Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 02-12-2006, 06:04 PM   #1
ASpec818
Member#: 37059
03 WRX
World Rally Blue
Default what are your tokico d-spec settings?
how soft/stiff do you guys have these shocks at and with what springs? results? the manual didn't give much pointers to awd vehicles, just fwd and rwd.
also, does anyone know anything about clunking in the rear? I had these installed and the rear passenger side makes noises when going over bumps/potholes, etc.
ASpec818 is offline   Reply With Quote
Old 02-12-2006, 06:25 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
......this question has NO possible answer....the 'setting' is determined by the particular vehicle, on the particular vehicle....spring rate will be the biggest determining factor....I prefer the rears ~ 3/4 to 1 turn softer than the fronts for my car.
the 'clunk is very likely the top nut not tight enough or something not quite tight....or the rear upper spring perch oriented wrong
Old 02-12-2006, 07:32 PM   #3
koretex
Member#: 83331
I am having a really hard time deciding between these and the Koni Yellows.....how easy/hard is it to adjust them?
koretex is offline   Reply With Quote
Old 02-12-2006, 07:35 PM   #4
ASpec818
Member#: 37059
03 WRX
World Rally Blue
i was deciding between these two too but opted for the tokicos since i didn't have to hack up my stock struts to put the inserts in. the install part for the koni's would've been harder and if you are going to isntall them through a shop, it will cost a lot more.
The adjustments on the tokicos are simple. you just insert the hex key they give you into the strut and turn clockwise or counterclockwise. however you ahve to remove rear seats to do the rears but i think konis are like that too.
Old 02-12-2006, 07:43 PM   #5
koretex
Member#: 83331
well I want to do the install myself and I def dont want to cut anything so yeah Tokico it is!
Old 02-12-2006, 10:42 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
No-No-No......dear readers...as in NOT
Mcmaster-Carr has some nice CHEAP(~$3/ea)...L O N G 3mm hex wrenches.....pn 5629A73
http://www.mcmaster.com/ctlg/DisplCt...MMainWidth=812
...which is what is used to adjust the Tokico's....the Tokico's come with some nice caps to cover the adjusters....drill appropriate sized hole in cap...insert long hex wrench....screw cap on...install seat....wrench sticks up above back seat for easy adjustement.
Profit
Old 02-12-2006, 11:24 PM   #7
koretex
Member#: 83331
Profit
holy **** dude thats awesome! Thanks!
Old 07-30-2006, 07:26 PM   #8
ASpec818
Member#: 37059
03 WRX
World Rally Blue
bump for this thread since more people have got these shocks in now. So what are your current settings?
In the manual, it says you run a stiffer rear and a softer front to lessen understeer. however, i noticed that some members have been setting a softer rear than the front. shouldnt we wrx owners go for a stiffer rear?
and when you list your settings, note if they are turns from fully stiff or fully soft. thanks!
Compiling Tokico D-Specs settings QuikWgn Brakes, Steering & Suspension 327 07-11-2013 09:33 PM
WTT Tein flexes for your Tokico D-specs knastyknate MAIC Private Classifieds 0 01-24-2008 11:21 PM
What are your CLB stg 4 settings? bobsterswrx Engine Management & Tuning 3 04-01-2003 11:23 PM
What are your Blitz boost control settings? ScoobieSnaX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-19-2002 03:20 PM
What are your S-AFC settings with Turbo Greg 99 Normally Aspirated Powertrain 2 12-28-2000 07:17 PM
