Old 02-13-2006, 01:12 AM   #1
ccroach
Member#: 69114
2002 VF30 WRX
Default STI TMIC ok with COBB stg. 2.5?
Now i've been doing lotsa searches on here so please don't flame me but i can't for the life of me find a reasonable conclusion, most people say it's just fine but others say EGT's and boost will both increase (no good). So can any of you fellas enlighten me with an answer to this question? Thanks guys .
ccroach is offline   Reply With Quote
Old 02-13-2006, 01:43 AM   #2
ccroach
Member#: 69114
2002 VF30 WRX
Good 'ol 30 minute NASIOC bump
Old 02-13-2006, 01:45 AM   #3
pityr
Member#: 31719
Well, I added a ver. 7 to my car with an ECUTek stage 2 reflash and it lowered my EGTs...
It probably won't do anything to the car unless you tune for it.
pityr is online now   Reply With Quote
Old 02-13-2006, 01:57 AM   #4
23b_Rex
Member#: 79394
02 gda
wrb
as for egts and boost.. that's something you're gonna have to monitor
also.. in vegas i assume you're gonna be dealing with some heatsoak issues
23b_Rex is offline   Reply With Quote
Old 02-13-2006, 02:21 AM   #5
ccroach
Member#: 69114
2002 VF30 WRX
Yup, i already have a CUSCO heat shield over the VF-30, I just hope the STI TMIC will agree with the COBB Acessport, think they'll get along fine?
Old 02-13-2006, 03:06 AM   #6
supermarkus
Member#: 6971
2008 WRX STi
SSM
They will.
supermarkus is offline   Reply With Quote
Old 02-13-2006, 03:06 AM   #7
23b_Rex
Member#: 79394
02 gda
wrb
^ yes.. considering cobbs maps are for tmic's
Old 02-13-2006, 03:37 AM   #8
ccroach
Member#: 69114
2002 VF30 WRX
Thanks alot for clearing up this issue fellas, i appreciate it! :beer:
Old 02-13-2006, 09:21 AM   #9
sjs0433
Member#: 86061
A buddy of mine has the usually goodies for a turbo upgrade, running a vf30, with a jdm sti tmic, its about 15% larger than the usdm sti tmic. His car is really fast. He's using AP and is just running the off the shelf map. Although only thing diffferent is he is running a manual boost controller at 20psi which is probably why it feels fast. Afr's are good too....the cobb maps are pretty rich.
sjs0433 is offline   Reply With Quote
Old 03-05-2006, 02:08 PM   #10
Scott4DMny
Member#: 74862
2003 WRX Sedan
World Rally Blue
Bigger intercoolers = reduced detonation. Also, even if the IC has less of a pressure drop, the ecm will account for that and bleed off more via the wastegate. with less of a pressure drop, the turbo will just have less strain on it because it wont have to push as much boost as it did before. You will be fine. There should be no "drastic" change. PERIOD. Some people will say "YOU NEED TO HAVE IT PRO TUNED". Thats just not the case.
Scott
Scott4DMny is offline   Reply With Quote
Old 03-05-2006, 06:05 PM   #11
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
i ran my cobb 2.5 setup with an ebay tmic for quite some time and everything was fine - a/f ratios and egts were well within safe values.
anthonyrb98 is offline   Reply With Quote
Old 03-05-2006, 09:19 PM   #12
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Posting in the right forum helps as does reading the sticky at the top of that forum. PLEASE....spend more than 2 seconds to decide where you are going to post and be sure to read the stickies. People like you give us Moderators ulcers.
Old 03-06-2006, 01:01 PM   #13
Steve Nastoff
Member#: 52052
03 Subaru WRX
Midnight Black Pearl
I've been running a version 7 STI intercooler with the Cobb 2.5 for 2 yrs. I carry 18.2 PSI as read on the Access Port which makes me believe that it is less restrictive. I ran this intercooler while I was at Stage 2 for about 6 months and have been very happy with it.
Steve Nastoff is offline   Reply With Quote
STi exhaust with Cobb stg 2 WRX? Blue_Rexer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-03-2006 02:56 PM
Has any cobb stg 2.5 wrx raced a cobb stg 1 sti? cheese tits Proven Power Bragging 41 12-22-2005 04:25 AM
Those with Forge bovs with cobb stg. 2, which spring? sjscooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-21-2005 01:36 PM
Thoughts with 16g and Cobbs stg 2.5 map Swine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 12-06-2004 03:51 PM
COBB stg 2.5 owners Report. abqkid Engine Management & Tuning 6 04-20-2004 06:35 PM
