Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
Old 02-14-2006, 04:08 PM   #1
stickboie
Member#: 38594
01 GC8
java black pearl
Default california smog test?
i was wondering if anyone knows what i need to do to pass the california smog test. i might be moving there and i would like to take my car. its a 02 wrx. i hurd that there pretty strict about somg. i have a gt37vnt with stright exhaust, header, upipe. i'm using the utec for tuning. tgv deletes, the case and heads are venting to the air, insted of back into the intake where its susposed to. i also have the throttle body flipped, with a custom intercooler and radiator. i know they do a visual test and a test at cruseing speed. i did a bit of research on it but i'm just wondering if im that far off. i don't think it'll pass in any state. hahaha.
stickboie is offline   Reply With Quote
Old 02-14-2006, 04:09 PM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
You are ****ed
You basically have to put it back to stock. Anything that doesnt look stock wont pass the visual. Internal stuff, or stuff like flywheels/etc. can get past if the actual emissions are fine.
Old 02-14-2006, 04:32 PM   #3
Mann Engineering
Member#: 77164
2015 STI CWP
2013 BRZ Limited
Yeah, they are pretty picky here.
You definitely need to have all the breather lines and everything connected back up to stock. You also need to make sure you have all the emission control devices on the car.
Regards,
Gary
Mann Engineering is offline   Reply With Quote
Old 02-14-2006, 04:38 PM   #4
stickboie
Member#: 38594
01 GC8
java black pearl
what kind of edmission control things? and if it looks like it does under the hood, i will never pass, right i don't have a factory airbox either its a big a$$ 4inch pipe with k&n filter.
Old 02-14-2006, 09:26 PM   #5
Mann Engineering
Member#: 77164
2015 STI CWP
2013 BRZ Limited
You need to have the stock airbox on it. All the breather hoses and check valves like PCV. You will also need the charcoal canister that is mounted on the back. Fuel rails need to be stock as well. And the Biggest one of them all OBDII, unless you are still running a USDM motor. Manifold needs to be like stock.
So yeah it is a big pain.
Regards,
Gary
Old 02-15-2006, 12:50 PM   #6
stickboie
Member#: 38594
01 GC8
java black pearl
i might have a suby for sale
Old 02-15-2006, 02:17 PM   #7
Lachlan
Member#: 19470
1981 Brat GL
register to a po box in nevada.
Lachlan is offline   Reply With Quote
Old 06-13-2006, 02:46 AM   #8
rexworx
Member#: 103232
MY05 GDA,MY04FXT6spd
PPG,Front LSD,4.44,E85
^^^^^^^^^^^^^^^could this be done?
rexworx is online now   Reply With Quote
Old 06-13-2006, 05:45 PM   #9
johnnyb
Member#: 57593
2015 Crosstrek XV
I had my OBS tested with a Cobb CAI on it. I don't think all places are as strict as some say.
johnnyb is online now   Reply With Quote
Old 06-14-2006, 05:29 AM   #10
MannyMohawk#5
Member#: 98807
1999 RSTi
RHD BF5 & BJ6
I'd say as long as you can pass the actual emissions part of the test, you'll be fine. You can usually get past the visual inspection fairly easy. But then again, some guys will pop your hood and turn you down if it doesn't look completely stock. You might have to ask around and pay extra to get that smog certificate. Shady mechanics FTW!!1!
MannyMohawk#5 is offline   Reply With Quote
Old 06-15-2006, 02:22 PM   #11
maddhatteroo7
Member#: 78840
yea kalifornia is ghey on smog laws...but what do u expect when u have kommunists running the state? if you're in the military u should be find with your out of state plate and tag on the window...if ur not military...well good luck with smog
maddhatteroo7 is offline   Reply With Quote
Old 06-19-2006, 10:24 PM   #12
di2co
Member#: 105648
2006 STI
wrb
Register the car as an out of state CA car, you will only have to pass 49 state emissions. But... if you get pulled over you will have to tell the cop that you just brought it to Cali. Also you will need to have a resident address in the other state (I used my parents in VA) to have the registration mailed to. DMV will not (at least not for me) mail registration to a PO box. You can do your 49 state emissions here in CA as long as the stuff coming out your tailpipe passes, ie no rollers or visuals. That's how I got my tube chassis '79 pinto w/ a 2.3 turbo motor registered. Hope that helps.
