to work with. So currently Im maxed out at 435hp w/ ecutek on pump. I can make alittle more power but the ecutek on a wrx is limiting me from that. Hoping someone that had an ecutek and upgraded to a stand alone unit can give me some info if they had better results with the standalone unit compared to the ecutek..
BlackMagic*Club5 is offline   Reply With Quote
Old 02-12-2006, 01:32 AM   #2
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
You might gains some power from the standalone, but you will lose things as well. including issues with idle control, lack of OBD2 support, and no cruise control...
mcowger is offline   Reply With Quote
Old 02-12-2006, 07:53 AM   #3
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
*How* exactly is the EcuTek holding you back?
The stock ecu is MAF based, are you saying you are overflowing your MAF sensor? Are you running a BigMAF or a stock sized intake?
The advantages of the standalone is that it is typically MAP based which removes the stock ecu's MAF limitations if that's what you are running into.
FYI - My EcuTek tune on my 2L with the GT30R and the Perrin BigMAF put down 380 WHP (pump gas) and I had more MAF headroom. Was your quoted 435 HP, wheel or flywheel HP?
mick_the_ginge is offline   Reply With Quote
Old 02-12-2006, 02:34 PM   #4
BlackMagic*Club5
Member#: 101638
420 It aint my MOMs
atramentous
Yea thats the problem im running into. I am running on stock intakes. and its 435 on the fly. But how bad is the issues w/ idle control & obd2 support going to be?
Old 02-12-2006, 02:42 PM   #5
Blackpantherwrx
Member#: 70855
Air Spencer... Squash.
I think Ecutek should be fine for that power.
Blackpantherwrx is offline   Reply With Quote
Old 02-12-2006, 06:17 PM   #6
BlackMagic*Club5
Member#: 101638
420 It aint my MOMs
atramentous
But the thing is I want more
Old 02-12-2006, 07:50 PM   #7
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Then change the intake to a BigMAF. You will need a complete re-tune for the BigMAF but it can handle far higher air flow to MAF sensor voltage. A reading of 4.9 volts with a BigMAF means you would be running about 460-500 WHP
Old 02-12-2006, 08:35 PM   #8
BlackMagic*Club5
Member#: 101638
420 It aint my MOMs
atramentous
Ok thanks mick.. I'll try that.. I was planning on doing that before my tune but thought it wouldnt really make that big of a difference. But at this point its all the little things that matter now...
Old 02-12-2006, 10:14 PM   #9
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Well, zero chance of ever passing any emissions check, as without OBD2, its an autofail in pretty much every state.
Old 02-12-2006, 10:39 PM   #10
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Three words, Water/Methanol injection...http://forums.nasioc.com/forums/showthread.php?t=937176
DonkeyPunch is offline   Reply With Quote
Old 02-13-2006, 02:44 PM   #11
BlackMagic*Club5
Member#: 101638
420 It aint my MOMs
atramentous
Nice info and writeup. But how would this work with a front mount? just drill a hole next to the TB? Got any pics of this and which type are u using for ur suby?
Old 02-13-2006, 05:35 PM   #12
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Using Snow Performance stg 2 with varible controller. Not the MAF controller.
Here are install pics.
Variable controller in Glove box
Pump and Tank mounted in Trunk
LED showing activation of system in Triple gauge pod
I don't have any of where my nozzle mounts, I forgot to take some, Basically I drilled the bottom of the intercooler, right where it dumps to the throttle body. In the endtank of the TMIC. Right in the center of the intercooler outlet. THis is where most of the TMIC users drill for their nozzle.
DP
Old 09-22-2006, 12:36 AM   #13
BlackMagic*Club5
Member#: 101638
420 It aint my MOMs
atramentous
Just an update I changed to AEM. And boy am I glad I did. Dont get me wrong my ecutek was good to me for couple yrs now with couple different turbo setups. but the fact that I cant change crap without going to a tuner SUCKS(especailly for MINOR changes that messes the ecu up). Also my car was tuned before I did a whole new custom piping so the car was near the leaner side. And idling/stalling was ALWAYS a problem when i changed to a Gt35 setup. But anyways I stuck in my AEM and WOW I gained 60hp. No idle/stall problems. Raised the boost up to 19-20psi where as the ecutek couldnt hold more then 17-18psi without det. dont ask me why maybe it could of been lack of tuner knowledge? But anyways now my car is 495HP(dyna-pak) and lovin it.
Have Axxis Ultimates, should I switch to HP + or Carbotech Panther +'s Hotrodguru Brakes, Steering & Suspension 14 10-11-2004 12:55 PM
Should I switch to synthetic? Crash477 Normally Aspirated Powertrain 30 08-15-2004 01:28 PM
Should I switch to Synthetic oil? LisaPhish Legacy Forum 13 08-07-2003 11:13 PM
Should I switch to Synthetic? Speedy02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-02-2002 07:13 PM
10 Miles On Car: Should I Switch To Mobil 1 Immediately? Ex Con Service & Maintenance 5 01-20-2002 09:19 AM
