Welcome to the North American Subaru Impreza Owners Club Sunday August 2, 2015
Old 02-14-2006, 03:15 AM   #1
dooba33
Member#: 107515
1995 impreza
green/white
Post 95 impreza 1.8 to jdm ej2.0t help!
I need help!!!! I am putting a ej2.0t into my subaru I need some help. I am try to choose the version that I wont and could install myself. Then maybe some wiring help to (PLEASE).
Thanks (please help)
dooba33 is offline   Reply With Quote
Old 02-14-2006, 04:26 AM   #2
dooba33
Member#: 107515
1995 impreza
green/white
Well mostly I need the most help on how I am to wiring this engine into my car. If anyone has do this swap could you help me out a lot and tell me the easy way to wiring it.
Would it be easy to get the whole harness uncut or just the engine part? The engine I am going to use is the jdm ej20t version 4
HELP!
Old 02-14-2006, 01:16 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
A: wireing is differnt between models and years and even some times mid year
B: subarus have a intagrated harness it will require you to strip your stock harness and merge it with a stripped v.4 harness
C: if you find some good documentaion of a ver 3-4 let me know i have a repository of just about every thing else
D: you need the ENTIRE HARNESS UNDER THE DASH!
Old 02-14-2006, 01:53 PM   #4
dooba33
Member#: 107515
1995 impreza
green/white
How hard is it intagrated the harness together!! Where could I get the full wireing harness from. I think that I am going to get my motor from tokyomotorimports which come with the engine part of the wireing harness only. Or should I order my engine from somewhere else.
Will my transmission that is in my car right now bolt right up to the ej20t or should I need get the transmission also. If I get a transmission will I have any more problems. Like the LSD..
Old 02-14-2006, 02:18 PM   #5
XENONSVX
Member#: 41719
XT, SVX, JUSTY &
GF8 STI V4 RA
I did the wiring on my V4 in about a day. Wasn't hard at all, but that's for me.
I used the pinouts on ravenblad, along with the JDM wiring diagram to solve a CEL.
I wound up taking out my dash and everything when I did it, but when I do my next swap I dont think you really have to, but it does make life easier.
XENONSVX is offline   Reply With Quote
Old 02-14-2006, 02:53 PM   #6
dooba33
Member#: 107515
1995 impreza
green/white
I cant what to start the swap. I need to order the engine all the little thing that i will need. But when it comes to wireing I dont have a clue, I have never done any wireing on a car but some amp installing.
Can anyone tell me the wirieng that I might have to slice. Or a web sit that could help on that.
Old 02-14-2006, 05:36 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
somewhere else. you need the full harness and the ecu
-unless its very cheep a ver 3/4 long block is worth ...~1200-1500 a full clip w/ tranny should be in the 2.5k-3k range
yes it will work but your clutch will slip you will need to upgrade that at a minimum
Old 02-14-2006, 05:48 PM   #8
XENONSVX
Member#: 41719
XT, SVX, JUSTY &
GF8 STI V4 RA
wiring diagrams
basically you splice all wires from the JDM ECU into the USDM "incar" wires (such as tach, fuel pump, power, ground, temp, ect, ect). Everything that hooks to the JDM motor from the ecu, you leave alone and run though the firewall.
Honestly, do a search. There's already a ton of good info on here, yahoo, rs25.com, ect. That's how I got all my wiring info
lol but here's what you've got to look forward to:
Old 02-14-2006, 06:50 PM   #9
dooba33
Member#: 107515
1995 impreza
green/white
That look like a lot of wire. About how many do you have to splice. Are they color to the same color when you have to spice them from my harness to the jdm harness
If I do us my old tranny, I still use a 1.8 clutch kit right ( sorry for the dumb ? but i am no share about that)
Does anyone have a good web sit to order my engine swap...?
Old 02-14-2006, 11:41 PM   #10
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
depending on how good you are with electrical. it might take you months. or it might take you a day.
some wires are the same collor, some are diff. that is something you will have to find out as you are going thrue the wiring.
also, the stock tranny wont last you to long(you will be putting over 2X the power thrue it). when your are looking into getting an engine, look into a package deal that will come with a tranny/ front and rear axles/ rear diff/ brakes/ suspention.
its not smart to have an engine in a car that has 250+hp, and that handles like a boat and that cant stop.
do your suspention and brakes 1st before you do the swap.
snowman4us is offline   Reply With Quote
Old 02-15-2006, 12:57 AM   #11
dooba33
Member#: 107515
1995 impreza
green/white
Thanks for all of the help all of you are giving me!! Can anyone tell me the wire that I have to keep for the jdm harness..
Has anyone do the same swap that i am doing??????
