Old 02-13-2006, 09:15 PM   #1
darkmist2k1
Member#: 31364
Ver6 Trek and couple
bottle of gatorade 4boost
Default turboing a RS...questions
hey everyone.. i have about a 1 or 1.5 year before i can swap out my engine.....so my friend persuaded me to slap on a turbo and have fun with it. so it got me thinking! I dont want to waste a lot of money on it! so maybe i want a simple stock wrx setup.. not too crazy!
i got couple of questions!
will a wrx header fit on a 00 RS engine(ej25)?
would it be efficent to run the td04 at 5 or 6 psi?
can i operate it with just an apexi SAFC to control the fuel?
do i need bigger load injectors?
What else is needed?
~Sunny
darkmist2k1 is offline   Reply With Quote
Old 02-13-2006, 09:37 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
bad friend bad
do you need this car for transportation a turbo kit will fail
Old 02-13-2006, 11:02 PM   #3
darkmist2k1
Member#: 31364
Originally Posted by Jaxx
bad friend bad
hahhaha...yea bad friend...and yea it a daily driver
Old 02-13-2006, 11:04 PM   #4
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Wrong forum!
Exhaust header? Yes. The up pipe will hit the crossmember though, so the setup won't work.
Yes. Would it be efficient on a 2.5L engine? Not particularly.
Only at very low boost levels.
Yes unless you are running very low boost.
If you don't know, you shouldn't do this?
powerlabs is offline   Reply With Quote
Old 02-14-2006, 12:35 AM   #5
darkmist2k1
Member#: 31364
Originally Posted by powerlabs
Wrong forum!
nice! answer alot of my questions!! i though a putting wrx turbo into a RS is consider a swap! hehe..maybe not! ..thanx again powerlabs
Old 02-14-2006, 01:19 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i would add that a safc will only work in a 98 or 99 rs not so well on a 00+
Old 02-14-2006, 09:07 PM   #7
jayfressh
Member#: 16847
2000 impreza rs 2.5
mach I maroon
Post
Here's some advice to live by my friend "A blink is the same as a nod to a blind horse"
Do your homework there are alot of options, screen name Chadsuabru or something like that, sells a uppipe that will clear the cross member. as stated below STOCK wrx up pipe will not clear.
jayfressh is offline   Reply With Quote
Old 02-14-2006, 09:21 PM   #8
Charge
Member#: 3313
subachad is the name you're looking for. I know he had stopped making them for a while...not sure if he started up again.
Either way...do a search in Aftermarket Forced Induction. The forum's not that active(most people have veered away from attempting this as it's just not economically sensible or generally reliable), but there's tons(and I mean tons) of old information in there that's pertinent to what you're asking.
It's NOT as simple as slapping on some WRX parts. There's tons of minutea involved that most individual posts on turbo'ing an 2.5RS don't account for. Read about 15 of them and you'll probably cover most(but still not all) of the basics. Also, concentrate on ones that are of similar years as yours. There's lots of differences for the various years.
Charge is offline   Reply With Quote
Old 02-14-2006, 10:07 PM   #9
BensonRST
Member#: 106895
1999 RS-T
Custom Charcoal
ok, here's the list of words that don't belong in a TurboRS project; persuaded, slap on, simple, not too crazy. but moving on, it can be done, and can be reliable. In order to use any of the stock wrx exhaust piping, you have to swap in a turbo crossmember. the stock wrx uppipe doesn't hit the xmember, it hits the side of the head. you can have a machine shop make a 1 1/2" spacer to go between the uppipe and the manifold. just bring the gasket to the shop and say, make me one of these and it will work fine, it just pushes the rubo back slightly. the NA 2.5 intake manifold puts the throttle body further towards the firewall, and the wrx top mount is a tight squeeze. the 00rs ecu will learn around an SAFC from everything i've heard, so get some real EM. as far as why it wouldn't be effecient to run 5-6 psig on the 2.5, that's untrue. that's what i'm running and it is incredibly powerfull. My friend's stage 4 wrx can barely pull on me until about 80, then he starts walking away. bigger injectors are a god idea. i believe the stock 280's run out at about 4-5 psig. as far as being econimically insensible and unreliable, also not true. i did my whole turbo project for under $2000. i got alot of really good prices on some very good used parts. that's the trick. and there are also plenty of people still doing turbo projects on RS's, they just all go to RS25.com, not here, you'll find much more info there. but $2000-3000 for a mid to lox 13 second car is hardly expensive. with prpoer engine management, and a solid tune, 6-7 psi will last as long as you want. good luck.
BensonRST is offline   Reply With Quote
couple of generic turbo rs questions tverdek Normally Aspirated with bolt-on Forced Induction Powertrain 1 03-29-2004 05:45 AM
Legacy Turbo / RS questions SubaFastR Normally Aspirated with bolt-on Forced Induction Powertrain 4 09-10-2003 03:11 AM
'98 Turbo RS Questions MHC Normally Aspirated with bolt-on Forced Induction Powertrain 4 05-01-2003 09:35 PM
a question for anyone who turboed their RS IMPREZA GUY New England Impreza Club Forum -- NESIC 33 10-12-2001 11:56 PM
2.5 RS Turbo Kits Interest/questions/feedback Thug General Forum Archive 8 05-19-2000 01:01 PM
