Old 02-14-2006, 03:32 PM   #1
chaddeus
Member#: 56624
2004 Subaru WRX STi
Default AccessPort: Real Time Mode
I got my AccessPort and changed the Base. Now, when I want to switch to say Economy Mode (real). After sometime, if I forgot what mode I am, how can I check what real time mode I am in?
When I use the AP to check, it always give me my base mode
- Charles
chaddeus is offline   Reply With Quote
Old 02-14-2006, 03:58 PM   #2
hondaeater69
Member#: 60324
there's no way to check what real time map you are running that i know of. If you're not sure i would do a reset to erase the real time info.
Old 02-14-2006, 05:03 PM   #3
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
You can't check current realtime map.
mcowger is offline   Reply With Quote
Old 02-14-2006, 05:10 PM   #4
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Just reload another real time map...only takes 5 seconds. Then you will know fo sho.
waktasz is offline   Reply With Quote
Old 02-14-2006, 10:42 PM   #5
ivrep
Member#: 53237
2006 sleeper wagon
black
Impreza WRX
True....
Econo Map takes lots of self control.
I've used it once.
ivrep is offline   Reply With Quote
Old 02-14-2006, 11:20 PM   #6
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
Bah, Econo mode is useless. basically raises timing and drops boost. Just keep off boost, thats the best econo mode. And Yes, it does take alot of self control.
darksands is offline   Reply With Quote
Old 02-14-2006, 11:25 PM   #7
chaddeus
Member#: 56624
2004 Subaru WRX STi
I find it ok actually. I been driving list an econo mode all the time anyway
- Charles
Old 02-15-2006, 12:28 AM   #8
ALaDDiN
Member#: 98294
2004 Honda Civic
2006 Acura TL
This might sound like a stupid question.
I just got my Cobb AP and so far I have a TBE and an UP. Should my base map be the stage2 93octane? Or is that going to be my real map?
I have read the manual, but still find this real v. base map thing somewhat confusing . Could someone possibly explain this to me in simple english lol . .
ALaDDiN is offline   Reply With Quote
Old 02-15-2006, 01:04 AM   #9
ivrep
Member#: 53237
2006 sleeper wagon
black
OK. I'll try....
Yes with a full TBE you should run a stage 2 base map. Plane and simple.
Remember that when you flash the base map both sections in the ECU (base map and realtime map) get filled.
The base map has additional logic needed to run at the stage 2 level.
You should not run any stage 2 realtime map with anything but a stage 2 base map flashed.
When you flash a realtime map the base map is still there. Example base map: is Stage 2 93 oct....then you want to run an econo map just flash the econo realtime map....
My advice is pic the basemap carefully. Use one that meets your mods level of the car and the octane you are using. Its better to be safe than sorry so if you only put in 93 oct once in a while then use a 91 oct. map.
Big difference: base map vs realtime map,
Base map: additional logic, never goes away unless you revert to stock or change the base map.
Realtime map: limited control, can be erased by simply unpluging the battery or switching the realtime map...takes 10 sec.
If you need more info try...
www.cobbtuning.com
forum.....accessport......lots of good info here
later,
ivrep
Old 02-15-2006, 01:34 AM   #10
ALaDDiN
Member#: 98294
2004 Honda Civic
2006 Acura TL
Thanks.
NY times article about real time access to ECU Suladed Engine Management & Tuning 1 03-12-2010 05:39 PM
Real-Time Traffic Reporting, on Time AVANTI R5 Non-Subaru News & Rumors 0 09-19-2009 07:34 AM
('93-'01) We need a CHAT forum with real time chat capability! ScoutWRX Impreza Forum 1 06-04-2001 05:17 PM
real time chat Weezer General Forum Archive 2 03-02-2001 12:12 AM
Real Time rally update's on your phone! dbrown General Forum Archive 0 06-08-2000 08:21 AM
