Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 02-12-2006, 09:37 PM   #1
RallyKid
Member#: 2215
Default UTEC noob question about setting it up for stock
I have an 2002 WRX w/:
-STI injectors
-Walbro pump
-Intake
-HKS BOV
-LINK ECM
I am borrowing a UTEC and putting it in and want the car to run stock, meaning to pass emissions.
Can I avoid making a fuel map and just set the stock injector compenstaion only or do I have the make a map?
I will be setting the ignition map to "e" and was wondering if I can do the same with the fuel map and just compenstae for the bigger injectors, if so what number do I put in?
RallyKid is offline   Reply With Quote
Old 02-12-2006, 10:54 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...ask TXS.
Old 02-13-2006, 09:21 AM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
what firmware on the utec?
Old 02-14-2006, 01:51 PM   #4
RallyKid
Member#: 2215
TXS is not getting back to me.
Says Rev 3 on the PCB, I do not know what revision S/W, have not hooked it up yet. Will it tell me when I hook it up?
So this is not a streight forward setup. From the manual seemed like an easy one, set Fuel and Ignition to "background ECU" and set injector correction factor and should be done, no?
Old 02-14-2006, 01:57 PM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
yes, you'll see the firmware version on the splash screen, top right.
it matters because not all revisions have open loop fueling which is necessary for injector scaling, and even fewer have the option to enable injector scaling while still under oem ecu fuel control.
it's a simple matter to reflash it though. get that laptop fired up and tell us what version you're running.
i assume your oem ecu has not been reflashed?
Old 02-14-2006, 02:07 PM   #6
RallyKid
Member#: 2215
OEM ECU is not flashed.
I will fire it up today and let you know, MMmmm, today is Valentine's Day, make that tomorrow.
Thank you for the help.
Old 02-14-2006, 07:25 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
....I had the 'old' fimware...and Sti pinks.....and a little fuel out of the 0% collum....I had -5's and -6's and it ran fine.
Old 02-14-2006, 07:31 PM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you could certainly do what scotty said, too. that's the way folks used to tune the utec for larger injectors.
you're still gonna need that laptop though!
Old 02-20-2006, 11:23 AM   #9
RallyKid
Member#: 2215
So I had the UTEC hooked up, and had my buddys map running which was for STi injectors and exhaust, similar to my set up, and had the Wideband, and no matter to what I changed the low RPM and load rows, I am still running lean 14.7 area under light throttle.
Is there a way to see the active cell that the UTEC is running? How do you guys know which cell to change if say a Wideband is telling you you are lean.
On a LINK you can see exactly what cell is active and you know what to change.
BTW: teh UTEC is REV.3, Firmware 4.1
Old 02-20-2006, 11:39 AM   #10
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
rally:
with a utec, you must cross over the TPS crossover point to have any effect. you must also be outside the range of rpm/tps/maf that the oem ecu is still running "closed loop" stoich fueling.
Old 02-20-2006, 12:27 PM   #11
RallyKid
Member#: 2215
So UTEC will not take over until some point? Why does it have a column for 0% Load then?
Old 02-20-2006, 01:47 PM   #12
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
well, two things are happening:
the 0 column is indeed for non utec control.
however, the rpm/tps/maf inputs to the oem ecu are in a region where it is still running closed loop. it is using a feedback loop containing the front o2 sensor to determine idc. that, along with the input from the maf sensor, is used to set the oem ecu fuel trims. changing the mafv offset in the utec will NOT change the idle (and other closed loop) operating afr--it will just end up changing the fuel trims.
iow, your car should ALWAYS idle at 14.7:1 or thereabouts, and for most part throttle putting around town as well. you cannot change this without a reflash or standalone ecu.
Old 02-20-2006, 01:56 PM   #13
RallyKid
Member#: 2215
14.7 seems kinda lean, and the car runs ruff for that matter, choppy, like its not likeing the mixture. I dont know what else it could be, ignition is set to ECU.
Should it also be running closed loop ao the highway at like 3000RPM? I doubt it, this morning I was coming to work and at 3000RMP it was still in the 14's AFR.
Additionally I have the % fuel enrichment set to 10% in the parameters but that is not heliping either.
Old 02-20-2006, 03:31 PM   #14
Gethin
Member#: 2998
14.7:1 is stochimetric, not lean or rich. Cruising around on light throttle your car runs in closed loop and tries to maintain that mix.
Gethin is offline   Reply With Quote
Old 02-20-2006, 04:20 PM   #15
Freon
Member#: 88322
2009 BMW 135i
It is best to log fuel trim from the ECU to adjust the 0% column and/or injector scaling. You may want to check our www.wrxhackers.com for more info. Some people don't use injector scaling at all and just use large negative numbers in the fuel map to make adjustments. I'm not sure funtionally with the UTEC that there is a difference between using large negatives in the fuel map vs. using injector scaling and near zero values in the fuel map, but you may want to read up on opinions.
The ECU is going to try to maintain 14.7:1 idle no matter what your UTEC is set for. If it is too far off it won't be able to compensate at all (like if you just tried to fire the car up, fuel trim would max out) and will probably stall. Say you get your idle working with -6.0 in the fuel map 0% column. If you change it to -6.2, you will still probably idle fine, and it will still run 14.7:1, because the ECU will compensate with fuel trims. Preferrable you want fuel trim to be a moderate value, and when you start driving you want to keep it from bouncing around too much. I would suggest checking out Tari and openecu for cheap solutions to log fuel trim.
As Gethin said, you'll be in closed loop and running about 14.7:1 cruising or at light throttle (say <15%) regardless. Also, if you look at a standard fuel target map, you'll see the car wants to run 14.7:1 until you're moving quite a bit of air, and/or moderate air at higher RPMs.
Freon is offline   Reply With Quote
Old 02-21-2006, 07:59 AM   #16
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
why is the fuel enrichment set so high?
that could be your problem right there. in what section of the parameters is that enrichment set?
depending on mass air flow rate, it can hold closed loop up to 5500 rpms.
Old 02-21-2006, 09:51 AM   #17
RallyKid
Member#: 2215
Fuel enrichmnet is set so high cuz when its running in closed loop at 14.7AFR its rough and stuters, so I thought I would enrich it, but even at 10% its still 14.7% and now I know why. I am at work now, but if I remember correctly its set in Parameters>Tunning or something like that.
Noob question about Utec please HELP!!! 04psmgt35sti Engine Management & Tuning 5 07-13-2009 06:53 PM
Noob question about UTEC please HELP! 04psmgt35sti UTEC 1 05-12-2009 04:31 PM
Noob question about UTEC and ABC.. 2gsxtasy UTEC 4 02-25-2007 03:10 PM
noob question about utec silverboost0303 Newbies & FAQs 1 09-24-2005 10:00 PM
Noob question about up-pipe xtheviperx Newbies & FAQs 1 10-09-2002 01:51 PM
