Old 02-13-2006, 10:28 AM   #1
johnei
Member#: 70272
Default Porsche 997 turbo
via leftlanenews
Porsche officially announces 2007 Porsche 911 Turbo
Following the leak of photos over the week, Porsche today officially announced the 2007 911 Turbo. The sixth generation of the 911 series’ top-of-the-range model will be celebrating its world premiere on February 28, 2006 at the Geneva Motor Show and will be available in German dealerships as from June 24, 2006. The 911 Turbo (Type 997) now has an output of 480 hp at 6,000 rpm, 60 hp more than its predecessor (Type 996). The specific output of the 3.6-litre boxer engine thus climbs to a new all-time high of 133 hp per liter of displacement. Rated torque has been increased from 560 to 620 Newtonmeters. The speed range in which this power is available has also been extended. While the previous model’s maximum torque was available between 2,700 and 4,600 revolutions per minute, the corresponding figures are now 1,950 to 5,000 revs.
These improvements are translated into driving performance. The new 911 Turbo with six-speed manual transmission requires 3.9 seconds for the standard sprint from zero to 100 km/h. The coupé reaches the 200 km/h mark in 12.8 seconds. And just 3.8 seconds are all it takes for the most powerful series-built 911 model of all time to accelerate from 80 to 120 km/h in fifth gear. Despite these enhanced performance statistics, Porsche developers succeeded in reducing average fuel consumption by one tenth to 12.8 liters per 100 kilometers.
The 911 Turbo with the optionally available Tiptronic S automatic transmission puts in an even more impressive performance. An optimized setup gives the vehicle the wherewithal to power from zero to one hundred in just 3.7 seconds and to reach 200 km/h after a mere 12.2 seconds.
The Turbo with automatic transmission also has the advantage when it comes to flexibility. In penultimate gear it accelerates from 80 auf 120 km/h in 3.5 seconds. Fuel consumption by the Tiptronic S variant is 0.3 liters lower than that of its predecessor: 13.6 liters in accordance with the EU standard. Both transmission variants have a top speed of 310 km/h.
The vehicle’s flexibility can be enhanced even further with the optional “Sport Chrono Package Turbo”, available for the first time. Here the driver selects the “sports button” adjacent to the gear lever to activate a short-time “overboost” at full throttle. This increases boost pressure in the mid speed range by 0.2 bar for up to ten seconds; torque rises from 60 to 680 Newtonmeters. The time required by the 911 Turbo with manual transmission for intermediate acceleration from 80 to 120 km/h is reduced by 0.3 seconds to 3.5 seconds.
These performance figures owe themselves to exhaust turbochargers with variable turbine geometry, featuring for the first time in a gasoline engine model. At the heart of this technology are adjustable guide blades, which direct the engine exhaust flow variably and precisely onto the turbine wheel of the exhaust turbocharger. The principle of variable turbine geometry unites the advantages of small and large exhaust turbochargers and leads to a discernable improvement in flexibility and acceleration, particularly at low speeds.
To transfer the available power to the road, the new generation of the 911 Turbo features a redesigned all-wheel drive with an electronically controlled multi-disc clutch. Porsche Traction Management (PTM) ensures variable power distribution to the two driven axles. Depending on the driving conditions, the all-wheel electronics system constantly determine the optimal torque distribution to ensure the best-possible drive. In practice this translates as high agility on narrow country roads, outstanding traction in rain and snow and optimal active safety even at high speeds. These properties make the Porsche Traction Management system in the new 911 Turbo one of the most powerful and, at the same time, lightest all-wheel systems on the market.
The new 911 Turbo’s driving performance is duly tempered by its brake system, which comprises monobloc fixed-caliper disc brakes with six pistons at the front axle and four at the rear.
In comparison with the Type 996, the diameter of the internally ventilated and perforated brake discs at the front and rear wheels has been increased by 20 millimeters to 350 millimeters. As an option, Porsche is also offering its optimized ceramic brake system, PCCB (Porsche Ceramic Composite Brake). The advantages of this high-tech material mean a reduction of 17 kilograms compared to the standard brake system, excellent fading stability owing to consistent friction values and absolute corrosion resistance. The brakes now have a diameter of 380 millimeters at the front axle and 350 millimeters at the rear.
