Old 02-13-2006, 09:01 PM   #1
Huff
Member#: 103020
2004 WRX/STi Swap
Java Black Pearl
Default V.4 or 5 into 04 WRX
I'm getting a complete JDM swap from a version 4 or 5 sti for my 2004 WRX. Everything I am aware of. ECU, Motor, Trans, Axles, Diff, Engine Harness uncut. Is there anything i should be aware of with the swap into my car?
Huff is offline   Reply With Quote
Old 02-13-2006, 09:07 PM   #2
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Um....
Why?
jamesfacts is offline   Reply With Quote
Old 02-13-2006, 09:25 PM   #3
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
Why indeed.
THAWA is offline   Reply With Quote
Old 02-13-2006, 09:36 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
don't
Old 02-13-2006, 10:56 PM   #5
Huff
Member#: 103020
2004 WRX/STi Swap
Java Black Pearl
Why shouldn't I? I threw a rod bearing in my WRX motor! Why not swap it?
Old 02-13-2006, 11:01 PM   #6
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Exactly... Why not? Its JDM so right off the bat it will make 60+more HP then his current motor, and be able to handle a ton more.
The only reason I can think against this would be if you ever had to pass emissions; if that was the case then I would swap only the shortblock.
powerlabs is offline   Reply With Quote
Old 02-13-2006, 11:08 PM   #7
THAWA
Member#: 44581
3 Boxers 2 AWD
Good enough reason for me.
Old 02-13-2006, 11:11 PM   #8
Huff
Member#: 103020
2004 WRX/STi Swap
Java Black Pearl
Emissions I'm not worried about wat so ever...
Old 02-14-2006, 12:16 AM   #9
jamesfacts
Member#: 51282
98 RS
Why will it be able to handle a ton more? A v4 block isn't unusually strong - and if he goes through with the swap, his mod potential will be seriously diminished. If anything, he should do a v7+ swap.
v4 is a step backwards... it makes no sense to rewire a GD for a gc motor.
Old 02-14-2006, 07:52 AM   #10
Huff
Member#: 103020
2004 WRX/STi Swap
Java Black Pearl
So ur saying to look for atleast a version 7 jdm sti motor?? does my clutch and flywheel bolt to the jdm motors?
Old 02-14-2006, 11:03 AM   #11
linsavy
Member#: 11620
1997 GF4-STiV3 clone
The wiring for a V7 is simple into WRX. Not so for a V4 or V5. The downside of course is the significant increase in cost for the motor. You save money on the install and spend it on a new better motor by going with the V7.
linsavy is offline   Reply With Quote
Old 02-14-2006, 11:10 AM   #12
Huff
Member#: 103020
2004 WRX/STi Swap
Java Black Pearl
thank u very much sir
Old 02-14-2006, 01:09 PM   #13
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
bzzzt its in the EM so if he uses a usdm ecu (which won't work so it a mute point) it won't be any advantage
a ver 5 or later block will have the high density crank sensor (i believe)
when subaru changed crank sensors in jdm land isn't clear
the price on short blocks really isn that much ... look for a v7 or later or for that matter a usdm sti block for ~1500...
your going to need a retune either way
Old 02-14-2006, 01:15 PM   #14
Huff
Member#: 103020
2004 WRX/STi Swap
Java Black Pearl
i'm having my sponsor order me a v7 longblock with harness, turbo, ecu, everything. I think I'll be alright that way
04 STi engine into 04 WRX with 5 speed benben84 Subaru Conversions 4 04-22-2009 10:25 PM
wtb: TIAL wg SPRING .4 OR .5 BAR...SMALL GREEN,RED,or blue JT's06sti Private 'Wanted' Classifieds 3 02-12-2009 07:27 PM
Anyone know where to get STI V. 4 or 5 drivetrain? or good prices on STI gearset. Rallyspec Transmission (AT/MT) & Driveline 5 04-25-2003 02:27 PM
Wash 'n' Wax meet - 5/4 or 5/5 keyroc Bay Area Impreza Club Forum -- BAIC 0 04-29-2002 01:22 PM
4 or 5 point harnesses for non caged WRX??? FreeBMW Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-15-2001 12:07 AM
