Notices
Old 09-21-2001, 04:26 PM   #1
hillman
Member#: 1303
2007 Not a Subaru,
thank God.
Default Water Leak Other than Condensation?
This morning after changing the oil in my 2000 Legacy GT, I noticed a significant amount of water dripping onto the floor from just behind the right front wheel.
I had not recently run the air conditioner, so I'm sure it was not condensation from the compressor.
My next assumption was that it was coolant, but it was definitely clear and tasteless, so I'm doubtful.
Can anyone offer a potential explanation?
All I'm left with is that water from the rain overnight collected somewhere in the engine compartment, and drained after I pulled the car into the ( level ) garage. But that seems unlikely.
Thanks.
hillman is offline   Reply With Quote
Old 09-21-2001, 04:31 PM   #2
gumball
Member#: 1209
you mean you tasted it???? jeez!
I've had a clogged drain tube from the evaporator-you can see the tube in the passenger side of the engine bay at the bottom of the firewall, that gave similar symptoms. But you said you hadn't run the A/C- for me the bottom of the evaporator filled w/ about 1/2 gal. of water and just slowly leaked out through the foam seals.
The only way to check for rain would probably be to run a hose and check you door drains, side sill drains etc, and see if everything is ok.
gumball is offline   Reply With Quote
Old 09-21-2001, 05:54 PM   #3
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Default H2O ?
Moonroof drain?
Glenn O
nuburu2 is offline   Reply With Quote
Old 09-22-2001, 10:12 AM   #4
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default I assume....
you raised the car to change the oil? If you did this could have caused additional water to leak from your evaporator(A/C) box or as happens sometimes on my car therain gutter abve the windows down the a-pillar and onto the floor at this same point from inside the engine compartment. HTH
subysouth is offline   Reply With Quote
Visiting Oregon, other than Lake Crater and PDXtuning, any other cool place to see? maramaralula North West Impreza Club Forum -- NWIC 7 08-15-2007 05:45 AM
Will it do any permanent damage to a WRX to use other fuel other than premium? Soldier88 General Community 7 08-18-2004 08:57 AM
air to water IC and AC condenser Jaxx Normally Aspirated with bolt-on Forced Induction Powertrain 9 05-24-2003 06:42 PM
Other words you refer to the bathroom as, other than "bathroom" dorifto88 Off-Topic 26 01-05-2003 06:36 AM
OT: Other hobbies other than your cars, poll! HomerJay General Forum Archive 53 09-30-2000 12:13 AM
