Old 02-12-2006, 03:21 PM   #1
japslapr
Member#: 100150
02 V9 STi 6spd
HTA Green, Built EJ205
Default Unichip... even worth the 125?
Anyone have any expierience with the Unichip? Not asking for hear say... just experiences please.
It's cheap and fits my mods as of right now. TBE/UP
japslapr is offline   Reply With Quote
Old 02-12-2006, 04:48 PM   #2
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
think it's worth it if you don't plan to upgrade your car... I've had it for a year and it worked great. Is that TXS unichip?
Old 02-12-2006, 04:49 PM   #3
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
I had the unichip for a long while and loved it. It truly was a set-it and forget-it EM piggyback.
My mods were : VF34, Perrin TMIC, Sti Pinks, walbro pump, APS up, APS down, APS tbe, GT spec headers, IC water spray, UNICHIP.
The car was a 2.0 WRX stock block and tranny - ran 8.45 in the 1/8th and felt very smooth on the road. If I had not upgraded my mods , i would've kept the unichip. I ended up going with UTEC, and now i have moved on the AP with protune. But the Unichip was still the most seamless EM I've ever experienced.
Good Luck.
kingtut12 is offline   Reply With Quote
Old 02-12-2006, 04:57 PM   #4
REX8
Member#: 24038
I run one sometimes...contrary to the above post, mine is pretty on/off. Make that VERY on/off.
If your car likes it, they tend to go like stink. My TXS stage II easily outran my OTS AP stage II. You'll see lots of 13.1's with unichips from back in the day if you search.
Cheap, big fun, not smooth....2 outta 3 ain't bad!
Old 02-12-2006, 06:33 PM   #5
japslapr
Member#: 100150
02 V9 STi 6spd
thanks for the info fellas.
One more question tho.... I see that a lot of people are running some sort of MBC with it. Is this necessary or just something that they can be tuned for? Do they all use them?
Old 02-12-2006, 07:02 PM   #6
veloman
Member#: 36000
2002 WRX Sedan
The MBC won't do you much good unless you have a boost gauge. I have a Unichip in my car now and it's been great. Make sure you do the harness mod to even out the accelleration. See below from stuff I used when installing mine. I can send you a complete install doc, just PM me for it...
The programmed stage 2 boost curve for the Unichip in 4th gear is as follows:
RPM Boost
3500 16.5psi
4000 16.5
5000 16.5
6000 14
7000 13
Note: Boost in 1-3rd gear will be slightly lower and boost in 5th gear will be slightly higher (~0.5psi).
If you live at sea level, minimal or no adjustment of the boost level should be required. However, if you live at high altitude, you will need to use the ABC to increase the boost level. To increase boost, simply use the included hex key to turn the boost controllerís adjustment screw counter-clockwise. Each full turn of the screw will increase the boost approximately 1 psi. Remember to use a boost gauge when setting the boost level!
veloman is offline   Reply With Quote
Old 02-12-2006, 07:11 PM   #7
aspenw06sti
Member#: 104779
2009 RIP Sil STI/NAV
06 W STI:07 LIMITED #374
Ask vishnu!
Thats the same thing as his exeddy system.
THE ONLY DIFFERENCE IS THAT IT IS NOT IN A PLASIC CASING WITH PREPINNED OUT HARNESSES.
VISHNU IS A COPY I.E.
aspenw06sti is offline   Reply With Quote
Old 02-12-2006, 08:30 PM   #8
REX8
Member#: 24038
My unichips by themselves have never hit target boost. Always needed the MBC to achieve it.
Old 02-13-2006, 12:40 AM   #9
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
I never used a MBC with mine. Mine was an older model made by APS. Came with clubspec kit from Cobb.
Old 02-13-2006, 01:29 PM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Originally Posted by aspenw06sti
Ask vishnu!
incorect
differnt manufacure
controls boost
is user programable
the unichip is not
Is this Worth $1000, or even worth it wrxphantom Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 30 03-22-2009 10:37 PM
is this even worth the money overtheedge86 Newbies & FAQs 3 02-08-2007 01:37 PM
Are rear speakers even worth it? neorealist Car Audio, Video & Security 10 03-27-2003 07:05 PM
Does anyone think the Unichip is even worth spending money on? eightballrj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 03-20-2003 08:06 AM
1.8L even worth messing with? DoinkMobb Normally Aspirated Powertrain 15 06-10-2001 01:32 PM
