Old 02-13-2006, 03:13 AM   #1
tcard
Member#: 80459
2000 impreza 6MT
DCCD silver
Default GC8 ABS Wiring Q
I recently put an 04 sti tranny in my 2000 2.5RS which had an automatic in it before, so i wired everything up and the car runs great, then the ABS light comes on and the brakes lock up the more you use them, till it is impossible to drive the car? im lost, any help is appreciated
tcard is offline   Reply With Quote
Old 02-13-2006, 04:30 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
pull the abs fuse until you figure out what you messed up on...that or you have ATE Super Blue in your brake lines and you've never flushed it.
Old 02-13-2006, 04:47 AM   #3
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
Did you swap in the STi axles? The different stator rings could be the problem. Personally, I'd junk the ABS system entirely, but just do as HndaTch suggests and pull the fuse for now.
US2JDM is offline   Reply With Quote
Old 02-13-2006, 04:56 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
i didn't even think about him swapping the axles....that's the problem right there if you did in fact swap in the STi axles
Old 02-13-2006, 05:53 PM   #5
tcard
Member#: 80459
2000 impreza 6MT
DCCD silver
no im running the front gc8 setup, stock auto axels up front, but explain this sti axel problem just in case. thanks again guys
Old 02-13-2006, 06:04 PM   #6
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Well, ABS won't work when you swap AT for MT. You need to put your TCU back in the car if you removed it. I believe (if you're lucky) that just connecting the TCU will work. Try it out.
garface is offline   Reply With Quote
Old 02-13-2006, 07:42 PM   #7
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
Well, did you swap out the rears? The stator ring (looks kind of like a gear) is what spins past the ABS sensor and induces the signal that tells the ABS computer what speed the wheel is turning at. I know the rings are different between the older cars and new ones. The ring is pressed on to the end of axle stub. If you've got GC fronts and GD rears, I believe that is your problem right there.
Old 02-13-2006, 07:48 PM   #8
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
They didn't start putting the sensor ring onto the axle shaft until MY2000 Legacy's and MY2002 Impreza's. On the 1993-2001 Impreza's, the ABS sensor ring bolts right to the hub front and rear so it's independent of the axle itself.
wrx_driver_2002 is offline   Reply With Quote
Old 02-14-2006, 02:48 AM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
and there you have it
Old 02-14-2006, 03:41 AM   #10
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
You're right. Brain fart.
I'll jump on the AT vs. MT bandwagon.
Old 02-14-2006, 04:00 AM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
yea the more i thought about it the more i realized that he was right, but then again if he chaged the rear hubs wouldn't it still have the same effect or is the sensor they use compatible with the RS's ABS control unit?
Old 02-14-2006, 03:28 PM   #12
tcard
Member#: 80459
2000 impreza 6MT
DCCD silver
abs comp works again. thanks
Old 02-14-2006, 03:29 PM   #13
tcard
Member#: 80459
2000 impreza 6MT
DCCD silver
yea i did swap in the brembo rears with the r180, so how do i fix this dillemma? thanks again guys, been a major help.
Old 02-14-2006, 03:44 PM   #14
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
so just to be clear it was the absence of the TCU that was causing the problems correct?
Old 02-16-2006, 12:45 AM   #15
tcard
Member#: 80459
2000 impreza 6MT
DCCD silver
nope, abs comp works now but the brakes still seize up and wont decompress when i use them?
Old 02-16-2006, 03:49 AM   #16
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
I assume you did the rear hubs, axles and diff.? If so, it's probably the difference in the signals from front vs. rear. I think you'll have to go with the STi fronts as well to make everything match. Also, which rear ABS sensors did you use? RS or STi? How are the clearances?
Old 04-11-2006, 03:51 PM   #17
tcard
Member#: 80459
2000 impreza 6MT
DCCD silver
i used the rs ones, but im not sure on the clearence, might be a little to long, but ill know soon. thanks im running without the abs at the moment, pedal is a bit soft though...
WTB: Front passenger ABS wire car_cursed Private 'Wanted' Classifieds 0 02-07-2008 11:59 AM
Wanted: 96 Legacy ABS wiring diagram Gator GT Legacy Forum 3 02-14-2006 10:08 PM
Q about ABS wiring soloflo Brakes, Steering & Suspension 1 04-02-2005 07:56 PM
Q about ABS wiring soloflo Tri-State Area Forum 2 04-02-2005 04:09 PM
Remove ABS Wiring gr8wheels Brakes, Steering & Suspension 1 09-23-2002 08:20 PM