A characteristic design feature of the new 911 Turbo is the modified front end with its distinctive, tautly drawn cooling air inlets. In conjunction with the standard-equipment oval bi-xenon headlights, they define its unmistakable image. The harmonious front view is enhanced by widely placed and deep-set fog lights and by new LED flashers, which are situated in the lateral air inlets of the front end. From the rear perspective too, the Turbo takes on a more powerful appearance. This is due first and foremost to its tail end, 22 millimeters wider than that of the previous model, to which the redesigned wing spoiler element has been aligned. It now slopes downward slightly at the sides to nestle into the contours of the rear fenders. The lateral air inlets behind the doors have also been redrawn and, together with the new air ducts, afford a more efficient supply of cooling air to the charge-air intercoolers.
The basic Euro price for the 911 Turbo is 115,000 Euros. In Germany it is available for 133,603 Euros including value added tax and country-specific requirements. In the USA the 911 Turbo is priced at 122,900 Dollars (not including taxes), and will be available as from July 8, 2006.
In addition to the 911 Turbo, as a special surprise at the Geneva Motor Show, Porsche will be presenting another world premiere: the new 911 GT3. You will receive technical data and photos of this “racing car for the road” on February 28, 2006, the first press day in Geneva.
johnei is offline   Reply With Quote
Old 02-13-2006, 11:17 AM   #2
sasquatch95
Member#: 17163
2006 Legacy
Non-GT white
i <3 that car so bad
sasquatch95 is offline   Reply With Quote
Old 02-13-2006, 11:28 AM   #3
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
Looks good. Hopefully they put some of the edge back into it that they lost in the 996.
mhoward1 is online now   Reply With Quote
Old 02-13-2006, 06:50 PM   #4
amdmaxx
Member#: 31665
2006 Saab 9-2x Aero
SICK!!! Just SICK!!!
amdmaxx is offline   Reply With Quote
Old 02-13-2006, 07:09 PM   #5
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
Check me on this - Did it actually say the Tiptronic reaches 0-100 km/h -faster- than the manual?
fogdor is offline   Reply With Quote
Old 02-13-2006, 07:13 PM   #6
WRC1
Member#: 47803
2000 Impreza 2.5 RS
Blue Ridge Pearl
I really like the car minus the drug dealer rims
~Leor
WRC1 is offline   Reply With Quote
Old 02-14-2006, 01:06 AM   #7
Len
Member#: 39937
2011 328i 6MT
LMB
Bummer eh?
Len is offline   Reply With Quote
Old 02-14-2006, 01:13 AM   #8
Len
Member#: 39937
2011 328i 6MT
LMB
This "sport button" officially qualifies as the button I wanna push the most before I die.
Old 02-14-2006, 05:10 AM   #9
Timmysubie
Member#: 67043
2005 WRX
CGM Cobb stage 2!!
This got me excited...
An optimized setup gives the vehicle the wherewithal to power from zero to one hundred in just 3.7 seconds...
That is until i read this....
...and to reach 200 km/h after a mere 12.2 seconds.
I didnt believe it for a minute, but i was praying that wasnt a typo.
Timmysubie is offline   Reply With Quote
Old 02-24-2006, 07:23 PM   #10
SUBE555
Member#: 24043
2005 Legacy GT Sedan
While looking for info on the 911 GT3 on Porsche earlier, I tripped across THIS really well done piece of media on the new 911 Turbo on the Porsche site. Makes you want to own one after you view it.
I wish Subaru could do so well with their advertising, makes you feel the product and get a sort of connection with it.
SUBE555 is offline   Reply With Quote
Old 02-24-2006, 08:38 PM   #11
amdmaxx
Member#: 31665
2006 Saab 9-2x Aero
1 mile = 1.6xxx kilometers..
u can calm down now..
Old 02-24-2006, 10:21 PM   #12
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
~Leor
amen to that....
jigga is offline   Reply With Quote
Old 02-24-2006, 10:28 PM   #13
SUBE555
Member#: 24043
And amazing as such, they're growing on me.
Old 02-25-2006, 12:12 AM   #14
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I like the way GT3 looks much better than this car.
Old 02-25-2006, 09:08 AM   #15
blubaru703
Member#: 71380
^^i think they both look great.
blubaru703 is offline   Reply With Quote
Got a ride in a 997 Porsche 911 Turbo today... WRX Shenanigans Off-Topic 62 06-13-2008 01:11 AM
TTP turbo upgrade for the Porsche 997 Carrera AVANTI R5 Non-Subaru News & Rumors 0 02-04-2008 08:39 AM
Whose white GC8 @ Porsche 997 Unveiling? FiKtIOn Texas Impreza Club Forum -- TXIC 3 09-01-2004 11:06 PM
Porsche 997 SkirtBoy Off-Topic 49 05-18-2004 08:46 AM
Porsche 997 officilal photo and specs crystalq3 Off-Topic 7 05-11-2004 05:00 PM
