Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 02-12-2006, 10:33 PM   #1
sneekyjesus
Member#: 74968
02 wrx
wrb
Default Why does my alarm go off when I open with key?
Why the heck does the alarm in car go off when I open the door with the regular key instead of the keyless entry remote? The battery is dead in the remote, so now I can't start my car....
sneekyjesus is offline   Reply With Quote
Old 02-12-2006, 10:36 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....turn the key in the ignition to 'on' and 'off' 3 times....quick....then start the car...if it isn't 3 times...try 5
Old 02-12-2006, 10:38 PM   #3
23b_Rex
Member#: 79394
02 gda
wrb
haha, mine just goes off 30 sec after i set it... so at least yours works
23b_Rex is offline   Reply With Quote
Old 02-12-2006, 10:39 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Because unlocking with the key does NOT disarm the alarm. Follow the procedure Scotty posted (I think it's 5 times), then go get a new battery for the remote.
Old 02-12-2006, 10:41 PM   #5
sneekyjesus
Member#: 74968
02 wrx
wrb
ill try the on off thing, heres a side question: i took the remote apart to check what kinda battery it is, now the thing wont work at all when i put it back together. i took it apart cuz i think the batteries dying, but it was still working before hand... why not now?
Old 02-12-2006, 10:44 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Did you take the battery out and put it in backwards?
Old 02-12-2006, 10:46 PM   #7
shipjumper
Member#: 6307
what I has no car...
am carless
only on the legacy product (OB, tribeca) will the key turn off the alarm in the door...
the impreza stuff (and baja) does not have this ability
shipjumper is offline   Reply With Quote
Old 02-12-2006, 10:46 PM   #8
Black-Falcon
Member#: 106318
16 Cadirrack
ATS-V
Heres a way outta left field guess, but did you re-sync it with your car? With my truck, I had to hold Lock and Unlock at the same time until it did somthing to let you know that it was setup
Black-Falcon is offline   Reply With Quote
Old 02-12-2006, 10:46 PM   #9
sneekyjesus
Member#: 74968
02 wrx
wrb
backwards as in 180 degrees rotated?
Old 02-12-2006, 10:48 PM   #10
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
As in flipped over heads/tails, i.e. reverse polarity.
Old 02-12-2006, 10:49 PM   #11
sneekyjesus
Member#: 74968
02 wrx
wrb
nope ive been putting it so the + is on top
Old 02-12-2006, 10:51 PM   #12
Black-Falcon
Member#: 106318
16 Cadirrack
ATS-V
Old 02-13-2006, 01:10 PM   #13
cMags
Member#: 88668
'05 Outback Sport
5MT - Regal Blue / Grey
Outback Sport
On my '05, the on/off thing only needs to be done 3 times to disable. Still can't do it fast enough to not feel like a dumbass for setting off my own alarm. But I guess I feel better being that guy who sets his own alarm off with the spare key in my wallet than being that guy that locked his keys in the car again...
cMags is offline   Reply With Quote
Old 02-13-2006, 02:30 PM   #14
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
I'd get a new battery and install it. I managed to drop my keys in a bucket of water. I took it apart, blew it dry with compressed air, drove around setting the alarm off every time I started the car for 24 hours (setting my alarm off at least 2 dozen times, and the key on/off trick worked every time), then put the remote back together and it's still working perfectly 6 months later.
Mike Robinson
bluescoobywagon is offline   Reply With Quote
Old 02-15-2006, 02:08 PM   #15
corey_dyck
Member#: 98427
2006 STI
You can also turn off the factory alarm. You hold one of the buttons for a prolonged time with the driver's door open. It will flash "Security" on the cluster whenever the car isn't running after you've done this.
corey_dyck is offline   Reply With Quote
Old 02-15-2006, 10:46 PM   #16
HappyIdiot
Member#: 83494
2004 WRX Wagon
Red
Hmmm. There has been quite a few times I have gone to lunch and left my keys inside. Instead of going back, I just use my spare. I have never had my alarm go off with unlocking the door with my key. I have an 04 btw.
HappyIdiot is offline   Reply With Quote
Old 02-15-2006, 11:05 PM   #17
kellie00
Member#: 80965
2012 STI
That's messed up, mine goes off if I even think about using the key.
kellie00 is offline   Reply With Quote
Old 02-15-2006, 11:08 PM   #18
bezerk
Member#: 44809
2008 BMW M3
SATURDAY!!!!!!!!!!!!!!!
Yeah, something is messed up....it should be going off.
bezerk is offline   Reply With Quote
Old 02-16-2006, 10:23 AM   #19
HappyIdiot
Member#: 83494
2004 WRX Wagon
Red
Since I have owned my car the alarm has never gone off, but if you hold the panic button down it still goes off. I just tried it.
Old 02-16-2006, 11:03 AM   #20
NVAKeith
Member#: 26525
Sold 2002 WRX
2011 LGT Blue
When the alarm is armed (by locking car with the remote or PDL button with door open) the red 'security' light flashes in the gauge cluster. IIRC when the valet feature is enabled, the security light stays on.
When I don't want to carry the remote fob and intend to use my spare key, I just don't arm the alarm.
NVAKeith is offline   Reply With Quote
Old 02-16-2006, 12:40 PM   #21
HappyIdiot
Member#: 83494
2004 WRX Wagon
Red
I have never noticed a security light flashing or stayed solid in my gauge cluster. Maybe Im an idiot and not doing it right, but I normally either lock the car with the remote, or I will press the lock on the door and close the door. Sorry for hi-jacking the thread.
edit: Nevermind, I am an Idiot. Thanks for all the help.
Factory alarm going off when TT counting down. TommyWRX Car Audio, Video & Security 4 03-30-2007 11:56 AM
Why does my alarm only work "sometimes" MF-DIF Car Audio, Video & Security 3 11-24-2004 01:08 PM
why is my alarm going off? philip_g Car Audio, Video & Security 5 04-14-2003 11:29 PM
alarm goes off when i use the key bziller Car Audio, Video & Security 4 07-16-2002 01:22 PM
('93-'01) why does my PMs automatically delete when i reply? jetfire67 Impreza Forum 1 06-11-2001 10:39 AM
