Old 02-12-2006, 12:58 PM   #1
akirasan
Member#: 45158
2004 STi
Unhappy OAT pegged at 122F
The other day I added a connector to my Alpine head unit so I could play my Rio through the system. As usual precaution when moving electrical gear around, I disconnected the battery. It stayed disconnected for an hour or so while I took some calls. When I re-connected power to test the connector I noticed
OAT decided to peg itself at 122F. Figured maybe it was a reset value based on power loss, but after driving around for a bit it dropped into the 80s range (in 60 temps) then back to 122 so now I'm wondering - dying/dead sensor, short, ??? Lacking a diagram for the sensor & cluster I'm at a bit of a loss, curious if anyone has experienced similar on their STi.
akirasan is offline   Reply With Quote
1985 GL Trouble Codes (22, 24, 73) Speedometer pegged at 125mph!!! Sierradump Normally Aspirated Powertrain 10 04-04-2009 07:06 PM
Oil pressure gauge stays pegged out at 110 psi. Just started doing this. lennyTR Electrical & Lighting 5 03-25-2009 10:46 PM
Oil Pressure gauge pegged at 100psi Drowner Electrical & Lighting 3 12-28-2006 05:24 PM
Oil temp pegged at 250deg svxr8dr Normally Aspirated with bolt-on Forced Induction Powertrain 13 01-14-2004 09:53 AM
Silver Rex Wagon Sighting at Wild Oats in Denver jzinckgra Rocky Mountains Impreza Club Forum -- RMIC 0 06-12-2001 10:27 AM