Old 02-18-2006, 01:06 AM   #12
dooba33
Member#: 107515
1995 impreza
green/white
I just got the wiring diagram for my old engine. Does anyone a jdm wiring diagram for the ej20t that they could scan and email me. thanks
But on the wiring I have to cut the new jdm wiring harness down tell I have just the engine part right then I have to splice body wiring into the jdm harness righ????? Or am I wrong.
Old 02-18-2006, 12:04 PM   #13
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
which ej20 they have been in production since 1989
Old 02-18-2006, 06:43 PM   #14
dooba33
Member#: 107515
1995 impreza
green/white
Hey sorry the version 4. Hey Jaxx you dont live that far from me I live in chewelah about 2 hour away....
Old 02-19-2006, 11:03 AM   #15
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
dunna know where that it ..
bit more than 2 hrs
Start address: Boise, ID
End address: Chewelah, WA 99109
Distance: 478 mi (about 8 hours 58 mins)
Old 02-19-2006, 07:42 PM   #16
dooba33
Member#: 107515
1995 impreza
green/white
My girlfreind wonts to go to school there. And she sayed that it only took about 2.5 hour for them to get there. Maybe that was from spokane. I dont know my girl cant tell judge time that well !!!!
Old 02-20-2006, 01:53 AM   #17
dooba33
Member#: 107515
1995 impreza
green/white
I was just going to turbo the old engine but there are not that many performance part out for (like headers)!!! How long would my engine hold up with a turbo kit on it??????
But on the other hand would I be a hole lot easyer to swap in a 1995 JDM Subaru Impreza WRX GF8 Front Clip. It Powered by the 240hp EJ20-T Engine, and 5Sp AWD Transmission.
Old 02-26-2006, 09:22 AM   #18
dooba33
Member#: 107515
1995 impreza
green/white
Would it be alot easyer to put that engine (FROM THE LAST POST) in beacuase it is the same year as my subaru??? Does anyone know where I could get a performance header for my 1.8 subaru?????
Old 02-26-2006, 04:39 PM   #19
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
nope .. about the same
its less complicated than a usdm swap (less wires) but will still require splitting and merging the harnesses
Old 02-28-2006, 11:47 PM   #20
imprezin04
Member#: 39482
2000 Impreza RS
SRP
anyone know about how many wires need to be spliced into in the U.S. in car wires? i am doing a similar swap and just trying to figure out how much time it will take. ive almost finished spliting up the wires and only saving the wires and connectors coming out of the jdm ecu. XENONSVX- where are the diagrams on that link you put there? i cant seem to find it. also, will i have to remove all the tape from the in car wiring like i did with the jdm harness? it seems like you did for your swap.
imprezin04 is offline   Reply With Quote
Old 03-20-2006, 10:51 PM   #21
dooba33
Member#: 107515
1995 impreza
green/white
ok back to the wiring that I will have to do. Is it like my radiator main fan relays, inhibitor switch, check engine light, vehicle speed sensor, ignition switch, main relay, fuel pump relay, canister, purge control solenoid valve, two way valve, ficd solenold valve, idle air control solenoid valve, pressure regulator, fuel tank, fuel cut valve, fuel pump, fuel filter, air cleaner, mass air flow sensor, throttle position sensor, pvc valve, throttle opener, gas temp sensor, EGR solenoid valve, EGR valve, fuel injector, ignition coil, check valve, air suction solenoid valve, air suction valve, crankshaft positoin sensor, igniter, front cat converter, oxy sensor.
Is that right wiring that i will have to spice from my main harness to the jdm harness. Where could I get just the JDM wiring harness and wiring digram. thank
Old 05-28-2006, 01:50 AM   #22
dooba33
Member#: 107515
1995 impreza
green/white
I need some help on finding a wiring diagram for the jdm motor. Could anyone help me out and tell me where to get one. And if I have all the right wires that I have to spice into the jdm harness.
Thanks
95 Impreza 1.8 engine, transmission, diff, shaft, axles DariusL 1993 - 2001 Impreza Specific Parts 7 04-19-2009 06:47 PM
Diagrams: Underhood Fuse Box Circuit, 95 Impreza 1.8 t3hWIT Electrical & Lighting 0 01-17-2007 07:18 PM
1995 Impreza 1.8 Smog problems... Can anyone help interpret results? Impretzle Normally Aspirated Powertrain 1 08-05-2006 11:44 PM
95 Impreza 1.8 suddenly not running right Impretzle Normally Aspirated Powertrain 14 01-31-2006 06:45 PM
Will a wrx aftermarket exhaust fit on a 95 impreza 1.8 NewbyScooby Normally Aspirated Powertrain 3 05-22-2003 03:32 AM
