Old 02-13-2006, 09:35 AM   #1
ScoobySnacker
Member#: 105303
2003 WRX
Default Reading a/f ratio?
I just realized i posted this previously in the wrong forum..I will be getting an innovative wideband gauge this weekend..What are the basics for reading a/f ratio? What is the target range? How do i tell if the car is running rich or lean? Can knock be determined by the gauge? Im not new to cars, just new to the turbo thing. any info would be appreciated!
P.S- I have an 03 wrx
ScoobySnacker is offline   Reply With Quote
Old 02-13-2006, 10:46 AM   #2
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
Quack is offline   Reply With Quote
Old 02-13-2006, 11:26 AM   #3
ScoobySnacker
Member#: 105303
2003 WRX
Thanks
Old 02-13-2006, 12:01 PM   #4
ScoobySnacker
Member#: 105303
2003 WRX
Does this also determine engine knock?? And what are the target a/f readings for the wrx?
Old 02-13-2006, 12:03 PM   #5
Quack
Member#: 57264
no, it's best to use a knock sensor.
AFR's depend on the tune, load & fuel map .
Old 02-13-2006, 01:07 PM   #6
ScoobySnacker
Member#: 105303
2003 WRX
at the moment i have TBE, do i really need to worry about my AFR right now, or should i just worry when i get EM.
Old 02-13-2006, 01:26 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Originally Posted by Quack
AFR's depend on the tune, which fuel map its in and LOAD
fixed that for ya
Old 02-13-2006, 01:56 PM   #8
hondaeater69
Member#: 60324
targets will depend type on gas and level of mods, but generically speaking targets are 14.7:1 at idle and light cruise. Light throttle (7psi) they will begin to get rich, 12:1, getting richer near redline, anywhere from 11.5:1 to 10:1 depnding again on gas etc.
I would personally not worry about AFR's on a professionally tuned car. If you want to get it just to "see" what they are, that's a fairly expensive imagination. If you plan on tuning your car yourself at some later date, then you'll need it anyway. If you don't plan on tuning the car yourself, save the duckets and spend it on a professional tune and get an EGT system for day to day monitoring.
Old 02-13-2006, 04:16 PM   #9
ScoobySnacker
Member#: 105303
2003 WRX
So you believe that having wideband is not worth it if i am not going to tune my own car?? I get confused beause other people here say that cobbs maps can sometimes not be safe, and i dont want to ruin my motor.
Old 02-13-2006, 04:41 PM   #10
hondaeater69
Member#: 60324
So you believe that having wideband is not worth it if i am not going to tune my own car?? .
that's exactly what i'm saying. The money you spend on a WB, you could put towards a custom tune, which they use a WB when tuning, they will get your car into a "safe" tune and you're good to go. Some OTS maps are not safe. . .that's why you get your car professionaly, custom tuned.
How to read A/F ratio?? ScoobySnacker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-13-2006 10:43 AM
Is S.E.C.S. air/fuel ratio readings still accurate when running UTEC? edkwon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-23-2004 07:00 PM
A/F Ratio readings using TXS Tuner please help my02wrx Engine Management & Tuning 6 03-13-2004 10:38 PM
How do u read Gear Ratios??? AWDBOY Transmission (AT/MT) & Driveline 1 04-24-2003 06:48 PM
uppipe pre-cat and a/f ratio readings recursian Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-20-2003 05:49 PM
