Old 02-13-2006, 09:18 PM   #1
Klestrob44
Member#: 107275
Default 2000 OB: driver's side window will go down, won't come back up
I just bought this sweet 2000 Outback today, which really is immaculate, except for one (what i consider to be major) problem:
The driver's side window scrolls down fine, but will not come up. I've tried almost everything, and am certain that something is wrong or broken.
Anyway, I was wondering if some of you out there have encountered similar problems, and maybe can offer some reasons for why this is happening (and maybe give me a ballpark estimate on how much this would cost me to have fixed).
Thanks!
P.S: I tried starting the car and trying the window out, and also the window's motor wasn't broken due to frost or anything...
Klestrob44 is offline   Reply With Quote
Old 02-14-2006, 02:44 PM   #2
bongchild
Member#: 28352
1993 1.8 helL (AWD)
'06 Corolla XRS!
Since you mentioned a window motor I'm assuming you have power windows. Can you hear the motor running when you hit the switch? If so, then most likely your problem is a bad regulator. I had a similar problem, except my window wouldn't go up or down on its own.
It's pretty easy to fix yourself and the part should be pretty cheap (about $90). Just pop the door card off and have at it. There are service holes in the door itself and all the bolts you need to mess with are clearly visible.
bongchild is offline   Reply With Quote
Old 02-14-2006, 04:06 PM   #3
flanders
Member#: 76382
2000 BH
BP Wannabe
I had this problem and it was the switch or something like that. Paid the dealer too much to have it fixed. Ask in the Legacy Forum, they will know.
Ned
flanders is offline   Reply With Quote
Old 02-14-2006, 04:18 PM   #4
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Just had this issue on my 98. The switch was bad. Pretty cheap from a junkyard. Would've been $80 for the part otherwise. Mine powered down fine and then wouldn't come up. I could still get the motor to make noise pushing the swich down, so I knew it had to be the switch.
For mine you just remove the door panel, remove some screws and plugs and swap it out. Pretty easy really.
.02
Jared
gtwagon941 is offline   Reply With Quote
Window will roll down but not up!? GoneSingle Electrical & Lighting 2 08-04-2010 12:50 PM
Window will go up but won't go down. Photoroller Interior & Exterior Modification 2 07-31-2008 03:47 PM
My driver side window doesn't go all the way up flipguy80 Interior & Exterior Modification 2 09-15-2004 02:31 AM
Driver side window will not roll down Nettat Electrical & Lighting 0 06-09-2003 05:01 PM
Driver's side window clunking Big Tee Technical Forum Archive 6 09-17-2000 12:15 AM
