Old 02-13-2006, 09:19 PM   #1
reeksti
Member#: 106930
2006 WRX STi
Work Emotion
Default Just got a Cobb AP
i want to know where to get the maps from and what maps to use with my 2006 STi?? Plus what maps are good to run on my stock sti
reeksti is offline   Reply With Quote
Old 02-13-2006, 09:23 PM   #2
Scott Farmer
Member#: 87799
2005 STU STi
White/Gold For Sale!
Scott Farmer is offline   Reply With Quote
Old 02-13-2006, 09:38 PM   #3
reeksti
Member#: 106930
2006 WRX STi
Work Emotion
what do i use base map or real time map?? do i need to use anything else?
Old 02-13-2006, 09:50 PM   #4
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Not to be a dick but you should really read their manual. It will get you more straight answers than you will find here...BUT!!! A base map is a map that gets flashed to your ECU, it takes about 10 minutes and requires you to fiddle under the dash with some connectors. After you flash a base map, you can then load a real time map which will stay loaded until you unplug your battery or change real time maps again.
waktasz is offline   Reply With Quote
Old 02-14-2006, 07:57 AM   #5
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
the STI's will take ~30minutes to flash.
before you do anything READ the manual, then read it again, because i'd hate to see a "tried to install my Cobb AP and now i don't run" thread.
also for more info go to www.wrxforum.com
Quack is offline   Reply With Quote
Just got a cobb AP. 2Slow4You Newbies & FAQs 10 10-06-2009 04:50 AM
Just got unmarried 04 AP, can i just use it? o2sys AccessPort 5 04-23-2006 10:31 AM
Just flashed with cobb ap stg 1. 8psi boost joehack98 Engine Management & Tuning 17 01-07-2006 12:38 AM
just reflashed to cobb ap stage 1 intence Engine Management & Tuning 11 10-03-2005 03:36 PM
Got My Cobb Ap krustywrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 08-10-2005 01:36 PM