Jake
di2co is offline   Reply With Quote
Old 06-19-2006, 10:30 PM   #13
di2co
Member#: 105648
2006 STI
wrb
BTW, first check which county you will be moving to. Some counties like Imperial County only require smog to be done the first time you register so you could take the car back to stock, pass, and put all the aftermarket back on and never have to worry about it again. If you are moving to a major metro area though you'll have to do the things in my above post to register your car.
Jake
Old 06-19-2006, 11:00 PM   #14
Chi_San
Member#: 53558
2002 WRX Wagon
Jake
Do they not have a grandfather clause in Cali? In 79, I didn't think they had any kind of legal emissions.
Chi_San is offline   Reply With Quote
Old 06-19-2006, 11:15 PM   #15
di2co
Member#: 105648
2006 STI
wrb
the grandfather clause right now is 74 and lower, next year it will be 75 and so forth, I might be a year off but that's it. But no... there were not any REAL emission reductions till 79 you are correct. CA at this point does require any emission system to be intact back to model year specified. As for emission systems just look at a 69 camaro's vacuum system compared to a 79 and you'll see the "attempt" by GM to reduce emissions. Were emissions reduced during that period? Not really but it was a start. I work with large power plant systems both gas turbine and traditional steam systems and I deal with Cal EPA pretty frequently. Here in the great state of CA it's not about air quatlity any more but it's more a souce of revenue (spelling).
Jake
Old 06-20-2006, 12:06 AM   #16
Chi_San
Member#: 53558
2002 WRX Wagon
Ah, I see.
Glad I live in Oregon, where emissions aren't as strict, but then again, there's some bill on the table that would make our emissions MORE strict than Cali's!
Old 06-20-2006, 01:00 PM   #17
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
I heard they stopped adding a year last year or the year before.
I tried to get my 95 Honda Civic smogged last year. The guy i bought it from had hacked off the airbox and zip tied on a cone filter. I took it in and they wouldnt even test it because of the cone filter.
Technically in cali any mod is illegal. Even just a muffler. Even though you can mod up to stage 4 (vf turbo, tbe, up pipe, headers, intercooler, injectors) and still pass the actual sniffer you wont pass the visual, unless the guy is cool.
My car got impounded back in december and i got sent to the California State Smog Referee. It is basically a state certified smog place and they are very thorough. I had a full rotated setup with nos and a 2.2L stroker kit in an 02 wrx. I had it put back to stock, mostly. It still passed with the 2.2L stroker. I decided just to sell it and got an 06 STi. I didnt want to go through the hassle of taking everything on and off every two years to get smogged. Not to mention they have mobile sniffers now and they can bust you on the spot. I have bought parts from a couple guys down in LA who had both been pulled over and given tickets for their exhaust.
Old 06-22-2006, 11:22 PM   #18
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Ya the '75 thing is now locked at '75, wont go any newer than that.
Old 10-12-2009, 01:45 AM   #19
04trailsti
Member#: 179170
OK so from what i researched If you are military and have out of state registration then you should be fine as far as beign SMOGGED correct? Now does anyone know about the military base, will they smog you i have heard that cali bases are also more strict on emissions. or is that a rumor?
04trailsti is offline   Reply With Quote
Old 10-12-2009, 04:00 PM   #20
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
I can honestly say that Cali Smog laws are the bane of my existence. I know a fair amount of different "car" enthusiasts, and when it comes to smog, they all pay under the table.
You wouldn't be able to pass otherwise.
Heaven forbid you get sent to the state ref, i knew a kid with a 3000gt who got reffed and spend 1.5 months sorting it all out. Another guy i know "sells" his car to a relative every time he gets reffed.
DHRDAN is offline   Reply With Quote
Resetting ECU before California Smog Test dan240 Newbies & FAQs 18 10-13-2012 10:08 AM
will i pass the smog test in california? newerWRX Newbies & FAQs 14 04-08-2007 04:06 PM
Would the aftermarket FMIC fail the smog test in california. ix8vii Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 09-06-2005 03:17 PM
California Smog Question Jaykkub Southern California Impreza Club Forum -- SCIC 3 11-16-2002 03:20 PM
HELP! I need a SMOG test locally. Won't pass the "visual" test! ARG Southern California Impreza Club Forum -- SCIC 13 05-02-2002 10:20 PM
