Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 02-12-2006, 05:47 PM   #1
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
Default Any one have any info about the Baja bed mounted bike rack? i want one!
Hey,
I want to get a bed mounted bike rack for the Baja so we can haul our bikes around this summer. Does anyone have one? If so, how do you like it?
Also, does anyone have one they dont use that they would be willing to sell?
jnorth85 is offline   Reply With Quote
Old 02-12-2006, 06:01 PM   #2
Fuzzy 34
Member#: 96460
JNorth,
Is this the bike racks that you are talking about?
http://forums.nasioc.com/forums/showthread.php?t=939137
Fuzzy34
Fuzzy 34 is offline   Reply With Quote
Old 02-12-2006, 06:18 PM   #3
jnorth85
Member#: 76785
SRP
nope that is a roof rack.
i am looking for a bed mounted one.
Old 02-12-2006, 07:25 PM   #4
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
Some one used a 2x4 and unimounts for the forks and it worked good.
holland_patrick is offline   Reply With Quote
Old 02-12-2006, 07:57 PM   #5
jnorth85
Member#: 76785
SRP
i couldnt imagine that would weather so well.
Old 02-12-2006, 09:36 PM   #6
Smooth Criminal
Member#: 90980
2003 Baja
I made one with 2X4 's and uni's. I used pressure treated wood and put a few coats of poly on them, they should outlast the car.
Smooth Criminal is offline   Reply With Quote
Old 02-13-2006, 11:54 AM   #7
Pursuit
Member#: 38370
I didn't want to use the 2x4 approach or drill the car (like is required with the factory unit). I bought a normal bed mounted track-type rack and trimmed it down to mount in the slots the guys are using for the 2x4's... The fork mounts (or wheel mounts or whatever) can be moved and pivoted in the track, I've had four bikes in the back. I'm happy with it, looks factory and is quick to take in and out.
Pursuit is offline   Reply With Quote
Old 02-13-2006, 12:09 PM   #8
jnorth85
Member#: 76785
SRP
do you have any pics of this set up?
what did you buy to use ?
Old 02-13-2006, 12:50 PM   #9
Pursuit
Member#: 38370
It's a Saris rack, here's a blurry pic on another thread. If you do a search there's a few threads about the bike rack questions.
http://forums.nasioc.com/forums/show...ght=minor+mods
Old 02-13-2006, 01:31 PM   #10
MountainBikerBaja
Member#: 100420
2006 Baja Turbo 5sp
I have the Saris Kool Rack for mine and it works great.
It is length adjustable and has a hydraulic pump with a pressure release valve so that you don't over extend it and damage the plastic bed walls. It holds 2 bikes and can also be used to help secure large loads in the bed.
I got it because I didn't want to drill any holes in the bed.
BUT, you have to mount it near the front of the bed over the attachment holes to avoid squishing the plastic. I'll try to post some pics...
-Jason
Here's a link.
MountainBikerBaja is offline   Reply With Quote
Old 02-14-2006, 10:35 AM   #11
imprzya
Member#: 12181
2004 STi WRBro
15 Forester Touring
-Jason
Here's a link.
That looks nice, i may go that route
with that bike rack, where do you put your front tires? the factory one has a place to put your front tires
imprzya is offline   Reply With Quote
Old 02-14-2006, 01:19 PM   #12
MountainBikerBaja
Member#: 100420
2006 Baja Turbo 5sp
With this rack, I secure the front tires between the bed sides and the bikes by using two straps. One strap holding the front of the tire to the sport bar, and the other holding the rear part of the tire to the bed extender.
As mentioned, you have to position the rubber feet of the rack lengthwise directly over the plastic bed wall attachment points under the sport bars. Here's an image showing the area I am talking about.
This area won't cave in as you as you pump the hydraulic extender. (You really have to pump it until the presure release valve kicks in or else the rack will slide down a bit).
I didn't have any pics but if you need more info feel free to PM me.
-J
Old 02-14-2006, 11:01 PM   #13
hatake
Member#: 34811
04 Baja T
As I already had Yakima rack system, I got a pair of L brackets from Home Depot (like 50 cents), copper spacers, and extended bolts. Works fine, although I replaced the L brackets to bigger one. This way, the cargo box and cargo pass through are both free from the interference.
hatake is offline   Reply With Quote
Old 02-18-2006, 12:02 PM   #14
jnorth85
Member#: 76785
SRP
well, i just ordered th Saris rack, thanks everybody
Old 02-19-2006, 08:16 PM   #15
MountainBikerBaja
Member#: 100420
2006 Baja Turbo 5sp
Enjoy!
Subaru OEM bed mounted bike rack KEY Ti Pit Baja Forum 3 04-23-2010 01:29 PM
Who makes the Subaru fork mounted bike rack? Autologic General Community 6 07-24-2006 10:39 AM
Bed mounted bike rack Pursuit Baja Forum 4 11-30-2004 04:27 PM
Build your own Bed Mounted Bike Rack - for under $25! Peloquin Baja Forum 9 08-29-2004 12:57 PM
Anyone have Solid Info about the H6? Paisan Legacy Forum 2 01-28-2000 09:12 AM
