Old 02-13-2006, 03:01 AM   #1
craver
Member#: 77905
2005 WRX
WR BLUE
Default EJ20G on wrx any 1 ???
Hi there currently running on 05 wrx was wondering if this older model closed deck block fit in nicely into a newage wrx here. Is there any compatiable issue here?? Going through the search function nt much info could be found. Hope any 1 here can provide me more details for me before making the go. Thank
craver is offline   Reply With Quote
Old 02-13-2006, 08:02 AM   #2
silvialost
Member#: 91021
1997 impreza
red
the majority of the ej20 stuff is compatable. im pretty sure you could get away with it. but i cant make any promises.
silvialost is offline   Reply With Quote
Old 02-13-2006, 10:36 AM   #3
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
I know of someone who swapped an EJ20G engine and then had a bad block, so he used a USDM EJ20 shortblock then with EJ20G heads.
I would say yes, that you can use atleast the EJ20G shortblock with your USDM heads and intake manifold.
scoobyimprza is offline   Reply With Quote
Old 02-13-2006, 11:15 AM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Unless you have fragged your block, I wouldn't even consider this. And as has been mentioned, putting a 12-15 year old engine in there in place of a virtually new one is a risk. More and more people recently are getting old swaps into their cars and having them spin bearings in the first 6 months. You just can't trust the stuff that's older.
Furthermore, closed deck is way over hyped, and the early heads have HLA's that don't like to rev very much. Unless you were going to use an STI block (with solid lifters) and do a full rebuild from the ground up, this is a stupid idea. And closed deck engines will only be '94 and earlier. There really aren't very many of them still floating around. I do have an EJ20G closed deck shortblock that needs to be gone through if you are serious about this project. But, you would be far better off sourcing a V7 STI shortblock, and mating it to your heads...
Old 02-13-2006, 11:15 AM   #5
craver
Member#: 77905
2005 WRX
WR BLUE
Is it worth spending $700 to get a complete set EJ20G block to transplant over 05 wrx?? More review coming thank.
Old 02-13-2006, 11:17 AM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
Not in my mind, it isn't. I would sell my shortblock for $250 plus freight.
Old 02-13-2006, 11:19 AM   #7
craver
Member#: 77905
2005 WRX
WR BLUE
Sorry whats HLA's ?? Wow yr advise really sound exactly from Mike (spdusa) He also advise me to source a V7 upwards block.
Old 02-13-2006, 12:36 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
Hydraulic lash adjusters. And you can always trust Mike's input...
Old 02-13-2006, 01:19 PM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
no
+1 for what matt said ..
even a v.5 or v.6 short block but not a phase 1 .. i also remember somthing about the older pistons and bad valve clearance too
Old 02-13-2006, 04:34 PM   #10
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
HLA on the ej20g's dont liek to go past 8K. unless you have a turbine that wants to go past 8K and the other such, HLA isnt bad. no need for mechanical whatnot adjustments. the normal Sti's had HLA's in the G motors. the sti-RA's were the only G that will spin past 8K happy. to 9, or 10K if you dont have a rev limiter (and want to suffer the consequenses....)
unless you actually can argue that you can go past 8K and make power, going HLA isnt bad at all.
swapstar is offline   Reply With Quote
Old 02-13-2006, 08:35 PM   #11
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
gunna have to go with matt as well.
and matt, you selling the rsra?!
Hurley 2.5 WRS is offline   Reply With Quote
Coolant reservior on ej20g / 02 wrx azn0boi04 Water/Methanol Injection, Nitrous & Intercooler Cooling 1 09-15-2008 11:42 PM
sti upipe on wrx ..any gains?? ineedparts Newbies & FAQs 11 05-10-2007 09:14 PM
STI TMIC on WRX, any advantage when protuned???? krystek Newbies & FAQs 10 09-09-2006 06:20 PM
Installing JIC FLT-A2 coilovers tomorrow on WRX - any tips? samwY Brakes, Steering & Suspension 20 05-15-2004 03:44 AM
6 piston caliper has less clamping force then 4 piston ones on WRX - any truth? HM3SC Brakes, Steering & Suspension 12 06-27-2001 05:54 PM
