Old 02-13-2006, 03:01 AM   #1
ikkuy
Member#: 99042
01 2.5 RS
Question Power Plus or Vision Plus?
As titled, I am thinking about getting philips power plus or vision plus.
I have seen lot of threads about how good the visions plus is, but not the power plus.
Is that new product? are there any differences?
ikkuy is offline   Reply With Quote
Old 02-13-2006, 03:44 AM   #2
REVNU
Member#: 82147
2005 WRX Sedan
I think the PowerPlus are over-wattage bulbs, which are a big no-no if you're running the stock wiring harness.
Stick with the VisionPlus. I have a set in my 05 WRX and I really like them. Much more usable light than my old PIAA Extreme White Plus.
Hope that helps.
~REVNU
REVNU is offline   Reply With Quote
Old 02-13-2006, 10:50 AM   #3
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Philips VisonPlus or the Osram Silverstars are what you should consider:
http://www.powerbulbs.co.uk/
Hank3 is offline   Reply With Quote
Old 02-13-2006, 03:15 PM   #4
ikkuy
Member#: 99042
01 2.5 RS
I see. So if i upgraded the wiring harness, power plus will be brighter tho?
Thank you.
Old 02-13-2006, 05:15 PM   #5
REVNU
Member#: 82147
2005 WRX Sedan
Yes the PowerPlus will be brighter. But you also have to worry about our PLASTIC headlight housing melting from the extra heat they generate.
Your best bet (and safest) is to stick with the stock wattage bulb (Vision Plus +50%) and get some auxilary driving lights with some super bright bulbs. Is there a reason you need such bright lights?
~REVNU
Old 02-14-2006, 12:15 PM   #6
MtnGoat
Member#: 86243
2001 2.5RS brp
07 FXT Sports ugm
Default VisionPlus
I just installed VisionPlus bulbs from Powerbulbs.com and been using them over the last couple of weeks. Plenty bright. Has a more even spread of light than the PIAA super plasmas I replaced. No need to change wiring. I just hope they last longer than the PIAA's. Much cheaper. 20bucks vs PIAA @80bucks. Fast service from Powerbulbs and you get a free pair of sidemarker lights with your purchase
Good idea to order 2 pair to have one for backup.
MtnGoat is offline   Reply With Quote
GE Megalight plus vs. Osram Silverstar vs. Phillips Vision Plus Scooby Blue Electrical & Lighting 23 02-07-2005 02:06 PM
EDM STI lights with phillips vision plus Scoob02 Electrical & Lighting 3 05-04-2003 11:25 PM
Philip Vision Plus H1 emits yellow light from jdm projector S-WRX Interior & Exterior Modification 3 03-20-2003 11:12 AM
Philips Vision Plus H1 from Powerbulbs.com Ooter Vancouver Impreza Club Forum -- VIC 12 08-02-2002 01:42 AM
